Re: Diary of "JPH" 2.1 ZT ( in primer 24/4/10)
looking good rod
what sealer you going to use?
- andymcd
Fantastic work!
- Sphinx
- FRSJON
Splendid!
What brand of etch do you use, mate?
This project is fantastic, you have put so much work into this, its going to be a top car when its finished!
- - Danny Boy -
- Your car: Fiesta Si 2.0
Well its time for a catch up
things have been a bit slow lately due to loosing my enthusiam
but starting to get it back again
after selling quite alot of parts recently to get my funds level back up
mainly things that are no good to me, after my change of plans on a few things
as basically this car wont look the same as before,
more factory looking with subtle touches
firstly my new black samco hoses for the mk3 fiesta with zetec engine
(the kits only been released a few months ago after all these years)
spark lead clip, new washer jets, clips to hold the wiring in the boot, and tailgate grommet
brand new hubs to go with the knuckles i have'nt picked up from the powder coaters yet
new rear license plate lamp on the left, compared to the old yellow on the right
the metal shim that goes between the block and gearbox, no longer available new
so straightened mine up, sanded back to bare metal as it was a little scabby
etch primer and few coats of satin black, JOB DONE
also the panel gap below the rear light i've had lead filled, so basically its slightly flexable and wont crack
heres how the shell is looking
basically seam sealer is being put on only where its needed and nowhere near as thick as it comes from factory
recently while in the london area, i went to see chris todd @ torque of the devil
about mapping, wiring and management
very happy to leave the car with them in the near future
- RS rob
Re: Diary of "JPH" 2.1 ZT ( updated 22/5/10)
if this car makes any creaks or crones when its rebuilt i for one will be shocked lol, should drive like new
i didnt see you at fitp mate only your zetec s
coming along again, loving them black cars
- RS rob
Got a spec or a project thread for it anywhere ?
Looks very nice
Scott
- sjoyce666
hoses look the don mate, where did you get them from? i want to get some on order today before the mrs finds out
as you cant buy them direct from samco?
- fiestasiphil
Hoses look wicked some look different to the roose kits?
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
aye im wanting some of them samcos too, look tidy, need to save the pennies for a bit first thou
- FRSJON
- knuckles
- Your car: Fiesta Rs turbo
- FRSJON
some updates later tonight if i have time,
been some good progress, just not had the time or patience to sit down and type it out
- RS rob
nice one
i know what you mean,been sorting loads in my engine bay but too busy to sort pics
soon though
- FRSJON
in the engine bay i've decided to move the ecu and its wiring
so the factory hole is useless
so it was welded up, grinded back, then a some filler over the top
also had the last few holes welded up which hold the factory fuel filter and abs on other models of this car aswell
after being sanded back
and in primer
inside of the arch was smoothed aswell
to reseal the car back up i've been using a fords sealant,
from inside the shell, under the bulkhead you can see the plate welded over the location for the factory ecu
aswell as the sealant i've been putting in the panel gaps
i've sealed up the same places as done originally, except i've not putting it on so thickly
just making sure it's pushed into the gap and looks neat
and in primer
- RS rob
your such an inspiriation, and goes to show, even if a shell is so rusted up you can just take it back to bare shell like you have and replace the rusted panels like sills wings even more structural places
i know yours werent rusted up badly but goes to show what you can do when its stripped back to the shell
keep at it mate it will be all worth it at the end
wish i cud do this to mine
- Xr_Dub
well next up was more sealant,
just applied a different way,
the mk3 fiesta was known for water leaks mainly on the front bulkhead,
so with this in mind i'm making sure cover all the seams well as i dont want a leak when its all built up
the choice of sealant,
how i'm going to apply it with an airline
a test section on some cardboard using masking tape for edges
test section with the masking tape removed, happy days!!
