Fiesta RS Project - *29.9.06* - f**k IT, I GIVE UP!!!
Postby Excursion on Sun Feb 12, 2006 9:02 pm
Where'd you get your Oetiker ruler from mate btw?
Postby ianFRST on Sun Feb 12, 2006 9:11 pm
one day on the way to work, i passed an elderly lady at the side of the road trying to change her seemingly ok, but very flat tyre, i saw her struggling to remove the nuts, so i pulled over and her helped her undo them :)
and then off i went, leaving her to her business of swapping them over, and she gave me that ruler, AND a pen for my troubles. ive since lost the pen, and seeing as she was about 99 years old at the time, im sure she has long gone, so that ruler is all i have left to remind me of the old stranded lady :( :)
ianFRST
Postby Excursion on Sun Feb 12, 2006 9:17 pm
lol!
Postby rich_frst on Sun Feb 12, 2006 9:46 pm
yes mate, just wanted to see how your one had been put together and also wanted to know the spec of it (what parts you had used, any rover or FRST parts) if you dont mind
rich :D
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich_frst
Your car: mk1 sierra cos, mk2 escort est
Postby ianFRST on Sun Feb 12, 2006 10:04 pm
takes alot of modding to fit on.
frst throttlebody - rover end chopped off, plate welded onto end, and drilled and tapped to accept bolts for the tb
frst iscv - made to fit the underside of the inlet - chopped the bit off the end of the frst inlet, where the iscv bolts to, and welded that to the underside
rover fuel - modified to be moved down slightly, also modded to accept frst fuel pressure regulator
2 holes drilled and tapped in the rear for boost / dumpvalve takeoffs
adapter plate to fit to zetec head
have a browse earlier on in the thread, sure i put pics up of it before i got i powder coated :D
ianFRST
Postby Max M4X WW on Sun Feb 12, 2006 10:05 pm
Will my top mounts be buggered? I dont even know where they are!
Postby ianFRST on Sun Feb 12, 2006 10:07 pm
they are on the top of the suspension, look at the picture :P
they fit between the suspension top, and the struts. the suspension top mounts (the metal cup things) are ontop of them
ianFRST
Postby rich_frst on Sun Feb 12, 2006 10:12 pm
ianFRST :takes alot of modding to fit on.
:o :o :o :o :o :o :o :o :o :o :o :o :o :o
s**t dude, thats a wicked description!!!! thanks mate!!
i'll have a butchers and see....
rich :D :wink:
My ProjectS..
rich
07834862431
rich_frst
Postby FezzR on Sun Feb 12, 2006 11:11 pm
ideal solution to the 90degree bend, would be a spacer block to sit between the tb and plenum, but turn the angle of the tb through 45 degrees. but that will be expensive and time consuming
you can try and adjust the angle of the brake servo, like is done when fitting an escort servo as an upgrade, i recon that combined with hose trimming, will get it in there.
you could even try making a remote master cylinder
FezzR
God Damn Lazy
God Damn Lazy
Postby ianFRST on Mon Feb 13, 2006 3:53 pm
yeah i wanted my inlet to look exactly like dannyboys but it was impossible to make when i had no measurements of where i wanted it, so i had to go with what it is now :(
i might get it re-done again when its all up and running :D
ianFRST
Postby FezzR on Mon Feb 13, 2006 6:41 pm
ianFRST :i might get it re-done again when its all up and running :D
will you tho, most people would be happy its running and just leave it
FezzR
God Damn Lazy
God Damn Lazy
Postby ianFRST on Mon Feb 13, 2006 7:08 pm
yup :D dannys manifold looks the dogs :Q IH just simply wouldnt do it with out measurements :( he just didnt want to fook it up and get it wrong :lol:
:Q :Q :Q
or even if i could find another rover inlet, ill just take the measurements, and swap the 2 top halves over :D
ianFRST
Postby andyhardy on Tue Feb 14, 2006 5:32 am
Makes me want to have sex wee in my pants more than pictures of heeman10 wearing fishnet stockings! :)
I'll sort out the c-spanner, and no that's not another name for heeman10, that's his speciality, when he's not in the gym he's seeing to everyone's cum spanner.
Postby heeman10 on Tue Feb 14, 2006 9:58 am
You think about me too much!
Postby rich_frst on Tue Feb 14, 2006 10:08 am
Ian, you might be in luck mate.....
I have a rover inlet manifold for sale
http://www.fiestaturbo.com/forums/viewt ... highlight=
interested??
rich :D
My ProjectS..
rich
07834862431
rich_frst
Postby ianFRST on Tue Feb 14, 2006 6:59 pm
rich - not the same inlet :wink:
well, cut the roose hose this afternoon, and it WILL NOT FIT :cry: i reckon it was going to be close with no coil pack there as i could angle it downwards, but with the coilpack on, it made it worse :(
i reckon i might get in contact with lee at fusion, and see if he could come up with a metal pipe instead :)
so i gave up on the boost hoses again, and finished painting off the underside at the back :D :Q
ianFRST
Postby dannyboy on Tue Feb 14, 2006 7:52 pm
Thats a shame Ian, if you were thinking of modifying the inlet I can give you any measurements you need :D
dannyboy
Postby ianFRST on Tue Feb 14, 2006 8:14 pm
dannyboy :Thats a shame Ian, if you were thinking of modifying the inlet I can give you any measurements you need :D
or just give me your inlet :D
how about cash plus mine :Q :bonkers:
ianFRST
Postby heeman10 on Wed Feb 15, 2006 12:31 pm
That's a right arse! Silicone deflects well and everything, but you need to allow for engine movement and rubbing too, bugger :rolleyes: Looks nice underneath though :)
Postby chris-fiesta on Wed Feb 15, 2006 1:11 pm
Ian,
was looking through pf i think the otherday and there was a lil snip it of sunny's old fiesta and he was also talking bout his new project and he is planning to relocate his servo which sounds pretty smart... ever thought of doing this?
