Re: MWSTEWART | Si project | Will 205/40/16 work?
Ha. I'm not sure I want it in a magazine. I've never really been a fan of the Ford ones. Sorry I never answered your question, the spacers were from Ford, £20 ish complete with bolts. They go for around £11 second hand. Bargain really given the benefits.
are the spacers roughly 12mm each then?
if so i am buying some!
do you happen to have a part number for them, would help alot, but they just go straight on the mk3 hubs?
thanks though!
thanks though!
Excursion :Ha. I'm not sure I want it in a magazine. I've never really been a fan of the Ford ones. Sorry I never answered your question, the spacers were from Ford, £20 ish complete with bolts. They go for around £11 second hand. Bargain really given the benefits.
i went to burtons today to buy hub centric 12mm spacers !
please dont tell me ford do these for less
finis number please mark
- knuckles
- Your car: Fiesta Rs turbo
knuckles :Excursion :Ha. I'm not sure I want it in a magazine. I've never really been a fan of the Ford ones. Sorry I never answered your question, the spacers were from Ford, £20 ish complete with bolts. They go for around £11 second hand. Bargain really given the benefits.
please dont tell me ford do these for less![]()
clark check out the axel spacers on the sport and street ka,
i think thats the ones mark is on about,
all the mk5 and 6 fiesta boys have them
i had 20.5mm ones for my mk6
did'nt think they'd fit a mk3 hub though?!?!?
- RS rob
Ahh, yeah, I've got a ZS beam on this. The ford spacers unfortunately only fit the beams on a mk4 and later.
fiend :Are you going to be using the standard inlet cam?
Inlet yes, exhaust no.
Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
I remembered seeing the spacers couple of years ago when working on a sport ka but never got around to getting any, and still to this day I have wanted some
Luckily I never got them as I didnt know they wouldn't fit!
I think I will get some made up, which wont be hard at all really, might even do it myself in a workshop, just need the PCD of the hub bolts which I can find out from the internet somewhere I'm sure
- - Danny Boy -
- Your car: Fiesta Si 2.0
- Danny Boy - :Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
I remembered seeing the spacers couple of years ago when working on a sport ka but never got around to getting any, and still to this day I have wanted someLuckily I never got them as I didnt know they wouldn't fit!
The rear hub bolt pattern is different. It's pretty easy to make them, though
i know the measurements needed, pm you want them or catch me on msn danny
im sure the mk4 onwards ones can be filed to accept the mk3 beam, some do it with the focus rear discs
jonyb4 :i know the measurements needed, pm you want them or catch me on msn danny
You cannot file the Ford spacers.
Excursion :- Danny Boy - :Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
Yeah I can see they are now, just looked on microcat to check! I'll get some made up then
- - Danny Boy -
- Danny Boy - :Excursion :- Danny Boy - :Any reasons as to why they do not work on MK3 rear beams? PCD difference I presume?
i told you that a while ago you donut
Excursion :Ahh, yeah, I've got a ZS beam on this. The ford spacers unfortunately only fit the beams on a mk4 and later.
does the mk5 rear beam fit straight onto a mk3 then ?
but you lose a rear anti roll bar when you go over to mk5 rear beam
- knuckles
knuckles :Excursion :Ahh, yeah, I've got a ZS beam on this. The ford spacers unfortunately only fit the beams on a mk4 and later.
I think ive read or heard the ZS rear beam is better than a mk3 beam with an ARB.
- Ratspeed
Yes mate the ZS rear beam goes straight on, and is superior mate by a long way. It's 1.2mm thicker steel than the mk3 beam, and the void bushes are stronger.
The Mk5 beam is an upgrade over the FRST one, and the ZS beam is 20% stiffer still
Cant believe people still don't get the ZS beam thing, I've been saying for 4years or so that it was the best thing I did to my white one!
The ARB on an FRST isn't an ARB at all, its a strengthening bar.
Max M4X WW :Cant believe people still don't get the ZS beam thing, I've been saying for 4years or so that it was the best thing I did to my white one!
