Re: MWSTEWART | Si project - Reassembly 31/12
Postby Excursion on Mon Jan 31, 2011 11:06 am
Well the interior retrim is being handled by someone else, which leaves the following main chunks of work:
- Engine build
- Wiring
- Engine bay modifications (ABS, engine mounts, gearbox mounts)
- Engine bay paint
- General reassembly
I've decided to outsource the engine build to someone else because the reality is that this project would likely end up going into next year. I've just got too much going on now to really get this Si finished in a decent amount of time - which is a bit pointless in this case as it isn't a show car; I'm building it as something that can be used every day! I'm a bit dissapointed about this in one way, as it's something I'm more than capable of doing and I feel like I'm giving away part of my project to someone else - but I had to make a sensible decision here based on what I can realisitcally get done in a sensible timeframe.
I've been friends with Ian Howell for years now so he's going to take on my engine build to get away from the Wife and Kids for a bit :) What I'll get back is 400bhp ready to bolt in, which leaves me to sort out fabrication and rebuilding the car, so I may actually get it on the road for this summer.
Desired Spec
* I'd like to keep the rev ceiling at 7.5k for long term reliability.
* I'd like to do whatever possible to keep NVH to a minimum (if that's at all possible)
* 400bhp max
Long term reliability is also a consideration for me, I'd like it to be 'turn key' for years to come. The car won't be used for any kind of launches or sprinting, but I do like flat out high speed driving, so I'd like it to be able to withstand that. I hadn't added anything regads engine response, rev band etc as I doubt this is much of a consideration in something so light as a Fiesta!
Most important to me would be low speed tractability and good manners (I suspect this is down to the map) - I'd like to be able to take the car away for a weekend and use it for 'normal' activities and around town if I wanted.
Re: MWSTEWART | Si project - Engine Build 31/01/2011
Postby jonyb4 on Mon Jan 31, 2011 11:31 am
more or less how i like to have my car (but obviously alot less powerful :P )
having soemone do the engine for you is alot of sence, but yea diown side is it makes you feel like your skipping on a part of the build, but if it allows you to have a easier stress free build and have it sooner, its a good decision
Postby Excursion on Sat Feb 05, 2011 3:43 pm
Dropped off the engine today, spec is:
  • Ported exhaust side (being a Black Top the inlet flows 20% more than a Sliver Top as standard)
  • Ians exhaust cam and vernier pulleys on both cams
  • Focus RS Pistons
  • Ians rods to suit the 22mm pin pistons
  • GT2871R and I'm going for a bigger exhaust housing to reduce back pressure - this will raise boost threshold by 250rpm but keep under bonnet temps lower
  • TiAL stainless steel exhaust housing
  • Pulsar inlet manifold
  • Couple of thou honed from the standard bores to allow more expansion room for the pistons, because I want the engine to withstand my high speed driving (props to Ian for this as I wouldn't have known this tip!)
  • WRC Inconel exhaust manifold
That's about it - there's really not much work involved to get 400, especially when starting with a brand new Black Top! I'm having it mapped on the Dyno with Pectel T2; I thought T2 was prehistoric but Ian assured me that the processor in it is still better than Autronic. I asked for 400 and Ian said I'll get a good 400 - so we'll have to wait and see what that means :lol:
I'm working on the car today and tomorrow. I hope to get the side skirts on, and the mk5 pedal box in.
Re: MWSTEWART | Si project - Engine with Ian 05/02
Postby fiend on Sat Feb 05, 2011 4:01 pm
Nice progress, where will it be mapped at? On an engine dyno?
fiend
Postby Excursion on Sat Feb 05, 2011 7:37 pm
fiend :Nice progress, where will it be mapped at? On an engine dyno?
Yeah, Harvey Gibbs I think...
Postby jimmyesh on Sat Feb 05, 2011 7:46 pm
Top work - That engine will be brilliant by the look of things :Q
jimmyesh
Your car: Yes
Postby Excursion on Sat Feb 05, 2011 7:53 pm
jimmyesh :Top work - That engine will be brilliant by the look of things :Q
Cheers mate. I hope so :D It feels like a a cop out giving it away to someone else to do, but needs must.
Postby fiend on Sat Feb 05, 2011 8:30 pm
Excursion :
I was going to say Harvey Gibbs. Won't go wrong there. :D
fiend
Postby - Danny Boy - on Sat Feb 05, 2011 8:38 pm
Engine spec sounds good :) Should be lovely when its all done! Be nice to see this car back on the road too :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby SEG1 on Sat Feb 05, 2011 9:11 pm
with the gt2871r off the car and as your waiting for the engine to be build, you might as well port the wastegate hole to reduce boost creep.
TD done mine and it does make a difference.
not expensive either.
take it you are going internally waste-gated. if not ignore me :lol:
SEG1
Postby Excursion on Sat Feb 05, 2011 9:22 pm
RS_seg :with the gt2871r off the car and as your waiting for the engine to be build, you might as well port the wastegate hole to reduce boost creep.
Thanks for the tip mate but I will be going for a TiAL external gate :D
Postby ~nomad~ on Sat Feb 05, 2011 9:36 pm
did you get to the bottom of pulsar inlet fitting then?
~nomad~
Your car: Breadvan
Postby Excursion on Sat Feb 05, 2011 10:06 pm
~nomad~ :did you get to the bottom of pulsar inlet fitting then?
Yes mate, I will upload pics when sorted.
Postby ~nomad~ on Sat Feb 05, 2011 11:34 pm
was it a case of having a adapter plate made up or machining the inlet itself? very very interested in using same setup on mine, you think it would be good in a N/A?
~nomad~
Your car: Breadvan
Postby Excursion on Sun Feb 06, 2011 12:55 am
~nomad~ :was it a case of having a adapter plate made up or machining the inlet itself? very very interested in using same setup on mine, you think it would be good in a N/A?
