Ford Fiesta Mk3.5 Project OEM+: End of an era...
Re: Ford Fiesta Mk3.5' Projekt OEM+: Passed - MOT
Postby russ-RST on Sun Jan 02, 2011 1:41 pm
my 1.3 i had 120 out of :lol: and sounded the nuts for what it was only had a scorpion backbox on it and kept the tappets adjusted ran sweet as a nut :D was nippy for a 1.3 but now iv got the RST i would never go N/A again lol :rolleyes:
russ-RST
Your car: fiesta rs turbo
Postby jonyb4 on Sun Jan 02, 2011 2:49 pm
smidydevil :my 1.3 i had 120 out of :lol: and sounded the nuts for what it was only had a scorpion backbox on it and kept the tappets adjusted ran sweet as a nut :D was nippy for a 1.3 but now iv got the RST i would never go N/A again lol :rolleyes:
yea right lol, and im merry poppings :wink:
i agree with rob, the 1.3 is much more bearable, the 1.1 isnt imo
i have had a 1.3 mk3 and mk4 and the mk4 i used for over a year with the 1.3 in
its a much better engine
Postby 3lward on Sun Jan 02, 2011 6:23 pm
My 1.1 cruises at 80! i used to drive back and forth to cardiff everyday and would do 80mph there and back no problem with no issues.
obviously its not fast, but like ive always said ive got plenty of time for fast cars im happy just cruising in the little 1.1!
The Fat Fake XR2i
3lward
Postby EUFez on Sun Jan 02, 2011 10:44 pm
RS rob :as i started on a 1.1 first aswell,
i then progressed to a 1.3 there was quite a difference, did'nt have to change down on hills etc
same exhaust system was alot louder,
i reckon if your dead set on going for the carbs etc, then hats off to you
but get a 1.3 in there first, make it a little more worth while!
I am definatly buying the parts needed then fitting them at some point with a little help. Honestly don't know when though. I know what you mean with the comparision with the 1.1 to the 1.3, but my current engine has done low milege, and might I add, A BLOODY MINTER! Sooo maybe in the near future I'll upgrade to a better engine. Hopfully not a 1.3 though, maybe look into something bigger and better than that. But expect the wee 1.1 too stay with some meaty carbs on it. :Q
EUFez
Postby EUFez on Sun Jan 02, 2011 10:45 pm
3lward :My 1.1 cruises at 80! i used to drive back and forth to cardiff everyday and would do 80mph there and back no problem with no issues.
+1
Does the job for me also. Wicked cars!
EUFez
Postby b0yracer on Mon Jan 03, 2011 12:18 am
jonyb4 :
EUFez :
xr2ilookalike :its ashame about that dent it does look like it should pop out though as said that swage line might cause problems
are you still putting bike carbs on??
whats yours go like is it 1.1 or 1.3?
Yeah. Correct, I am still planning on having bike carbs put on. With some big help off a bloke on here that done it to his Si. Not too sure when I'll do it though... Definatly sometime this year.
1.1 mate, does the job for me. I'm not that heavy footed so I dunno how fast I can get outta it, probs around 80mph LOL
my old 1.1 could do 86mph hahah was so slow!
ive had 90 out of mine sure it would touch 95 but need a long flat road :D
as far as 1.3 every time ive asked about putting a 1.3 in ive been told not to bother they are not much better, after reading these replys a 1.3 sounds a easy and good idea
b0yracer
Your car: ford
Postby EUFez on Mon Jan 03, 2011 12:37 am
People have different opinons on it I guess.
EUFez
Postby b0yracer on Mon Jan 03, 2011 12:41 am
i know where there is a 1.3 might go see if its still there and get it
i might also change mine fro cfi to carb can you get a twin choke for the hcs?
b0yracer
Your car: ford
Postby jonyb4 on Mon Jan 03, 2011 12:53 am
xr2ilookalike :i know where there is a 1.3 might go see if its still there and get it
meh i dunno, could be a bit big and a different bolt design
i dont agree though, most of them ppl who said that it aint worth using the 1.3 over the 1.1, it is better, its very similar mpg and has alot more poke, its got alot more torque then the 1.1 even though its only got 5 more bhp
and its litrally a straight swap, out and in
Postby xr2irhys on Mon Jan 03, 2011 12:58 am
i started this conversion on a engine but never finished it , they do bolt straight on the manifolds with carb ,
xr2irhys
Car: 1996 Ford Fiesta Classic
Postby fezza89 on Tue Jan 04, 2011 9:43 pm
where did you get your lower arms? how much? did they come with bushes? :D
fezza89
Postby EUFez on Wed Jan 05, 2011 12:29 am
fezza89 :where did you get your lower arms? how much? did they come with bushes? :D
eBay :lol: £30, came with bushes obviously... But not Polybushed I'm afraid. There is a Genuine Ford Seller on eBay. Lower arms going cheap with him at £30. New bolts I bought from my local Ford for £12, for all of them lol
EUFez
Postby ~nomad~ on Wed Jan 05, 2011 2:15 pm
EUFez :
got a link to the seller? may have some bits i want :)
~nomad~
Your car: Breadvan
Postby fezza89 on Wed Jan 05, 2011 2:55 pm
will i need all new bolts to fit mine? never done it before
fezza89
Postby jayrs on Wed Jan 05, 2011 4:14 pm
if the threads are ok on yours no, you can reuse the old ones.
i would however get a ball joint pinch bolt in juat in case, they can be a bit of a nightmare with the torx head and rusting in resulting in damaged threads beating them out
Postby EUFez on Wed Jan 05, 2011 6:28 pm
~nomad~ :
EUFez :
I'll get the link up asap. Good stuff on eBay.