Mate I told everyone about it when the Mk4 had the phase 2 back in 99
Excursion :Max M4X WW :Cant believe people still don't get the ZS beam thing, I've been saying for 4years or so that it was the best thing I did to my white one!
nice to know
on ecat there is only one axel listed for mk4/mk5 fiesta .
am i right in thinking that they are all the same then ?
if thats the case i may take a trip up a scrappy soon
cheers mark
- knuckles
There are two types deffo.
Yea wasn't saying I was the first mark, Just that I did it and no one else was
Max M4X WW :There are two types deffo.
care to elaberate on the two types ?
std beam
Zs beam ?
- knuckles
knuckles :Max M4X WW :There are two types deffo.
care to elaberate on the two types ?![]()
std beam
Zs beam ?
Correct mate.
Excursion :knuckles :Max M4X WW :There are two types deffo.
std beam
Zs beam ?
Correct mate.
not quite
earlier puma's and mk4 fiestas pre 98 i believe had a fork type mounted shock and the beam wasn't as thick, then they made the eye mounted shock beam which was stiffer, then the 1.7 puma and zetec s one was even stronger again
i know from owning a mk4, my mates puma which i worked on regularly and the fact everyone knows about the zetec s beam
apparently a twin anti roll bar mk3 beam is the equivalent to a zetec s beam
I was talking Mk4 phase 2 onwards i.e. if it's got digital dials, you're good.
The Mk3 beam with the ARB is awful - such a choppy ride. Two or three ARBs is a bodge and counter-productive. There must be flex in the right areas to make the car handle over anything other than a perfectly smooth surface
aye, wel all im saying is the twin arb stiffens the torsion side of the beam, effectively making it close to a Zs beam in stiffness
i could be wrong though
its no different to fitting a better/thicker arb front or back really
anyway!
any news on what tyres your gonna use?
anyway!
May as well fit a ZS beam, save messing with a Mk3 one and you get better drums too!
As this has gone onto stiffness of the rear beam now lol, another way to stiffen it up is do what Rob has done iirc, by welding metal plates into the beam itself.
But as Mark has said, you need a certain amount of flext and twist for it to be a smoother ride on roads. Now, if you are tracking it a lot perhaps, and 2nd rear ARB or stiffening up the beam by welding plates could be benaficial for less body roll, but of course this will effect other forces on the car, making it slightly less stable in other areas. Too much of a stiff rear end isn't always a good thing on a car as light as a fiesta with no weight on the rear either lol.
I think perhaps if this is going to get into a massive debate, we need to start a thread of its own, seeing as mods and admin are meant to be clamping down on this off topic talking - although this is technically on topic... But also, I dont want to fill Mark's thread with crap and debates about something like this as I wouldnt want it on my thread
- - Danny Boy -
- Danny Boy - :As this has gone onto stiffness of the rear beam now lol, another way to stiffen it up is do what Rob has done iirc, by welding metal plates into the beam itself.
Welding plates in doesn't get around the fact the mk3 beam is weak around the suspension mounting points - it was built to be cheap
yea, its basicly the same argument as to fitting strut braces, they dont allow the needed flex on bumpy/curved roads, so if you fgo up the mountains alot dont fit a rear strut brace
My point is that ford probably spent a bit more cash developing the beam for the Puma/ZS than the Mk3
not someone in a garage welding plates/adding bars
Yeah thats totally true Max.
- - Danny Boy -
Max M4X WW :My point is that ford probably spent a bit more cash developing the beam for the Puma/ZS than the Mk3not someone in a garage welding plates/adding bars
Sent you a pm max regarding beam
rather than clogging up marks thread.
- knuckles
I don't mind chaps, it's interesting discussion.
i'll let you know how my rear beam is, with the large section stitch welded
i bought it like that years ago along with my rs2000 rear drum/disc setup, it was done by the mark that had max's ZT originally
i've got rear axel spacers, and powerflex bushes everywhere except for the front rose joints,
a full corner weight setup and spring rates are the most important to me at the moment
- RS rob
Excursion :I don't mind chaps, it's interesting discussion.
if thats the case ive just found the sport series mk5 rear beam on ecat
it cost £468.86 inc vat
better get saving
- knuckles
