Mk3 Escort Pick up project - GOT A NEW CAR!!!
one question about the blacktop that no one has been able to answer me,
are the bolt holes for things like water pump, oil pump, rear engine mount and front alernator/pas bracket all in the same place as the silver top?
- adamburzynski
adamburzynski :one question about the blacktop that no one has been able to answer me,
bolt holes for water pump are different, as you can see in my pictures i've had my block machined to accept an rs1800 (silver top) water pump, i'm doing this simply because the black top water pump runs in the wrong direction, and needs to run in the opposite direction on a turbo charged car, hense the change.
I'm using the same oil pump..
rear engine mount is different on the black top. where the engine mounts (on rear of silver top) is where the alternator and bracket is, on silver top the alternator is at the front this is where the the engine mounts from on a black top. hope that makes sense.. these have to be swapped around, mount from the rear (where alternator is) and alternator goes where it would mount at the front... not sure about power steering yet, this is something i wanna look into having big wheels on my motor
heeman10 :What happened?
evening batman, see the football, ooh no your a homo, you dont like football do you
i got sandwich on a dual carriage way in slow moving traffic... i was stationary, heard some screaching, looked in my rear view mirror and saw an escort van skidding towards me
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich
07834862431
- rich_frst
No, I did NOT see the gayball!! I see we scored more than some third world country, all those millions of pounds clearly went to good use! They finally got the one-foot ball through the 100 square foot rectangle at the end of the field! Twice!
Clearly skillful men to be proud of
Sounds nasty, glad it wasn't a more valuable car and you're alright
heeman10 :No, I did NOT see the gayball!! I see we scored more than some third world country, all those millions of pounds clearly went to good use! They finally got the one-foot ball through the 100 square foot rectangle at the end of the field! Twice!Clearly skillful men to be proud of
non footy fans make me laugh
was a bit, never been in ambulance before, hopefully never again
cheers mate
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
heeman10 :Football fans make me laugh harder
"Who do you support?"
"Chelsea, you?"
"Arsenal. Let's fight!"
you fooking geek...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
rich_frst :
rear engine mount is different on the black top. where the engine mounts (on rear of silver top) is where the alternator and bracket is, on silver top the alternator is at the front this is where the the engine mounts from on a black top. hope that makes sense.. these have to be swapped around, mount from the rear (where alternator is) and alternator goes where it would mount at the front... not sure about power steering yet, this is something i wanna look into having big wheels on my motor![]()
u got any pics to expalin all these different holes?
as long as i can get the engine on the mount at the rear, and the big bracket that holds the alternator and pas and front mount to bolt on the front, i'll be happy... i know for different cars and different modles they normally mount in different places, but u noramlly find the holes are the same, its just the mounts, or the way they mount that is different...
- adamburzynski
adamburzynski :u got any pics to expalin all these different holes?
the alternator bolt holes pattern is exactly the same as the front mounts pattern... no pictures needed, you will need to modify the alterantor bracket to clear the water pump housing (if your using the black top pump??) if not its well clear for using a silver top water pump..
i wont let on too much but the rear mount hole pattern for a silver top has a different pattern for where the alternator (black top) mounts.. so i'll let you work out what to do...
adamburzynski :and how much for the heated front screen?
er... dunno mate.. £40 - its never been wired in, think my dads aunt got it put in cos they didnt have any normal screens....
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
- fiestamatt
- DIY Guy
fiestamatt :coming along awesome m8 should be sweet as when done![]()
Matt
quality mate, so thats who you are on here...
when i'm 100% there will be progress....
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
windscreen
Just had a look through your post ,was wondering about your windscreen?
Did you have to bond it in ?
Does it go straight in or does it need to be trimmed ?
doesd it go in as per the original?
cheeRS
Gav
cheeRS
Gav
- fiestamodder123
- Location: Mauchline (not the end of the world but you can see it from here)
as stated in the title, i have an injury, which for the last 2 months has been doing my head in...
was in a car crash in may, got sandwiched between 2 cars...
my car got wrote off, and i've had a bad back ever since...
in the process of doing some exercise everyday to work my back and make it stronger again...
hopefully not gonna be a long term thing, not rushing things as i wanna be 100% fit, strong and healthy before i attempt to get back to work, i could quite easily do more damage if i went back tot work
might have an update on my new, lets say everyday vehicle very soon...
rich
rich
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
Bad news, bad backs are so fragile
Get some swimming in if you don't hate swimming!
