dangerousdaves zt!! the end!
Re: xr2i 2.0L budget ZT 1/12 getting there now! :)
Postby richie baby on Wed Dec 02, 2009 8:24 pm
if he has it u can have my pace cooler and spare rad fan, or u can have to on :Q :Q :Q
richie baby
Postby dangerousdave on Wed Dec 02, 2009 8:33 pm
yeah i could make a bracket to fit 2 on!! :) :Q :Q :Q or you keep it and ill have your 2 new ones!! :lol: :lol: :lol:
dangerousdave
Postby richie baby on Wed Dec 02, 2009 8:38 pm
yeah i might poke myself in my eye with a blunt nail :P
richie baby
Postby gary_xr2i on Wed Dec 02, 2009 11:18 pm
dave dont your gauges have 3 wires coming out, red , black , orange then the + , - , s
red wire is for 12v
black earth
orange ( i think is a dimmer)
im trying get my diagram for you its in my mates car.
gary_xr2i
Postby dangerousdave on Wed Dec 02, 2009 11:25 pm
yeah i wire the 3 for the lights to my radio wiring as the sysem is fused, close to my gauges and im lazy! lol!! then i have the 3 "studded pillars" that are marked up S, +, and - positive and negative can go with the lights and s to the sender does that sound right??
dangerousdave
Postby gary_xr2i on Wed Dec 02, 2009 11:26 pm
pmd you this time :)
gary_xr2i
Postby - Danny Boy - on Thu Dec 03, 2009 11:05 pm
Now that is tiiiiiiiiiight lol :D Slowly getting there now!!!
- Danny Boy -
Your car: Fiesta Si 2.0
Postby gary_xr2i on Thu Dec 03, 2009 11:12 pm
dangerousdave :yeah i wire the 3 for the lights to my radio wiring as the sysem is fused, close to my gauges and im lazy! lol!! then i have the 3 "studded pillars" that are marked up S, +, and - positive and negative can go with the lights and s to the sender does that sound right??
i wont get the diagram till monday now :(
gary_xr2i
Postby dangerousdave on Thu Dec 03, 2009 11:18 pm
- Danny Boy - :Now that is tiiiiiiiiiight lol :D Slowly getting there now!!!
:) :) lol if i had some welding gear id attempt making loadsa bits to make it better simalar to how luka and crazy cage have there bays but maybe on the next incarnation!! lol :P
gary_xr2i :
no problem pal i think i have it sussed now, im just awaiting my oil feed pipe then i can test it!! :) :)
got a bit more to do over the next few days but mostly my shoddy wiring as i cant afford to build a loom from scratch as i would like too and when i can it will be for a better ecu! :D
dangerousdave
Postby gary_xr2i on Thu Dec 03, 2009 11:47 pm
dangerousdave :
gary_xr2i :
let me no how it goes :)
gary_xr2i
Postby dangerousdave on Sun Dec 06, 2009 6:25 pm
managed to get the water pipes in today and all conected up, started to think about the way its originally piped up and how im doing it now..... lol didnt look as if water could flow anywhere as the thermostat is the first thing it comes to from the top rad hose, but upon filling with water it cimes out the front pipe, which is for the heater matrix on mine now!, i just started thinking i needed the pipe from the pump to there for some reason but as water seems to pass it will be fine!!
exept the fudgekin housing face was leaking so i tightrned it up as tight as i could and ended up cracking the plasic cover in half!! :rolleyes: :rolleyes: :lol: :lol: :lol: :lol: so need to get another one now along with some liquid gasket ( after peeling off the one that was on it and saying what kind of a stupid dick uses that stuff!! :P )
sorted out the alternator wiring now so those that are interested in using a mondeo alternator for there 2.0 L
ether cut the multi plug off and connect both red wires to the connection with the rounded plastic walls round it or run one wire from here to the starter motor and the blue wire to the other with the square ones round it
there are labled B+ and D+ iirc but i forgot which were which by the time i got back, lol
well heers a pic to understand better!
and as i left her after i was a little annoyed for splitting the bloody therostat housing!! ignore the waterrail its none functional!! and the painted parts have only had 1 coat as its just to tidy it a little from the horrid green colour it all once was!!
dangerousdave
Postby Hilton HS2 on Mon Dec 07, 2009 6:09 am
mmmm dr pepper.
