Fiesta RS Project - *29.9.06* - f**k IT, I GIVE UP!!!
Looking good, all the clearances look fine regarding pipes/hoses
What are you doing about fans? The speed this project is moving on...it blows my mind!
i now need to reposition the grs cooler
when i put the headlights on, it was touching 1 side, and not the other, so it needs moving right literally 2 - 3 mm
dammit
- ianFRST
- chris-fiesta
Bummer. I got mine basically right, then slotted the mounting tabs to give fine adjustment. I have the ability to clamp the mounting bolts up very tightly, tightly enough to stop it moving on the road once the position's finalised. I don't know what your mounts are like, but if they're good enough, you should be able to get away with the same thing
yeah thats all i had to do, just slot the holes i drilled in the tab
original fan does not fit with the cooler mounted falt against the car
i noticed moodust and streetdragster slightly bent the tabs on it, so the cooler stuck out more giving more room for the fan. im going to have to find to small thin fans instead i think:D
when i rang him i think he said it was about a 4 week wait, but it arrived on my door in about 10 days
but this was this time last year
was there a waiting list for the grs cooler or did you get it straight away?
- ianFRST
**SHOCK HORROR** 21.1.06
after 3 hours of fiddling this morning, the engine was ready to go in, and so it did
now all i need to do is choose a filter
ithink i might opt for the 2L zetec item over the smaller renault 5 turbo one. might see if i can get a clio 16v one, that would be inbetween the 2? i think there is enough room for the 2L item
also go tmy ZS rear beam all fixed up
- ianFRST
yeeessss!!!! superb dude. whens the eta on completion then? we seeing it at the shows this year??
- ~nomad~
- Your car: Breadvan
~nomad~ :yeeessss!!!! superb dude. whens the eta on completion then? we seeing it at the shows this year??
well.......... i wanted to keep the bonnet catch, bit when we tried to put the turbo and rad in together, it was having non of it
thats the only hurdle i forsee at the moment
if it can be at shows, ill be there mate
- ianFRST
Excellent!
Keep up the progress mate. We should see some pretty wicked cars coming through soon!!
Agree with Pez on the remote filter and cooler mate. That folter looks far too small, unless your up for changing the filter on an overly regular basis.
It's also worth noting that Ford can sell you an external mount filter kit. They can be fitted to the Mondeo 24V.
Steve
Steve
- Captain Tightpants
pez / scort - still non the wiser as to a remote oil filter
max - no mate. was waiting for you to order them ones on ebay
and then await your fitting guide
and if all goes well, ill order them aswell
- ianFRST
Fitting guide = got the old ones out, now been told they dont make them for the mk5 yet till late feb
But i know people have them on ZSOC and zetecs.com so am waiting for a reply.
Have asked for dimentions for puma/mk4 ones!
Old ones were easy ish to remove, Prise plastic bits out, melt rubber lever metal bit out, cut outer metal and hammer it through!
Took about 30-40mins a side!
Basically... Remove the oil filter, and this item will screw on in plpace of it, it can be rotated to face any direction
Take off plate
The two ports on this unit are an oil feed and return pipe, the feed will go to this part....
Remote filter head
This is the remote filter head, you can bolt this on to somewhere like your inner wing, and means you can use the larger more efficient oil filter.
This the two ports are again feed and return, and the return will be directed to....
Oil Cooler
The oil will go in one end, and back out the other, back to the take off plate (item 1) and into the engine. Its a handy way of cooling your oil, and moving your filter to a more accessible/roomy area of the engine bay.
The parts above probably arent the correct ones for the job, but have a browse through the range and you will find something to suit your needs, or give them a call direct and ask what they advise for your particular setup.
Hope this has cleared things up slightly
Take off plate
Remote filter head
Oil Cooler
- Pez
i have only just read this post but very impressive, that is something i would love to do with mine but to scared that it wont go back to how it should be
Good work though mate good on you, will look reaaly mint
- gavrs1800
pex - cheers for the info, i think ill look into it a bit more. or maybe see how my oil temps are with the big filter fitted.
max - who said that, the bloke on ebay when you linked the item?
gav - cheeers
mark - why ya say that
gav - cheeers
- ianFRST
ianFRST :mark - why ya say that![]()
Well mate, during the years we've been on here I don't remember you doing anything on this scale...then you just pull a very high quality project out of the bag!
Woah Ian! Take it easy dude! I see some fairly major progress has been made, don't want to tire yourself out now!
The silver cam cover in that crisp white engine bay looks good enough to eat, reeeeally like it
Does the 2.0 pose problems that the 1.8 doesn't in terms of oil filters? Must do! The remote filter and cooler would be a good move, and you'll probably be one more person who fits their oil cooler before me!
mark - thanks
james - i dont forsee any problems as of yet (but then theres nothing in there bar the engine yet). i thought the way people said the filter needs to be alot smaller, i thought there was a major issue with room, and the filter catching the bulkhead / driveshafts / lots of other things or something, yet there seems to be ALOT of room behind the filter. i think ill just trial fit the 2L item and she what the crack is
as for the oil cooler
im not sure yet. thats just another obsticle tbh, as i need to sort the friggin zaust manifold now, which i thought would be just a case of an adapter plate, but thats not going to work due to room.
so i may just try and get it on the road, and look into a remote filter another time
- ianFRST
Streetdragster used an adaptor plate, but things are tight enough at the front end as they are without adding precious millimetres, as you've already done with the radiator being the thickness it is. Things start getting very tight up there!
What's wrong with a 1.6 Turbo filter, it be inbetween the two extremes you have then!
I think I might just be able to fit a 2.0L one on mine but because of the angle at which you withdraw it, it'd be very close to hitting.... 1.6 one serves me fine!
- mike_wall15
Car: 2002 BMW M3
mike_wall15 :What's wrong with a 1.6 Turbo filter, it be inbetween the two extremes you have then!
ill go get one
- ianFRST
pure sex m8
the power coated bits look spot on and think itll set the engine bay off very nicely, makes a change for chrome bits aswell
- chris-fiesta
max - i emailed them to ask them aswell, they said the same, they wont be available till end of feb / march time. so what i dont get it why advertise them forsale when they are not actually made
i might just wack the rear beam on and see how it is. then purchase some and fit them later on
chris - cheers dude
chris - cheers dude
- ianFRST
Retarded isnt it, Allthough after about 25 emails to powerflex and me showing them loads of posts to people with ZS' and links to pumabuild etc they rung pumabuild themself and were told that PFR19-707 will fit so they are on thier way!
Max M4X WW :Retarded isnt it, Allthough after about 25 emails to powerflex and me showing them loads of posts to people with ZS' and links to pumabuild etc they rung pumabuild themself and were told that PFR19-707 will fit so they are on thier way!
so whats that for? a puma mk4? so where you getting yours from and how much?
- ianFRST
looks very good mate!
the silver engne cover looks really good with the white paint
keep up the good work fella! hope to see it at a show this year !!!
- garyhurn77
