Re: MWSTEWART | Si project | Will 205/40/16 work?
Postby Excursion on Tue Feb 08, 2011 11:51 pm
Ha. I'm not sure I want it in a magazine. I've never really been a fan of the Ford ones. Sorry I never answered your question, the spacers were from Ford, £20 ish complete with bolts. They go for around £11 second hand. Bargain really given the benefits.
Postby jonyb4 on Wed Feb 09, 2011 12:11 am
are the spacers roughly 12mm each then?
if so i am buying some!
do you happen to have a part number for them, would help alot, but they just go straight on the mk3 hubs?
thanks though! :)
Postby knuckles on Wed Feb 09, 2011 12:13 am
Excursion :Ha. I'm not sure I want it in a magazine. I've never really been a fan of the Ford ones. Sorry I never answered your question, the spacers were from Ford, £20 ish complete with bolts. They go for around £11 second hand. Bargain really given the benefits.
i went to burtons today to buy hub centric 12mm spacers !
please dont tell me ford do these for less :o
finis number please mark :)
knuckles
Your car: Fiesta Rs turbo
Postby RS rob on Wed Feb 09, 2011 12:23 am
knuckles :
clark check out the axel spacers on the sport and street ka,
i think thats the ones mark is on about,
all the mk5 and 6 fiesta boys have them
i had 20.5mm ones for my mk6
did'nt think they'd fit a mk3 hub though?!?!?
RS rob
Postby Excursion on Wed Feb 09, 2011 8:42 am
Ahh, yeah, I've got a ZS beam on this. The ford spacers unfortunately only fit the beams on a mk4 and later.
Postby fiend on Wed Feb 09, 2011 8:58 pm
Are you going to be using the standard inlet cam?
fiend
Postby Excursion on Wed Feb 09, 2011 9:11 pm
fiend :Are you going to be using the standard inlet cam?
Inlet yes, exhaust no.
Postby - Danny Boy - on Wed Feb 09, 2011 10:21 pm
Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
I remembered seeing the spacers couple of years ago when working on a sport ka but never got around to getting any, and still to this day I have wanted some :lol: Luckily I never got them as I didnt know they wouldn't fit!
I think I will get some made up, which wont be hard at all really, might even do it myself in a workshop, just need the PCD of the hub bolts which I can find out from the internet somewhere I'm sure :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Excursion on Wed Feb 09, 2011 10:23 pm
- Danny Boy - :Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
The rear hub bolt pattern is different. It's pretty easy to make them, though :)
Postby jonyb4 on Wed Feb 09, 2011 10:26 pm
i know the measurements needed, pm you want them or catch me on msn danny :)
im sure the mk4 onwards ones can be filed to accept the mk3 beam, some do it with the focus rear discs
Postby Excursion on Wed Feb 09, 2011 10:29 pm
jonyb4 :i know the measurements needed, pm you want them or catch me on msn danny :)
You cannot file the Ford spacers.
Postby - Danny Boy - on Wed Feb 09, 2011 10:34 pm
Excursion :
Yeah I can see they are now, just looked on microcat to check! I'll get some made up then :)
- Danny Boy -
Postby jonyb4 on Thu Feb 10, 2011 3:04 am
- Danny Boy - :
Excursion :
i told you that a while ago you donut
Postby knuckles on Thu Feb 10, 2011 8:46 pm
Excursion :Ahh, yeah, I've got a ZS beam on this. The ford spacers unfortunately only fit the beams on a mk4 and later.
does the mk5 rear beam fit straight onto a mk3 then ?
but you lose a rear anti roll bar when you go over to mk5 rear beam :-?
knuckles
Postby Ratspeed on Thu Feb 10, 2011 8:55 pm
knuckles :
I think ive read or heard the ZS rear beam is better than a mk3 beam with an ARB. :)
Ratspeed
Postby Excursion on Thu Feb 10, 2011 9:05 pm
knuckles :
Yes mate the ZS rear beam goes straight on, and is superior mate by a long way. It's 1.2mm thicker steel than the mk3 beam, and the void bushes are stronger.
The Mk5 beam is an upgrade over the FRST one, and the ZS beam is 20% stiffer still
Postby Max M4X WW on Thu Feb 10, 2011 9:27 pm
Cant believe people still don't get the ZS beam thing, I've been saying for 4years or so that it was the best thing I did to my white one!
The ARB on an FRST isn't an ARB at all, its a strengthening bar.
Postby Excursion on Thu Feb 10, 2011 9:54 pm
Max M4X WW :Cant believe people still don't get the ZS beam thing, I've been saying for 4years or so that it was the best thing I did to my white one!
Mate I told everyone about it when the Mk4 had the phase 2 back in 99 :D
Postby knuckles on Thu Feb 10, 2011 10:00 pm
Excursion :
nice to know :)
on ecat there is only one axel listed for mk4/mk5 fiesta .
am i right in thinking that they are all the same then ?
if thats the case i may take a trip up a scrappy soon :)
cheers mark
knuckles
Postby Max M4X WW on Thu Feb 10, 2011 10:02 pm
There are two types deffo.
