Re: MWSTEWART | 500+ BHP Si Project | More Fab 29/05/2011
Looking good Mark, keep it up
- - Danny Boy -
- Your car: Fiesta Si 2.0
Thanks guys
Ad, haha, I will see you on track one day
- SEG1
RS_seg :what servo is that mate?
It is from a Sport Ka. It has a 23mm MC – I’m going to see if there is a bolt on 25mm version available.
Excursion :RS_seg :what servo is that mate?
i ask as im having trouble finding one that fit in my engine bay
mondeo and escort mk3 are too big they hit the mtx mount.
the sport ka one looks like it sit closer to the bulkhead, which might work with my set up.
- SEG1
RS_seg :i ask as im having trouble finding one that fit in my engine bay![]()
It's the same situation for us all with the MTX
Digital Dial Mk4, Mk5, Puma and Ka have shortened mounting brackets to suit the MY2001 Servo upgrade.
The Sport KA uses an ATE cylinder, so I will check out some French cars for a match.
RS_seg :Excursion :RS_seg :what servo is that mate?
dont have this problem with my gearbox mount
- crazycage
Excursion :RS_seg :i ask as im having trouble finding one that fit in my engine bay![]()
It's the same situation for us all with the MTXI had a Focus ST170 servo to go on, but it's too large. In any case the Sport Ka Servo is plenty large enough for the Mk3 - all the benefit comes from a suitable MC bore size.
does the shortened mounting brackets mount up the same as the mk3? as in the four bolt holes on the bulkhead.
- SEG1
The digital dial Ka ones do for sure. I think the Fiesta ones are different.
Excursion :The digital dial Ka ones do for sure. I think the Fiesta ones are different.
by digital dial you mean electric speedo and dash right?
- SEG1
yea with the little digital display for the odo
jonyb4 :yea with the little digital display for the odo
cool i better get searching
- SEG1
very late fiesta mk4's, late mk6 escort's and all fiesta mk5's had them, even poverty spec models
Re: MWSTEWART | 500+ BHP Si Project | Front Turrets 02/06
paint just the bay or the entire car?
that be a shame to waste your personal painting efforts
how effective do you predict them reenforcements to be?
they do look a bit "weedy" compared to some other oem braces ive seen
Jon, I think my turrets look nice and friendly
Parts update.
PAS Pump bracket and water pump pulleys, Focus RS (right) and standard (left). The FRS pump is driven at a higher crank ratio than the standard pump due to a smaller diameter pulley, and the PAS bracket is required to clear the larger FRS water pump body.
New Focus RS gear cables, 'lift up reverse' collar and short-shift gear mechanism.
Focus RS cam cover heat shield, oil breather heat shield, and water rail.
I also collected the new wheels. Tyre choice is Eagle F1 195/45/16
Even though the crank driven HPAS pump fits I have decided to use an EHPAS system, because I like the idea of a)reduced parasitic drag on the engine, and b) more weight shifted to the rear of the car. The pump will be mounted in the boot along with the dry sump tank, fuel system, and battery.
Parts update.
looking good.
i was also looking into electric power steering.i was looking at the saxo/106 pump ,but it looks a bit weighty.
would have to mount it in the boot as well, you seen the space in my engine bay.
what pump is that from?
- SEG1
Pump is from a Mk3 Focus.
good stuff
- dontpannic
is that off portal 2?
- dontpannic
first time you floor it those turrents will fail and the whole front of the car will fall off.
nice wheels btw, they mean you have a massive, long 'conquering device'.
- ~nomad~
- Your car: Breadvan
Excursion :Pump is from a Mk3 Focus.
whats needed to run that? does it have its own module/ecu.
- SEG1
could try Bini Pas pump or Astra Mk4
- HCS PIMP
Thanks all.
Seg - I had a looking at wiring diagrams before choosing this and I came to the conclusion that this doesn't need an ECU. I prefer the look of this over the other pumps on the market - the engineering looks a lot more modern and I know the Focus steering is very good, so the level of assistance should be spot on and close to the Fiesta.
P.S. If you're interested the power loom is FINIS 1385923. I got one from eBay for £10 http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0630572827
If your battery is already in the boot then wiring is very straight forward; you will require a decent fused relay for the +ve feed, and the relay trigger should be from a connection that is live only when the engine is running, otherwise you risk rinsing the battery if the ignition is in position II without the engine running.
P.P.S. I would recommend a 90Amp alternator for this.
There isn't a bolt on OEM 90amp available for the Zetec Fiesta, though there may be an an after market ICE version. I converted my old Si Zetec alternator to 90amp by stripping it down and swapping across the windings from a 90amp Escort Alt that was based on the same chassis.
Bespoke front cross member to increase room ahead of the engine so that I can fit a large Intercooler and radiator.
The standard front end with a cosmetic metal valance that is exposed on lower spec models.
Behind the valance is a box section cross member made from pressed 1mm sheet:
The Si has a deep front bumper and so the valance is superfluous. I removed the valance along with the original cross member:
Removed:
The material of choice for the new crossmember is 30mm diameter, 3mm wall CDS tube. The standard cross member is on the left, and the CDS on the right:
I had the CDS bent to my spec, and fabricated some brackets at each end along with matching brackets & captive fittings on the shell:
Bolted in (I'm not yet finished: there will be four more fixings added):
For added protection against grounding I let the new cross member sit 10mm below the bottom edge of the bumper.
The result is a great deal of space (in Fiesta terms) liberated at the front end, both in terms of depth and length. I can even trim 20mm from the rear face of the bumper and still the car would look standard from the outside.
Removed:
- SEG1
Re: MWSTEWART | 500+ BHP Si Project | Cross member 04/06
That looks awesome Mark!
- - Danny Boy -
some sexual goings on here sweetie,
we should meet up some time!
- RS rob
Immense work as always mate - such attention to detail!!
Hows Ian getting on with the engine?
- SiST