Hilton HS2
Postby dangerousdave on Mon Dec 07, 2009 10:17 am
mmmmm i know! :P only there so i dont loose the pipes! lol doubt ill start it up like that!!?
dangerousdave
Postby Hilton HS2 on Mon Dec 07, 2009 12:07 pm
Dont know mate. I'd keep it there probably adds some ponies :lol:
Hilton HS2
Postby Ruishy1 on Mon Dec 07, 2009 7:59 pm
Slowly but surely your getting there mate.
Nice :)
Ruishy1
Postby gary_xr2i on Mon Dec 07, 2009 10:55 pm
As said not sure if you still need these and not sure weather to post them up in the guids?? some are diffrent models and not all the same but gives a good idea :)
gary_xr2i
Postby dangerousdave on Mon Dec 07, 2009 10:59 pm
Ruishy1 :Slowly but surely your getting there mate.
Nice :)
yeah mate still not managed to find work since coming back to the uk! :( but ill here it ticking over in the next couple of weeks! then i can turn it around and drop the axel for a lick of paint get the tank out ready for a new pump and clean and paint the underside too!! :) :)
gary_xr2i :As said not sure if you still need these and not sure weather to post them up in the guids?? some are diffrent models and not all the same but gives a good idea :)
nice one buddy, thats how i have them now! :) cheers!! :D
dangerousdave
Postby gary_xr2i on Mon Dec 07, 2009 11:03 pm
no probs :)
gary_xr2i
Re: xr2i 2.0L budget ZT 11-12 SHE RUNS :)
Postby dangerousdave on Fri Dec 11, 2009 5:17 pm
SHE RUNS!ha ha ha well sort of!! she idles at around 3-4k!! sounds sweet tho!! lol
but that was without the turbo piped up and the TB was exposed, doubt would that make a diffence tho??
i gotta try and understand how this ISCV works as theres no pipe on the outside of it! ... anyone know how the 1800 zetec fiesta ones work?
well when its light tomorrow ill try unplugging it when its running to see if its that as it could be down to the TPS as im using the zetec TB thats been modified to work with the throttle cable from cvh! :)
dangerousdave
Postby richie baby on Fri Dec 11, 2009 6:09 pm
well done dave, but remember crank sensor :)
at least urs runs a :( :-? :cry: :cry: :cry: :cry: :cry: :cry: ,
richie baby
Postby dangerousdave on Fri Dec 11, 2009 6:51 pm
richie baby :well done dave, but remember crank sensor :)
well it does but you still got the coil pack!!, i think you should get the red xr2i from work unless gary ruined the roof :D :D :D
she runs tho buddy even if i have to make something for the frst throttle body to fit to! :( lol
dangerousdave
Postby gary_xr2i on Sun Dec 13, 2009 11:51 pm
YAY welll done mate :D bet your well happy :D
gary_xr2i
Postby dangerousdave on Mon Dec 14, 2009 11:06 am
yeah mate, need to plug my rst throttle body on and see if it still revs high on tick over as pulling the iscv off didnt do much! so job for later or tomorrow then if it works il be making up a mounting plate for the throttle body :)
dangerousdave
Postby black2 on Mon Dec 14, 2009 2:16 pm
Good news Dave.
I wonder if its down to the zetec TPS then, as to why its ideling high? Have you got all the vacume take offs on the manifolds connected up?
IIRC theres two on the back of the inlet and then one down low on the sandwhich plate, kind of behind the cam cover breather outlet.
Other than this issue though its all ok?
I will be torqueing the head down on mine soon as I have the decomplate and head gaskets now. When you done yours did you fit one gasket over the block then fit the decomp plate then the other gasket on top of that, so the decomp is sandwhiched between the two??
Cheers buddy,
Gareth.
black2
Postby dangerousdave on Mon Dec 14, 2009 6:41 pm
black2 :Good news Dave.
Cheers buddy,
Gareth.
yeah mate, thats what im thinking! they do sit at a difrent angle when i was looking at it compared to my frst one!? hope thats it as its an easy fix :P havent been to it today ill be going in the morning! if i plug my frst one in and it idles lower ill make a plate up ( or 2! :) )
yeah i placed the decomp plate between the 2 focus rs gaskets buddy, also bought new head dowls as they were only £1.22 iirc :)
dangerousdave
Postby black2 on Mon Dec 14, 2009 10:19 pm
When you say plug in the FRST one, do you mean the TPS or fit the whole FRST TB? If it is down to this them im going to have the same problem :( but if you cure it with knocking up an adapter to fit Im more than willing to give you some coin to cover making an extra one up??
