- Smo
hb69 :Smo :Come on Clark, you can get it fixed in time!
we have faith
And he has a yellow coat... He can't lose!
- Smo
The drivers side front wheel bearing collapsed while i was driving. The brake disc is badly scored from the carrier.
Stripped down the hub to find this
Split the cv boot as well
Thats what was left of the inner wheel bearing. mullered
- knuckles
- Your car: Fiesta Rs turbo
Ready and waiting
New hub on the left from Ford Co,
And my miracle worker - Tony fitting my new cv boot.
Im down but not out !
- knuckles
- Smo
- Smo
Even had time to change over the discs and pads on the French Rs.
I was very shocked to see that the foreign car has litterally no rust on it. Just loads of french mud
- knuckles
- MAD_Adamski
Jammy sod it went the day before ford fair, like ad says they normally happen on the bloody way...... that reminds me *re-new AA cover*
Glad you got it sorted though
- Brammer
- Your car: Sierra Cosworth
Thanks everyone
Passenger front bearing needs doing now by the sounds of things
I couldnt of got it sorted in time without tony, what a life saver. What took the mick was when we finished working on my car, tonys alternator packed stopped working.
It hopefully will work till next wednesday, battery light comes on dim when idle and the read out is roughly 12.5 volts from battery
We havent had time to polish our cars so we will need to do that at ford fair
- knuckles
adamski frst ::o exactly what happened to mine on the way to FF last yearthats why i wasn't there last year 2 miles to silverstone and the bearing exploded
same thing happened to me on the way to ford fair 2 years ago, curse of ford fair me thinks!
- xrsi
- XR(ustyAtTheMo)SI
Trip to torque exhausts - Take 2
Up on the ramps being inspected
This is what the London speed bumps do to your exhaust if you lower your car too much
The flexy section started to sag due to not having a mount by the gear linkage.
The flexy section as it used to be
This was the end result - cut out old section, weld in new shorter and stiffer flexy section, followed with joiner pipe. He then welded on a new mount just in front of the flexy so i could mount the exhaust properly.
My leaky oil filter has done a number underneath the car. I replaced the filter 2 weeks ago because it leaks underneath and its still doing it slightly.....
Got the passenger wheel bearing renewed as well. its like driving a new car .
Thats all folks
Thats all folks
- knuckles
- j7aoc
Good stuff mate, i finally saw the recaro fiesta face to face on Sunday and it looks
as i was looking at the rims i couldn't help but notice 2 rather green strips sitting on the back seat, Get them fitted mate
Great car Clark and the work you've done in such a short space of time is incredible, considering you bought her as a rolling shell, give yourself a pat on the back, and the lads that helped you
- Brammer
did look good though
black wheels looked ok but shhhhh, dont tell clark
h196jne :Good stuff mate, i finally saw the recaro fiesta face to face on Sunday and it looksas i was looking at the rims i couldn't help but notice 2 rather green strips sitting on the back seat, Get them fitted mate
i was just thinking the same thing, it was definately one of my favourite cars on the ft stand at ford fair. well done indeed
- hb69
- Your car: Fiesta 1.1 LX
Thank you very much kind sir
Its come a long way in such a short space of time. Greens will go back on when i manage to straighten out those door stripes. May have to find some others...
Im in 2 minds about which set of wheels - may have to keep switching between std and the mondys
Henry -
Jay -
- knuckles
E4Fiesta :Nice work man!
Where abouts did you take it to get sorted, always good to know a trustworthy local garage!??
http://www.torque-exhausts.com/index.htm
I drove down the m25 after having the exhaust done and i saw blue smoke coming in via the heating vents. pulled over and smelt burning plastic.
Got back down to torque exhausts and the guy said its just the excess silicone burning off. They use that to seal the joins. I thought my car was on fire
- knuckles
