My 1990 Pop Plus
Re: My 1990 Pop Plus
Postby Christina on Tue Feb 18, 2014 8:41 pm
I'm freakishly tall, 6'3 D: And most of it is leg so annoying.
Christina
Your car: '90 Fiesta Popular Plus Mk3
Postby Christina on Tue Feb 18, 2014 11:36 pm
Swapped some of my spare Mk1 parts for a set of pepperpots :D
Christina
Postby Gus!! on Wed Feb 19, 2014 12:41 am
Xr2 pots?? Goody good!! :)
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Postby Smo on Wed Feb 19, 2014 12:43 am
Hmmmm!
I'd have gone with 8v XR2i alloys, personally!
Smo
Postby Gus!! on Wed Feb 19, 2014 12:45 am
Don't be talking about my pepperpots :lol:
Only trouble I can find is the tyres are a weird size!! :(
Gus!!
Postby Christina on Wed Feb 19, 2014 12:50 am
I pretty much got them for free so I'm not really complaining. Most of all I want a set of RS4 spokes or even to get the standard steels banded, I really like how they look with the centre caps :O
Christina
Postby Smo on Wed Feb 19, 2014 1:05 am
Gus!! :Don't be talking about my pepperpots :lol:
They should be 185/60/13 on those. Not particularly unusual, but I guess rarer for the likes of more modern small hatchbacks!
I think RS four spokes have more character and would probably work better depending on the look you're going for, but banded standard steels would be the best option :)
Smo
Postby Gus!! on Wed Feb 19, 2014 1:14 am
I'd love Capri pots with 175/50/13's but I haven't got the money!! I just bought some 185/60/13's for mine but they could only find a few companies that still make them!!
Gus!!
Postby Christina on Wed Feb 19, 2014 1:21 am
I would like banded steels but not paying £50 a corner plus the extra tyres I'd need. I could get the RS4s with good tyres on for less.
Christina
Postby Gus!! on Thu Feb 20, 2014 3:25 am
Banded steels are something I'd look into, I know a few people will do 4 for about £150 I think!! Need a low car for that though!! :bonkers:
Gus!!
Postby Christina on Thu Feb 20, 2014 9:34 am
I was thinking it would probably be easier and cheaper to just swap the centres into wider rims. I'd trust them more I think.
Christina
Postby Christina on Thu Feb 20, 2014 12:47 pm
I actually bought 2 but the fools only sent one out...
Christina
Postby Smo on Thu Feb 20, 2014 12:48 pm
What make is that?
Smo
Postby Christina on Thu Feb 20, 2014 1:14 pm
Otto mobile, it's resin. I've got a few of theirs, XR2 mk2, Sierra Sapphire cosworth, Escort cosworth, and got the Focus RS on the way.
Christina
Postby Christina on Sun Feb 23, 2014 5:53 pm
Getting a set of escort GTI wheels freshly powdercoated from my uncle for £100 :D
Christina
Postby Gus!! on Mon Feb 24, 2014 2:23 am
Not too keen on gti wheels, you will need to lower it if you put them on or it'll look like a monster truck, however, it'd cost you £100 to get them powdercoatsd so you might as well do it!!
Gus!!
Postby Christina on Mon Feb 24, 2014 9:58 am
Lowering is definitely on the to-do list. I can't pass up on these wheels though as they're among my favourites. They were on his Mk5 Cortina so I'm not sure what tyres are on them. I hope they fit! :P
Christina
Postby Christina on Wed Feb 26, 2014 8:09 pm
Got a rev counter on the way! :D was pretty hard to find one from an HCS car. Also the steering wheel hasn't turned up as of yet, opened up a case on ebay so we'll see how that goes.
Christina
Postby Gus!! on Thu Feb 27, 2014 12:44 am
How long have you been waiting for them?? I have been screwed over on ebay before!! Its irritating!!
Gus!!
Postby Smo on Thu Feb 27, 2014 12:47 am
You'll probably have to pass a wire through from your 6-pin car/engine loom connector at the back of the engine bay through to where your instrument cluster is. Your engine loom will have a green wire to its connector and then nothing on the car loom side. This was one of the first 'mods' I ever did :D Takes Mr back :lol:
Smo
Postby Christina on Thu Feb 27, 2014 12:55 pm
2nd pin from the left on the ESC right? I knew there'd be some wiring involved so that's no problem. :P
Christina
Postby Smo on Thu Feb 27, 2014 1:18 pm
You can take it from the ESC module, but through the 6 pin connector is where it comes through when fitted at factory :)
Smo
Postby Christina on Thu Feb 27, 2014 1:36 pm
http://www.fiestaguides.co.uk/content/r ... o_sup.html I've been looking through this guide, but he doesn't actually show where he solders the wire.
Christina
Postby Christina on Thu Feb 27, 2014 3:54 pm
How to quickly increase car value!
Christina
Postby Fiesta Mk1 on Thu Feb 27, 2014 6:03 pm
"just changing engine maps" :Q
Fiesta Mk1
Your car: Fiesta mk1 x4
Postby Christina on Thu Feb 27, 2014 6:43 pm
Okay it seems the leak is really tiny and is coming down the inside just infront of the door. I couldn't get even more than a tiny drip to show up though. I poured plenty of water over it. So it most likely is the scuttle panel/a pillar join.
Christina
Postby hb69 on Thu Feb 27, 2014 7:38 pm
Have you checked the bulkhead? Right up behind the pedals?
hb69
Your car: Fiesta 1.1 LX
Postby Christina on Thu Feb 27, 2014 8:10 pm
There's not a single drop of water on the driver's side, and no water on the inside of the bulkhead, just the floor on the passenger side and it seems to drip down the panel the door bolts on to.
Christina
Postby Fiesta Mk1 on Fri Feb 28, 2014 12:27 am
theres gotta be a hole letting in more than a tiny drip because the passenger footwell is soaked :o
almost as bad as the mk3 escort lol
Fiesta Mk1
Postby Christina on Fri Feb 28, 2014 12:35 am
I kept pouring kettle loads of water over it, all I got was a tiny drip. Only thing I can think to do next is take the dash out. But first I need to buy a set of torx bits.
Christina
Postby russ-RST on Fri Feb 28, 2014 7:55 am
You shouldn't have to hard wire in a rev counter for your clocks Iv never had to on either my 1.3 or RST and iv used a multitude of different clocks :lol: I like the look of this will be watching the progress closely
+1 on the tall driver front I'm 6'4 and it is a little squeeze :lol: do get some funny looks when you step out and my knees hurt after too long a drive
Russ
russ-RST
Your car: fiesta rs turbo
Postby Fiesta Mk1 on Fri Feb 28, 2014 8:18 am
im also 6ft 4 and i have to say, for me its easier to get behind the wheel of a mk1 fiesta than a mk3 :-?
Fiesta Mk1
Postby Christina on Fri Feb 28, 2014 1:15 pm
russ-RST :You shouldn't have to hard wire in a rev counter for your clocks Iv never had to on either my 1.3 or RST and iv used a multitude of different clocks :lol: I like the look of this will be watching the progress closely
Russ
I believe it depends on if the wire is actually there inside the car or not, some cars have a missing wire in the multi plug that connects to the clocks themselves.
Woop!
Christina
Postby Christina on Fri Feb 28, 2014 2:34 pm
Yep as expected, my car is missing the wire that goes from Pin 10 on the clocks multiplug.
Christina
Postby Smo on Fri Feb 28, 2014 3:55 pm
Things are totally different on the MK3.5, most MK3s didn't have the wire unless they were fitted with a rev counter from factory :)
Smo