Ports 1&4 need some welding inside the port and some adjustment with a die grinder. Quite a few breather take offs welding up, and an adapter plate welding on.
I'm ditching the ITB 'cos they are a pain to map, and don't make a massive difference in a turbo car. For N/A i'd leave them but balance them up with an airflow meter used for setting carbs.
Postby SEG1 on Sun Feb 06, 2011 1:09 am
Excursion :
the way forward :Q
SEG1
Postby Excursion on Sun Feb 06, 2011 7:03 pm
I fabricated some brackets to hold the edge of the RS skirts firmly against the sill - I rolled a step into some 1mm sheet which will trap the return lip on the inside edge of the skirts. No they're not perfectly straight, I rough cut them with an angle grinder :lol:
Mk8 Fiesta front panel clips for the bottom of the skirts (up into the sill) - these weren't long enough in the end, I think they were over £1 each and I over ordered in a big way :lol:
I will try something like this:
Drilling holes for the brackets and trim clips - I pumped a load more wax into each hole until it was dripping out of the sill join. I then painted each sill with semi-set Waxoyl.
Brackets fitted and a skirt fitted to show the good fit
Windows are in, new side mouldings, new weather seals etc (had to wait an age for the Mk5 aperture seals as they were on back order!) and new genuine lights all round - although I have changed my mind about the lights and will fit some smoked side repeaters and my UK RS accessory rear lamps. Here's the car with the skirts and new brakes fitted. I'm going for silver calipers with blue AP Racing decals.
I'm still waiting for a Mk5 aerial which is on back order, when it arrives the car will be water tight and I can give it a good clean. I will take some pics with a decent camera when that's done!
Re: MWSTEWART | Si project | Skirts and brakes 06/02
Postby - Danny Boy - on Sun Feb 06, 2011 8:00 pm
Awesome stuff as usual! :aviator:
- Danny Boy -
Postby EUFez on Sun Feb 06, 2011 8:50 pm
Awesome work! I've fallen in love with this colour.
EUFez
Postby jonyb4 on Sun Feb 06, 2011 9:44 pm
looking fantastic mark, i love this colour so much
cant really see whats going on witht hat plate you've made, where is it?
the brakes look stunning, id honestly say leave them red, ive not read your going for a sleeper look, they shoud be shown proudly :)
Postby knuckles on Mon Feb 07, 2011 12:12 am
Mk5 aerial on backorder ? WTF :-?
are you talking about the base or the rod ?
knuckles
Your car: Fiesta Rs turbo
Postby tompeteRS on Mon Feb 07, 2011 2:08 am
Looking good :Q
Did you manage to sort all the mouldings out Mark?
tompeteRS
Authorised Trader
Authorised Trader
Postby Excursion on Mon Feb 07, 2011 11:03 am
Cheers all :D
knuckles :Mk5 aerial on backorder ? WTF :-?
Both mate, the strikers, door seals and a few other bits were also. I ordered in the first week of Jan and they only arrived at the end of last week :o
tompeteRS :Looking good :Q
Not yet mate, I will take the rear quarter one from you: please drop me an email with your price and payment details.
Postby jimmyesh on Mon Feb 07, 2011 11:18 am
Looking good :Q
jimmyesh
Your car: Yes
Postby Excursion on Mon Feb 07, 2011 7:56 pm
I've changed my mind again with regards wheel choice :lol: Another set to sell!
I've now decided on some Team Dynamics Pro Race 1.2 in Anthracite
I have an additional 44mm rear track - 22mm either side thanks to a combination of Ka hub spacers and ST170 brakes, so I know 205 profile will work there, but what about the front? Can 205/40/16 work?
Re: MWSTEWART | Si project | Will 205/40/16 work?
Postby Max M4X WW on Mon Feb 07, 2011 8:44 pm
Same wheels as I've got for mine, look forward to seeing them on :)
No idea about tyre size, I was going to use 195/45/15 to start with
Postby RS rob on Mon Feb 07, 2011 8:49 pm
how wide are the wheels mark? 7j???
RS rob
Postby Excursion on Mon Feb 07, 2011 9:34 pm
RS rob :how wide are the wheels mark? 7j???
Yes mate
Postby RS rob on Tue Feb 08, 2011 12:06 am
two options the way i see it
- 195/40/16 (would be too harsh for a refined gentleman as yourself) but would be the easiest for fitment and lack of rubbing
- 195/45/16 would be the best compromise
the 205 width tyre is envolving the archwork needed for 17's basically
i remember all the arch trimming i did years ago :rolleyes: :rolleyes:
RS rob
Postby jonyb4 on Tue Feb 08, 2011 2:09 am
couldn't agree more with the choice of wheels, the colour will be interesting to see how it works with the aubergine
can i ask where the Ka spacers were sourced from?
I'm in two minds whether the pro race 1.2's or 3's would suit my car best
Postby SEG1 on Tue Feb 08, 2011 7:12 am
i run 205 with no issues ,but they are 15s
205/50/15
SEG1
Postby leighk2010 on Tue Feb 08, 2011 6:45 pm
coming on very well mark!
love the td 1.2s would really like a set for mine..
also how hard were the brakes to fit in the end? just bolt on as you thought they would be?
leighk2010
Postby Excursion on Tue Feb 08, 2011 6:53 pm
leighk2010 :coming on very well mark!
They weren't in the end.
Going for double valve springs and a bigger Turbo now - may as well :lol:
Postby jonyb4 on Tue Feb 08, 2011 7:00 pm
:lol: oh dear
i can see this being the next most powerful zetec engine with pictures of harvey and iain standing aorund the engine in Fast ford like they did with theyre last :lol:
