Re: Mk3.5 ST170 Turbo 4x4 (Quattro) project...Update 31/03/2008
Postby Excursion on Thu Jun 25, 2009 10:29 am
The Golf weighs an absolute ton, and I don't like the way it looks :)
Postby jayrs on Thu Jun 25, 2009 10:35 pm
i hear you on the looks mate :lol:
Postby MK3-MATT on Fri Jun 26, 2009 4:48 pm
wow just been looking at this thread. Amazing work on a huge scale! What's next? :Q
MK3-MATT
Postby Excursion on Thu Sep 03, 2009 6:57 pm
02/09/2009 | 8P0 S3 Lower Arms
I have discovered the 8P0 S3 also uses forged lower arms. I wish I'd discovered that before I commissioned a bespoke set. I must obtain a copy of the VAG parts catalogue system. The difference between the Forged arms and the Golf arms is phenomenal. I'm surprised something as heavy as the cast iron arms are fitted to anything 'sporty' built this side of the year 2000.
18/08/2009 | 1K0 R32 vs 8P0 S3 hubs
I have discovered that the 8P0 S3 uses forged Aluminium front hubs. I am going to locate a set of these and perform some weight analysis, but I suspect a potential 2Kg static weight saving per side from the hubs alone.
This is great news and these will complement the 2008> R32 rear hubs I have, which are also Forged Aluminium. I commissioned a set of Aluminium lower arms 2 months ago, and I'm still waiting for these...All in, I hope for a static weight saving of at least 5Kg per front corner on standard brakes, which is considerable.
R32
S3
01/06/2009 | R32 Shell sectioned
The shell is finally prepared after hours of measuring and careful but unpleasant cutting! I've cut the floor pan in two as the Fiesta wheelbase is 150mm shorter than the Golf. The reduction will come just after the handbrake. I will use <a href="http://www.reco-prop.com/">www.reco-prop.com</a> for prop shaft shortening, as they always seem to get good write-ups.
I took chance to briefly lay out and inspect out the wiring loom which I received with the engine, and noticed it doesn't have a CD changer fitted, and the door wiring has one less set of speaker wires than the loom that was in the damaged R32 I bought. I will need to investigate loom differences more thoroughly at some point, as I wish to retain the 10 speaker system and fit an iPod interface in place of the CD changer.
25-05-2009 | R32 Engine package acquired
2008 with only 1500 miles; everything is like new. I picked up the engine & box with all hoses and ancillaries, a complete wiring loom with ECU, ABS/ESP unit, various sensors, accelerator pedal and the air box and MAF. The loom is a credit to the person who removed it; there isn't a single cut wire!
17-05-2009 | R32 Shell cut down
After an hour spent measuring and carefully marking the shell, I continued with the rest of the dissection. The sills, scuttle, rear quarters and A pillars are now removed and yet again I was amazed by the significant weight of all the panels. Of particular note were the sills, which were just about on the limit of what I would comfortably lift.
I noticed that the majority of box sections were plugged with a plastic profile and foam in order to reduce noise in the cabin, which can be amplified in box sections. Nice touch.
I'm now left with everything I need from the R32 shell, and the relevant sections have been trimmed to a width of 1550mm to slot in between the Fiesta sills and A Pillars. The rear end will need some additional trimming once I'm ready to mount the floor pan in the Fiesta.
16-05-2009 | R32 Shell cut begins
I have taken many measurements of both the R32 and Fiesta shells, and the Golf shell will fit snugly between the Fiesta inner wings. I have started to carefully reduce the Golf shell to the areas I will use in the Fiesta.
The inner section of the Golf inner wing will remain, as will the bulkhead, but the A pillars and scuttle will be removed. I managed to make a start on the A pillars and inner wings, and this was slow progress due to the thickness of metal, which is incredible compared to the Fiesta. This is not surprising given the weight of components on the Golf; 1 door weighs more than 2 complete Fiesta doors!
The Golf uses a different construction method to the Fiesta; its main strength appears to be within the sills, which contain multiple channels and thicknesses. The floor chassis sections in comparison are weak. This is in contrast to the Fiesta which has significant chassis members under the floor. With this in mind I have designed 2 extra box sections to run along the Fiesta shell once the Golf floor is in place.
04-05-2009 | Remove dash board and wiring loom
The wiring loom passes through the bulkhead and is sealed in along with the bulkhead by RTV sealant. I found the best way to remove this was with a blow torch. A bolt in bulkhead panel reduces cost when manufacturing LHD/RHD variants of the shell.
The dashboard is now also removed, and after a quick measure of it and the Fiesta shell, it will just fit in after removal of 10mm from each side. The whole dashboard will be covered in black Alanctara once the car is finished.
03-05-2009 | More parts removed
I removed a few more parts from the shell, including the wiper linkage which will be shortened to suit the Fiesta's windscreen.
19-04-2009 | Taking delivery of the damaged R32
I purchased the remains of a damaged 2006 R32.
I sold the drive train from it as I already had 2 and this one looked like it had done a lot more miles. I'm only really interested in the bottom half of the shell, the fuel tank and some miscellaneous fixings.
As I noted with the drive train, every single component I remove seems to weigh a considerable amount. It's a surprise the R32 has the performance it has and it makes me question the need for such engineering; our desire for ever more refined and well engineered cars is producing a colossal amount of waste!
<a href="/images/2092/" title="Fiesta Quattro - 2009" rel="lightbox"><img class="thumb floatleft" images/2093/[/img]
<p class="clearfix">The dashboard is mounted in a typical VAG fashion; alloy cross brace mounting to each A pillar, and a further brace to the tunnel.
<a href="/images/2082/" title="Fiesta Quattro - 2009" rel="lightbox"><img class="thumb floatleft " images/2083/[/img]
<p class="clearfix">I have most items I need from the engine bay, and cabling routing and layout in here is superb.
02-02-2009 | 2nd R32 Drivetrain obtained
A 2nd complete drive train was obtained from a breaker in Manchester, this time with brakes and exhaust. This was from a 2006 car but had been stood for a couple of years and is as-new. As this is a 2006 it has the alloy sub frame and cast iron hubs. I will check dimensions of the 2008 rear end but plan to mix the alloy sub frame with the late alloy hubs.
<table>
<tr><th>Component</th><th>2006 – 2008</th><th>2008 ></th></tr>
<tr><td>Rear hubs</td><td>Cast Iron</td><td>Forged Alloy</td></tr>
<tr><td>Rear sub frame</td><td>Pressed Alloy</td><td>Pressed Steel</td></tr>
<tr><td>Rear ARB links</td><td>Steel</td><td>Alloy</td></tr>
</table>
One thing I did notice with the late sub frame is that the stronger steel construction negates the need for an under slung bracket. No doubt this make servicing the diff easier and so perhaps makes VAG more money…
Initial observations are shock at the weight of the components; manufacturing a drive train that suits something the size of a Passat and then fitting to a car the size of a Golf must bring with it some serious compromises. These components are seriously heavy duty! I have some work ahead to make weight savings where I can and produce a finely balanced and responsive car.
31-01-2009 | R32 Rear Drivetrain obtained
I was lucky to find a late rear drive train which had covered only 1500 miles. The rear sub frame is steel and the hubs are forged alloy; this seems to be the case for all post 2008 setups. I suspect this is a low-cost optimization exercise by VAG; save money by using a pressed sub frame and spend it on reducing unsprung weight.
Re: 3.2 V6 4 Motion/Quattro Mk3.5 Fiesta - 03/09/2009
Postby dangerousdave on Thu Sep 03, 2009 7:47 pm
looks cool buddy but we want updates here! lol :lol: :lol: :Q
dangerousdave
Postby jimmyesh on Thu Sep 03, 2009 8:52 pm
This is the mother of all projects! :Q Amazing amount of quality work going on here, can't wait to see this finished.
jimmyesh
Your car: Yes
Postby FezzR on Thu Sep 03, 2009 9:50 pm
good to see this project isn't dead!
do you have a source for ETKA? i have one but is too out of date for the gear your using, but give me a pm if you don't know where to get it and ill check if i can get a new copy :wink:
FezzR
God Damn Lazy
God Damn Lazy
Postby Turboboy67 on Fri Sep 04, 2009 12:24 am
Your completely bonkers :bonkers: :lol: :lol:
Awesome fella, I for one would never ever have enough patience to do what your doing,
Good luck with it all :)
Turboboy67
Your car: 911GT3 RS
Postby Xr_Dub on Fri Sep 04, 2009 1:00 am
thank god ur still going :Q vrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Postby Excursion on Fri Sep 04, 2009 10:23 am
Cheers chaps, progress has been slooooow since I bought a house :)
Postby dangerousdave on Fri Sep 04, 2009 11:00 am
its going to be one hell of a fiesta with all the refinements of a modern german car!! :Q :D
dangerousdave
Postby Ruishy1 on Sat Sep 05, 2009 6:58 pm
very nice mate, its some amount of evolution since you began the project :bonkers:
Ruishy1
Postby jonboisescort on Sat Sep 05, 2009 7:02 pm
great project and cant wait to see it finished
:aviator: :aviator:
jonboisescort
Car: 1994 Ford Fiesta
Postby PaulC on Sat Sep 05, 2009 7:25 pm
Mark! I havent been around here for a while, and I remember you starting this! But, you're still as mad and I wish I had the money and space to do something like this... keep going and get it done :Q
PaulC
Postby Excursion on Sun Sep 06, 2009 1:43 pm
Cheers boys :D
Postby Excursion on Sat Sep 12, 2009 7:30 pm
The front end and floor pan is in.