As for the Lowerarm bolts. I've always been told to buy new ones when replacing the Lowerarms. Better to be prepared. Their cheap anyway. Can get a full set at Ford for about £12
EUFez
Postby fezza89 on Wed Jan 05, 2011 6:35 pm
ill sort some new bolts just incase then,
is this the seller you got them from?
http://shop.ebay.co.uk/azcarpartsuk/m.h ... ksid=p3686
fezza89
Postby EUFez on Thu Jan 06, 2011 3:54 pm
Yeah best to buy the bolts.
I'm unsure mate. Can't find the seller. There's loads though, just use keywords 'Genuine Ford'
There's a guy on this forum actually that sells on eBay. Tom Peters?
EUFez
Postby Excursion on Thu Jan 06, 2011 3:59 pm
Ford specify you must use new bolts but TBH that's just them covering themselves. As Jay said, if the threads are good then you'll be fine re-using the bolts.
The nuts must definitely be replaced, though.
Re: Ford Fiesta Mk3.5' Projekt OEM+: New Pictures Tomorrow
Postby EUFez on Tue Jan 11, 2011 4:49 pm
Abit of good news. Fitting the rear Gaz coilovers tomorrow, with the new Ford Bolts. Then all four corners will be lowered. Can not wait! Not all mouth no more... Pictures to follow. :Q
Bad news - Went over a giant pothole a few days ago and one of my Weller steel wheels has been damaged. They look awful on the car anyway. As for the Allycats, I've got the rear ones but still haven't got the front ones. I bought them off a mate and there literally stuck on his Mk1 Fiesta, tried almost everything to get them off. We need an air gun or something. I'm so gutted! Won't be seeing them for a while. Paid for them aswell, p*sstake!
Oh and if anyone has some Fiesta Si arch spats then let me know. Would they fit the rear of the car?
Pictures tomorrow,
James
EUFez
Postby Excursion on Tue Jan 11, 2011 5:20 pm
EUFez :Would they fit the rear of the car?
Yeah, they go straight on.
Postby Ratspeed on Tue Jan 11, 2011 6:51 pm
EUFez :Abit of good news. Fitting the rear Gaz coilovers tomorrow, with the new Ford Bolts. Then all four corners will be lowered. Can not wait! Not all mouth no more... Pictures to follow. :Q
Pictures tomorrow,
James
a big long knucle bar will be more effective than an air gun mate
Ratspeed
Postby EUFez on Wed Jan 12, 2011 4:22 pm
All four corners are lowered now. GAZ Coilovers are fitted and on the lowest setting.
Got all four Allycat alloys now aswell. Trial fitting them tomorrow, but for now, the Wellers.
Here's the photos you've all been waiting for:
:Q
Don't worry, it's not staying that low. It's not good that low... As the fuel tank is 2inches off the floor and the exhaust hits the floor when rolling. So it's going abit higher.
More photos to follow...
James
EUFez
Re: Ford Fiesta Mk3.5' Projekt OEM+: MEGA LOW!
Postby fezza89 on Wed Jan 12, 2011 4:31 pm
i was gonna say.. how do you get on with speed humps but if you say its going higher :Q :Q
needs the allycats as you have said
otherwise very cool :Q
fezza89
Postby MK2 Jamie on Wed Jan 12, 2011 5:02 pm
EUFez :Image
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby EUFez on Wed Jan 12, 2011 5:16 pm
:Q
Cheers guys. Get sooo much attention from it. Well I would anyway... Because the exhaust makes terrible noises when I'm rolling. Scrapping on the floor. Ahaha! Allycats are going on tomorrow, but... Not driving with them on, as the Police said I must get bigger arches to fit them alloys, otherwise I'll get fined. :rolleyes:
Idea... Front Fiesta Si front arch spats. Anyone selling? Let me know, then they'll go on the rear. LOL!
EUFez
Postby fezza89 on Wed Jan 12, 2011 5:19 pm
fezza89
Postby MK2 Jamie on Wed Jan 12, 2011 5:21 pm
EUFez ::Q
F*ck da police.
MK2 Jamie
Postby - Danny Boy - on Wed Jan 12, 2011 6:35 pm
Now that is f**king low! :Q I remember when I first put my coilovers on and it was absolutly decked :D Im SO tempted to just go piss around with my coilovers now and make it so low :lol:
- Danny Boy -
Your car: Fiesta Si 2.0
Postby fezza89 on Wed Jan 12, 2011 6:39 pm
EUFez :
just got a brand new genuine ford lower arm for £1.70 lol
fezza89
Postby rs220bhp on Wed Jan 12, 2011 7:47 pm
EUFez ::Q
I can get you a pair of arch spats for a tenner.
looking good though but deff needs to be raised a little
rs220bhp
Postby Minstral on Wed Jan 12, 2011 9:03 pm
needs to be lower :bonkers:
good height james, be good with the alleys on then sort the stance
put si spats on front and rear if they poke at the rear as well
Minstral
Your car: *
Postby jonyb4 on Wed Jan 12, 2011 10:08 pm
i can sell you my spats just taken them off thanks to the RS kit gone on :)
Postby Dave G fsi on Thu Jan 13, 2011 9:53 pm
Looks beautiful mate :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby EUFez on Fri Jan 14, 2011 12:29 am
rs220bhp :
EUFez ::Q
Tenner? Sounds good man. PM me your Paypal address and I'll send the money asap.
EUFez