I also bought some new dowls as well, seeing how cheap they were. Im hoping to get some more done soon, as I finish work for the xmas break next week so should have some updates. Ive not done anything on it for such a long time now lol.
Gareth.
black2
Postby dangerousdave on Mon Dec 14, 2009 10:43 pm
ill make an adaptor hopefully, it depends on how close the holes are to if i can bolt a plate to the inlet and how big the hole on the inlet is to wherter it can be moved one way 5mm to avoid the holes hitting!!?? maybe rotating it a few degrees will be ok only the linkage will look on the piss but it would still function!!... ill need to look at them both and draw them up, or get hold a gasket for them both :D
if i can draw it up to work ill gladly knock 2 up i can clamp thrm together and make 2 at the same time with any luck! :)
dangerousdave
Re: xr2i 2.0L budget ZT AAaaaggghhhhhhh
Postby dangerousdave on Tue Dec 15, 2009 2:37 pm
AAaaaaggghhhh, god dam fudgekin thing is going to be running a 2i setup soon!!
tried the frst TB and it still idles through the roof then i unplug the iscv and it revs up and down from 900-4000 ish so does anyone know how the zetec iscv works? theres no external air bypass on it like the fiesta one!?, ....
id be gratefull for any help or oppinions :)
dangerousdave
Postby black2 on Wed Dec 16, 2009 11:16 pm
Sounds odd to me mate?
Maybe the remote iscv would work ok? thats what i intend on using. Just need to make a take off for the iscv in the rear of the manifold looks easy enough, i got the idea off of a chap on xrtwo.com
Also you sure 100% theres no air leaks around the manifold which could contribute to this problem?
Oh also, your old T2 turbo that you were going to use..... is it in good condition ie no smoke etc? Do you intend on using it again? If not would you want to sell?
Gareth.
black2
Postby dangerousdave on Wed Dec 16, 2009 11:30 pm
not sure mate, the only pos place it could be leaking is the brake servo pipe as the plastic push fit connecter has a chip in it but ill try blocking it off on saturday morning! or ill try and replace the fitting? :)
not to sure what im doing with the t2 just yet as i had it fully reconed with 360 berings ect it has no play at all but this t3 is shagged!! :( so dunno wether to make it fit on the t3 manifold or to sell and rebuild the t3, or to mock up with the t3 and buy one of them 150quid t3/t4 ones from ebay?? :-?
dangerousdave
Postby black2 on Sun Dec 20, 2009 10:47 pm
Ok mate, any updates for us?
Gareth.
black2
Postby dangerousdave on Sun Dec 20, 2009 11:39 pm
nah mate! think i may wait and get a meggasquirt ecu in the new year!! :) wanna buy the turbo? cant really sell for noting tho to be honest cost me well over 200 quid so far!! :(
not sure wether to knock up an adaptor to fit the frst inlet onto the zetec head and use all the original sensors except the water temp!!!??
how you doing yours?
i can see me doing a full on build over the next year again!! might rip the ecu etc out run it 2l n/a and build one up in the shed!! :D
dangerousdave
Postby black2 on Mon Dec 21, 2009 2:49 pm
Stick with it chap.
Knock up the adapter (x2 :D ) so you can fit the frst TB and try that, I' ll purchase the other one off you as well. Ive seen zetec turbos run with ofac/ofab and use the zetec inlet just with the FRST TB, so there should be no problem just a thought but is your iscv knackered? Try using another one.
Mine is still no further on, looking to get a bit done over the festive break though, should be able to get the head on and engine timed up. Ive got an ofac ecu and map sensor now as well so im getting there with the bits.
Gareth.
black2
Postby dangerousdave on Mon Dec 21, 2009 2:56 pm
not sure if its cuz the iscv is just crap or its totally wrong design? it doesnt bypass air like the frst one does! im thinking of making the whole inlet fit now like heeman did on his zetec turbo!?
dangerousdave
Postby black2 on Mon Dec 21, 2009 3:09 pm
black2