what ever you do please do not start chopping that inlet looks sweet as it is :Q
chris
chris-fiesta
Postby ianFRST on Wed Feb 15, 2006 4:09 pm
chris-fiesta :Ian,
chris
the reason sunny is moving his servo is because i think he boiled the brake fluid, i think it was caused by the red hot turbo iirc. and he was left with nye on no brakes on one of his top speed runs :aaah: i think thats his reasoning behind the moving of it. as for me :lol: no chance. im having enough problems trying to make 1 new rear line with a bias valve in it :lol: :oops:
ianFRST
Postby ianFRST on Wed Feb 15, 2006 5:10 pm
**another update, 3 days in a row :oooh: :aaah: :bonkers: :lol:
well i have a cold, and my nose wont stop running, so i havent been at work and im not oing back till it stops dripping :lol: so ive done even more work on the car today :bonkers:
fitted the new heater matrix. i dunno what people moan about ( i have no centre console which might make it a bit easier) it took me an hour, if that, and thats with a trip to ford to order some spring clips aswell :Q
why i had to buy a new matrix in the 1st place :rolleyes:
now im just waiting for 6 clips from ford, then i can remove the tape that holding it up :lol: :oops:
also managed to fit this all on me own, with out scratching the car, or the beam :bonkers:
so i fitted the rear avo coilovers aswell
you can see the front is still the spax shock and spring, and theres a huuuge gap compared to the rear. i think it needs to go down smidge more, there a fingers with between the tyre and the arch, so if i could get it down 1 more cm, then id be happy. even so, its lower than it use to be and i think it looks mean :Q
it also use to suffer from that dreaded fiesta lean, where 1 side is slightly lower than the other side, but the coilovers have cured it, so it must have been my old suspension
would have fitted the front, but it got too windy and i dont wana get worse :lol: :oops:
ianFRST
Postby heeman10 on Wed Feb 15, 2006 6:36 pm
:aviator:
Postby XRMike on Wed Feb 15, 2006 8:00 pm
nice mate.glad to see its comming together. :)
XRMike
Postby chris-fiesta on Wed Feb 15, 2006 10:07 pm
pureee sex :D :Q
love it...
chris-fiesta
Postby Sphinx on Wed Feb 15, 2006 10:17 pm
Very cool! :aviator:
One thing tho, it looks like someone jacked it up on the boot floor support :-?
Postby Ghost on Wed Feb 15, 2006 11:03 pm
sweet as! :Q
Ghost
Postby Whitty_696 on Thu Feb 16, 2006 12:59 am
looks really really sweet m8. 8) 8) 8) 8)
R.I.P ROB GONE BUT NEVER FORGOTTEN
Whitty_696
Postby chris-fiesta on Thu Feb 16, 2006 10:40 am
best pic
loads of colours going on... gotta say at first i thought that powder coating the rear beam was a bit pointless but gotta say does look sweet now that its on :Q
chris-fiesta
Postby ianFRST on Thu Feb 16, 2006 11:34 am
cheers for the replies :D :Q
sphinx - yeah, that was me :oops: that would be the spare wheel that has made that dent, it was the only place i could jack the rear end up, when it had no rear beam, and i had to shift it, so sadly, it did that. its not dented the actual floor, just that piece of metal you can see :lol: :oops:
chris - cheers dude :Q you can actually see more than i thought you would of the beam. maybe just because its blue and not the usual black it stands out a bit more :-? :lol:
ianFRST
Postby chris-fiesta on Thu Feb 16, 2006 11:45 am
probably, but still definately worth it.... now get off the net and get crackin on :lol: :lol: :lol:
chris-fiesta
Postby ianFRST on Thu Feb 16, 2006 12:21 pm
got the flu mate :( think i made it worse by working on it yesterday :oops: staying in bed today :lol:
ianFRST
Postby chris-fiesta on Thu Feb 16, 2006 12:54 pm
:lol: :lol:
same happened to me when i fitted the cossie brakes in the snow :lol: had to get the car back on the road asap for work then ended up being off cos of the flu!!
dint make sense :lol:
chris-fiesta
Postby ianFRST on Mon Feb 20, 2006 6:25 pm
got my exhaust manifold adapter plate in the post this morning. very well made. really heavy, got be easily 5kg in weight :o must thank interpro for that, the ONLY place i could find one. £85+ vat :o
ianFRST
Postby rich_frst on Mon Feb 20, 2006 8:15 pm
looking good ian!!!! :D
My ProjectS..
rich
07834862431
rich_frst
