Ford Fiesta Mk3.5 Project OEM+: End of an era...
Re: Ford Fiesta Mk3.5' Projekt OEM+: Passed - MOT
Cheers - Ka, I'm giving it too my Dad or Sister to keep maybe. It's a good little runner lol
- EUFez
- MK2 Jamie
good news james
needs to be in winter mode
- Minstral
- Your car: *
Re: Ford Fiesta Mk3.5' Projekt OEM+: MOT Time & Prv Reg
jonyb4 :jason peers!
how'd you get the premotion you lucky devil
sorry mate only just seen that post
theres some mods that seem not to use the site no more, and ive put my name forward before and i did so again and here i am
jay i love that pic, you look such a scally
scally
thats my "scrap yard" coat, many pockets
Do the service yourself james
- hb69
- Your car: Fiesta 1.1 LX
sound like a wiser version of myself jay
MK2 Jamie :Get the alleycats on and slam it you tart.
I will for pictures. Not gunna have the Ally's on in this weather.
- EUFez
Minstral :good news james
Cheers man. Definatly. Winter mode - Low on the steel wheels.
Snow plowwww!
- EUFez
hb69 :Do the service yourself james
That's what I'm doing my friend. Really needs an oil change. Brakes changed and fluid needs bleeding. Plus new cooling liquid. Not much really.
Needs a new rocker cover gasket aswell. I've got all the bits needed, just need to fit them.
Rear brakes shoes need looking at aswell I suspect. What are the tools needed to remove bits to get to the brake shoes?
- EUFez
indeed johny, i norm tend to have a oversized tool box when i go for some reason too
EUfez, get the pics up
EUFez :hb69 :Do the service yourself james
prise off the rattle clip , and useally just the one bolt mate then u can flip caliper up
- xr2irhys
Car: 1996 Ford Fiesta Classic
I'll look in the Haynes Manual to see what tools are needed lol
- EUFez
Screw driver rubber mallet or hammer lol and socket set also copper grease
- xr2irhys
Yeah but what socket size?
- EUFez
the bearing bolt to keep the hub/drum on is either a 30 or 32,i believe the smaller one, think its the fronts that are 32
thats all you need unless the drum is stiff on, usually is if its been a while or the shoes are new, if so, use a hammer/mallet, and two flat blade screwdrivers, mdeium sized ones to praise it off, hammer and pull kidna routine
the clips holding the shoes in place, you can use a pair of long nose pliers and a small hammer and flat blade screw driver to knock them off, and pliers to get them back on
the hand brake cable i find the hardest, use the pliers and it will go in int he end, i pull and hold the spring back then try and wiggle the cable into the lever on the shoe, you will see what i mean
thats about it really, first few gos is hard, but once your used to them its easy, problem is, they tend to change designs on various cars, like a citreon will have complretly different styles
i trust you know what your doing with the service?
yearly tends to involve, the air filter, oil and filter, and rocker gasket, anything after a year do the plugs, fuel filter and coolant
dont need to worrk about the hub not on the front to do the brakes, just a 17mm socket in most cases with a short extention, or a deep socket
with the rear brake, i always have some wheel breaing grease to hand aswell, and i repack the bearings while off.
you may find the rear brake cyclinders could be leaking or stiff, i would check them that there ok before bleeding the brakes incase you need to change them.
tbh, if it was me for what they cost i would just change them while the drums etc are all off anyway
Another thing to note is one of the nuts that holds the drum on to the hub is left hand threaded, think its the drivers side, so when you think your trying to undo it you are actually tightening it up. Sure someone will confirm which side it is.
Yeah id do the cylinders aswell while you got them off. also as said check the bearings and regrease as required. Also clean the inside of the drum with some 80 grit sandpaper to get all the old crap out
- rs220bhp
brake cleaner
brillaint stuff, has so many other uses, it evaporates after a few mins
I'll get to it at some point.
Fanny is currently in Winter Mode, slammed on the Wellers at the moment. Took all the stickers off aswell. All ruined by the snow anyway.
- EUFez
surely in winter mode it would be raised up so it can have better traction on the snow and ice?
rather than slammed?
Your wrong - Grandad's ride high. Rebels ride low!
- EUFez
when are you gonna put some more photos up dude?
- fezza89
yea you lazy baxtered!
Once I get the rear coilovers on and slam the rear with the Alleys on. Hard to work in this weather! Plus my tools are knackered, rachet etc.
- EUFez
but its in winter mode, so the alleys wont go on till gone feb! so we gotta wait that long?!
I can fit the Allys on just for pictures though can't I?
Should be good photo whoring!
- EUFez
ill show you how to do the brakes mate, you can use my snap on toolkit aswell
ill borro the correct size socket from work and hopefully getting a breaker bar when the snap on man comes back next
- THOMMA55
Ok, cheers pal. That's if I ever get to see you!
- EUFez
Tried our best to get the rear suspension off, but one of the bolts is very worn and can't get it off. So buying new bolts then getting it off by any means necessary. I know a bloke that can grind it off.
God, I am slacking abit aren't I?... And one of my New Years resolution was to finish the Fiesta. Pttt AHAHAHA
- EUFez
the heads round off on the bolt u mean ? u tried a 6 sided socket?
- xr2irhys
xr2irhys :the heads round off on the bolt u mean ? u tried a 6 sided socket?
i agree they can get a better hold sometimes
jonyb4 :xr2irhys :the heads round off on the bolt u mean ? u tried a 6 sided socket?
Facebook like lol!
- xr2irhys
EUFez :Tried our best to get the rear suspension off, but one of the bolts is very worn and can't get it off. So buying new bolts then getting it off by any means necessary. I know a bloke that can grind it off.![]()
You are slacking mate
- MK2 Jamie
we started off with a 6 sided socket, was already a bit rounded off as we started, than couldnt find anywhere open so we had to make do with a cheapy stud extractor which was as usefall as a kick in the balls.
- THOMMA55
Going to have the rears on very soon, gunna get a friend I know to do it. Then both, front and rear will be "kissing tarmac" as they say.
- EUFez