the important bits were masked around the bulkhead and sprayed with sealant
a close up after the masking tape was taken off
how it looks now, much better coverage of sealant without looking messy
- RS rob
well the sideskirts that were fitted previously catched the bottom of the doors and rubbed the paint off
so that being done 3/4 years ago i have a little surface rust starting
so that needed to be sorted
stripped both doors down completely
while i was there, i had to see the how bad the rust was,
thankfully with a small d/a it showed clean metal behind, so that was a big relief ! !
next was a test fit of the panels, any adjustments made before the car is ready for paint
so doors were fitted first to line up from the quarters,
while i'm catching up i'll show a picture from weeks ago, i did'nt post up because it would show my newest idea,
but while the front chassis was bare, it was the perfect time to get some paint on before the wings go on
as you dont get much access when the wings are on
it seems the last it was at the other bodyshop washers were used and parts of the hinge grinded away to allow the door to sit higher
so rather than replacing the hinges which seemed fine apart from the washers,
we used new washers and welded them on, so would look a better job
then with the belt sander the welding was tidied up
so with the doors on properly, the wings and bonnet were test fitted
so with the wings in the perfect place, the metal was prepped for spot welding
- RS rob
then spot welded on by a pro, its a lump of a machine
heres the wing after spot welding
then where the front valance meets the wing was welded
while we were test fitting, the skirts and arches were trimmed to fit nicely
aswell as being trimmed for my big wheels
also the wings were trimmed back to make more room for the 8"wide cossie wheels aswell
- RS rob
had some more parts back from the powder coaters
front hubs, another front engine mount and the back plates for the rs2000 rear disc/drum setup
recently tried cleaning up the brake bar which runs along the rear of the engine bay,
after lots of scrubbing it was'nt getting any better, so it was a choice of having it recoated, or a new one
so bought a new one along with new bushes and springs
some bump stops for the bonnet, screws for the bonnet hinges and bonnet
also nuts for the front and rear bumpers
new upper and lower steering cowl's
new plugs for the floor
new seal which holds the rear glass in the tailgate
new washer bottle
two new door seals and tailgate seal
new washer bottle
- RS rob
its definately coming along rob
good to see the shell getting close to paint,then its the nice part of bolting on all your fresh parts. love it
- FRSJON
new door hinge bolts and clips
one of the new door strikers aswell
got hold of an RS accessory part i've not seen before,
its a light dimmer relay basically rather than the on/off switch
also another accessory, the credit card style spare key
the panels under the rear lights which were lead filled,
have been finished off with a skim of filler
before
after sanding
before
after sanding
- RS rob
jonyb4 :your such an inspiriation, and goes to show, even if a shell is so rusted up you can just take it back to bare shell like you have and replace the rusted panels like sills wings even more structural places
Xr_Dub :wish i cud do this to mine
FRSJON :its definately coming along robgood to see the shell getting close to paint,then its the nice part of bolting on all your fresh parts. love it
thanks lads, really is flying along at the moment
cant wait until it all starts coming together now
- RS rob
Re: Diary of "JPH" 2.1 ZT ( updated 16/6/10)
Absolutely amazing work going into your car, really do love it. It's nice to see a project like this on here - Not many get the attention to detail that you're giving yours!
- Smo
Superb mate
- RS rob
- RS rob
mr wolz pressed my new bearings and hubs into the freshly powder coated knuckles
big thanks again
i'm proper chuffed with the outcome
also my new coilovers arrived from GAZ
the difference of these compared to the avo's i had before is massive,
the welds are really neat, two adjusters plates to lock the springs in place rather than one with a plastic screw
big thanks again
- RS rob
Re: Diary of "JPH" 2.1 ZT ( updated paint + more 18/6/10)
Great progress Rob looks mint cant wait to see it coming together now
- mrorange2
brilliant!
wow them new hubs/knuckles look brill, this car should make a creak or clonk when driving at all now, all these new parts it really will be like it was bought from the showroom the day before!
im so envyous
im so envyous