It took me a day of measuring, I'm sure it could have been done in less time, however I wanted everything to be perfect.
The Golf floor pan sits 13mm above the bottom of the sill lip, exactly where the Fiesta pan did.
Detail at base of A pillar. This is absolutely crucial for rigidity and safety. There are a further 3 seams behind this fillet, and each has been painstakingly joined to a reinforcement panel I added to the Fiesta sill/A pillar base. (Ingore the 'blobby' welding on the rusty metal - that is a temporary support post which will be removed)
The Fiesta outer wings have to be notched to sit around the Golf turrets. The bottom of the Fiesta bonnet also required a little modification to sit flush.
There's a fair bit of work ahead around the front inner wings, and infill pieces on the bulkhead.
Re: 3.2 V6 4 Motion/Quattro Mk3.5 | 12/09/2009 R32 Floorpan in
Postby Sphinx on Sat Sep 12, 2009 7:41 pm
So all the work you did getting the mk5 front in is now redundant :o :lol:
You are insane in the membrane but in the best possible way :D
Postby Excursion on Sat Sep 12, 2009 7:49 pm
Sphinx :So all the work you did getting the mk5 front in is now redundant :o :lol:
Yeah :lol: For anyone who's been thinking about it; it's possible :lol:
Sphinx :You are insane in the membrane but in the best possible way :D
Thanks babe
Postby ~nomad~ on Sat Sep 12, 2009 10:55 pm
good god.
~nomad~
Your car: Breadvan
Postby leeny on Sun Sep 13, 2009 5:44 am
absolutely nuts mate...lukin gud keep it up :D
RuLeThEbEnDs
leeny
Postby Ruishy1 on Sun Sep 13, 2009 1:50 pm
im glad project is all moving forward again, but to think of all the wasted work you put into it. good god man :o
but loving the latest incarnation :D
Ruishy1
Re: 3.2 V6 4 Motion/Quattro Mk3.5 | 13/09/2009
Postby Excursion on Sun Sep 13, 2009 5:48 pm
Ruishy1 :im glad project is all moving forward again, but to think of all the wasted work you put into it. good god man :o
It wasn't wasted work, it was all good experience ;)
I have used Mk5 Fiesta wheelarch infill panels to bridge the gap between the Mk3 A Pillar and the Golf wheelarch. The curvature of the Golf wheel arch is reasonably close to that of the Fiesta in the area I need to fill, so these panels work well.
Postby Sphinx on Sun Sep 13, 2009 6:12 pm
Did ya get my text? :D
Postby allinking on Sun Sep 13, 2009 6:18 pm
Still love this car will be a great Fiesta when done :)
allinking
Postby muz on Sun Sep 13, 2009 6:25 pm
Excelent progress Mark. I really thought this car was just not going to make it. Glad to see its still progressing.
muz
Postby Ruishy1 on Sun Sep 13, 2009 9:12 pm
yuo better not change your mind again, or me and the rest of FT are coming to your door with lit torches and pitch forks :lol:
looking good though, its not the usual flung together rubbish thats out there :aviator:
Ruishy1
Postby Excursion on Wed Sep 23, 2009 10:24 am
Distractions, distractions. I have another Mk3; a 1.4 Mk3.5 Ghia with 29k on the clock and Full Ford Service History - 14 stamps!
A freshen up has turned into a complete pain in the arse, as ever, with old cars, remove one thing and you end up replacing everything else connected to it! Updates to follow soon.
Postby Ruishy1 on Wed Sep 23, 2009 10:59 am
jesus man !!!
you need to get your priorities in order !
this first, silly run about second :rolleyes: :P
Ruishy1
Postby dangerousdave on Wed Sep 23, 2009 11:06 am
agreed, we wanna see this at FITP 2010!! :P :bonkers:
dangerousdave
Postby Dave G fsi on Wed Sep 23, 2009 11:44 am
This is an absolutely awesome project mate, just looked right through it.
Hats off to you, your doing a brilliant job, keep up the good work :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby Smo on Wed Sep 23, 2009 7:32 pm
Mark, you really do do some amazing work :)
Get some pics up of the Ghia too, or even do a thread!
Smo
Postby Sphinx on Wed Sep 23, 2009 10:07 pm
Ruishy1 :jesus man !!!
That silly runabout will be having my old engine so I say his priorities are bang on :D
Love ya Mark, sorry about the affectionate txts the other night :)
Postby Smo on Wed Sep 23, 2009 11:17 pm
Sphinx :
Is that where my texts went? :(
Smo
Postby Sphinx on Wed Sep 23, 2009 11:19 pm
You know I love you Simon, you're just never about for me to express my love :(
Postby ~nomad~ on Thu Sep 24, 2009 12:34 am
I've got a distraction for you Mark*
*clue, its my winky
~nomad~
Your car: Breadvan