Yea wasn't saying I was the first mark, Just that I did it and no one else was :lol:
Postby knuckles on Thu Feb 10, 2011 10:19 pm
Max M4X WW :There are two types deffo.
care to elaberate on the two types ? :lol:
std beam
Zs beam ?
knuckles
Postby Excursion on Thu Feb 10, 2011 10:24 pm
knuckles :
std beam
Zs beam ?
Correct mate.
Postby jonyb4 on Thu Feb 10, 2011 11:00 pm
Excursion :
knuckles :
std beam
Zs beam ?
Correct mate.
not quite
earlier puma's and mk4 fiestas pre 98 i believe had a fork type mounted shock and the beam wasn't as thick, then they made the eye mounted shock beam which was stiffer, then the 1.7 puma and zetec s one was even stronger again
i know from owning a mk4, my mates puma which i worked on regularly and the fact everyone knows about the zetec s beam
apparently a twin anti roll bar mk3 beam is the equivalent to a zetec s beam
Postby Excursion on Thu Feb 10, 2011 11:04 pm
I was talking Mk4 phase 2 onwards i.e. if it's got digital dials, you're good.
The Mk3 beam with the ARB is awful - such a choppy ride. Two or three ARBs is a bodge and counter-productive. There must be flex in the right areas to make the car handle over anything other than a perfectly smooth surface :) :)
Postby jonyb4 on Thu Feb 10, 2011 11:08 pm
aye, wel all im saying is the twin arb stiffens the torsion side of the beam, effectively making it close to a Zs beam in stiffness
i could be wrong though
its no different to fitting a better/thicker arb front or back really
anyway!
any news on what tyres your gonna use?
Postby Max M4X WW on Thu Feb 10, 2011 11:22 pm
May as well fit a ZS beam, save messing with a Mk3 one and you get better drums too!
Postby - Danny Boy - on Thu Feb 10, 2011 11:22 pm
As this has gone onto stiffness of the rear beam now lol, another way to stiffen it up is do what Rob has done iirc, by welding metal plates into the beam itself.
But as Mark has said, you need a certain amount of flext and twist for it to be a smoother ride on roads. Now, if you are tracking it a lot perhaps, and 2nd rear ARB or stiffening up the beam by welding plates could be benaficial for less body roll, but of course this will effect other forces on the car, making it slightly less stable in other areas. Too much of a stiff rear end isn't always a good thing on a car as light as a fiesta with no weight on the rear either lol.
I think perhaps if this is going to get into a massive debate, we need to start a thread of its own, seeing as mods and admin are meant to be clamping down on this off topic talking - although this is technically on topic... But also, I dont want to fill Mark's thread with crap and debates about something like this as I wouldnt want it on my thread :)
- Danny Boy -
Postby Excursion on Thu Feb 10, 2011 11:30 pm
- Danny Boy - :As this has gone onto stiffness of the rear beam now lol, another way to stiffen it up is do what Rob has done iirc, by welding metal plates into the beam itself.
Welding plates in doesn't get around the fact the mk3 beam is weak around the suspension mounting points - it was built to be cheap :D
Postby jonyb4 on Thu Feb 10, 2011 11:31 pm
yea, its basicly the same argument as to fitting strut braces, they dont allow the needed flex on bumpy/curved roads, so if you fgo up the mountains alot dont fit a rear strut brace
Postby Max M4X WW on Thu Feb 10, 2011 11:33 pm
My point is that ford probably spent a bit more cash developing the beam for the Puma/ZS than the Mk3 :) not someone in a garage welding plates/adding bars :)
Postby - Danny Boy - on Thu Feb 10, 2011 11:35 pm
Yeah thats totally true Max.
- Danny Boy -
Postby knuckles on Fri Feb 11, 2011 12:10 am
Max M4X WW :My point is that ford probably spent a bit more cash developing the beam for the Puma/ZS than the Mk3 :) not someone in a garage welding plates/adding bars :)
Sent you a pm max regarding beam
rather than clogging up marks thread. :)
knuckles
Postby Excursion on Fri Feb 11, 2011 12:22 am
I don't mind chaps, it's interesting discussion.
Postby RS rob on Fri Feb 11, 2011 8:46 am
i'll let you know how my rear beam is, with the large section stitch welded
i bought it like that years ago along with my rs2000 rear drum/disc setup, it was done by the mark that had max's ZT originally
i've got rear axel spacers, and powerflex bushes everywhere except for the front rose joints,
a full corner weight setup and spring rates are the most important to me at the moment
RS rob
Postby knuckles on Fri Feb 11, 2011 12:10 pm
Excursion :I don't mind chaps, it's interesting discussion.
if thats the case ive just found the sport series mk5 rear beam on ecat :D
it cost £468.86 inc vat
better get saving :lol:
knuckles