Here's to a solid recovery!
heeman10 :Bad news, bad backs are so fragileGet some swimming in if you don't hate swimming!
yeah i know mate... thats what i'm finding out now...
the spinal specialist i saw recommended swimming, cycling and some walking... been swimming everyday for the last 2 weeks, bought a new bike, and done a little walking... done some cycling, but felt worse after that... so just swimming..
my physio has given me an exercise routine to do in the pool..
my bills that i've been collecting so far are mounting up, scary how much stuff costs and adds up too, MRI scan, consultations with a spinal specialist, physio, swimming... the list goes on
just hope i'm not off work for ages...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
As soon as you wrote "cycling" I thought "No!!". Not a good idea really, puts too much strain on the back in too many places if it's already fragile, stick with swimming - no shocks, no sudden movements, just fluid, lightly-loaded exercise
heeman10 :As soon as you wrote "cycling" I thought "No!!". Not a good idea really, puts too much strain on the back in too many places if it's already fragile, stick with swimming - no shocks, no sudden movements, just fluid, lightly-loaded exercise
thats what i said when the spinal surgeon said cycling to me!! thought he was having a laugh!!!
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
rich_frst :heeman10 :Football fans make me laugh harder
"Chelsea, you?"
you fooking geek...![]()
So hence makes me a geek for not liking woosball either
Play a proper Mans game liek rugby
Least them fookers dont cry on the floor like babies when they get a litle tap on the floor
BTW move that oil return
- TomRS1800
mickylee :i had an MRI scan on my knee. fouquette noisy machine!!!
yeah i was warned about that, but when i got in there some bird said do you want to listen to any music whilst i've got the ear defenders on, said yeah ok... anything will do, like most things..
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
TomRS1800 :So hence makes me a geek for not liking woosball either
yeah maybe...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
rich_frst :TomRS1800 :So hence makes me a geek for not liking woosball either
yeah maybe...rugby is cool, its only forgeiners that fallover and cry us english dont cos we're hard
how many more times... not moving it, if all falls and my engine goes funlumps up then, paul hills will have a big bill to deal with, but i doubt that will happen
Sure is cool!
and I have been for many MRI scans in the past 4 years so know how you feel with the whiplash Its a fooker but it tske time to get over it!
- TomRS1800
TomRS1800 :Sure is cool!
yeah i bet, is that you in the sig?? biker eh...?
its doing my head in, but just gotta sit tight and let my body recover
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
rich_frst :TomRS1800 :Sure is cool!
Nope thats my bro messing about in Thailand!
http://www.getjealous.com/guidobertarelli
Some proper funny pics in there!
Ive been suffering with back and neck pains for nearly 4 years and now Ive been back and foward to specialists to get sorted! They say its pyschological now and after going to a shrink they have blessed me with 6 to 9 months of Cognitive Behaviour Therapy! Oh its gonna be fun! Just keep active mate and keep moving about as your body will adjust and repair itself!
- TomRS1800
rich_frst : yeah i was warned about that, but when i got in there some bird said do you want to listen to any music whilst i've got the ear defenders on, said yeah ok... anything will do, like most things..
first song
will young
thought ok, perhaps there will be something different on afetr this, turns out to be his fcuking album, had to listen to about 8 tunes, done my head in!!!
TomRS1800 :Nope thats my bro messing about in Thailand!
oh ok... nice pics there
i hope i'm not suffering much longer, just wanna get my life back on track, been a weird 2 months... had to get out of the pool early this morning, back was aching to much, thats the first time thats happened...
last week i felt like i was getting somewhere now i fell like i'm going backwards in time
trying to do things still, not strenuas tho..
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
heeman10 :rich_frst : yeah i was warned about that, but when i got in there some bird said do you want to listen to any music whilst i've got the ear defenders on, said yeah ok... anything will do, like most things..
first song
will young
:lol::lol::lol::lol:
wasnt funny mate!!!!!
wish i couldve pulled the ear defenders off, but couldnt move a muscle...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
as you can see from the title, i have put a put a deposit on a mk3 escort pick up... here's the advert's i saw...
http://www.passionford.com/forum/viewtopic.php?t=205660
http://oddkiddcreations.co.uk/forum/vie ... hp?p=54488
and just thought..
i want it
i havent actually seen the pick up in the flesh yet, my cousin lives on the isle of wight and said he'll go have a look over it for me... anyway last night a deal was struck and deposit laid...
here's some pictures if anyone cant get onto the above links.
my bro took this picture last year at ford fair...
and this is just another picture i have
cheers for looking chaps
D:
rich
and just thought..
rich
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
Looks an awesome bit of kit Rich
Get some pics up when you get it!
- TomRS1800
TomRS1800 :Looks an awesome bit of kit Rich
will do mate,
be a while tho, until i can hack a car journey where i dont ache and stiffen up, and until i have money to go and get it from the IOW...
My ProjectS..
rich
07834862431
rich
07834862431
- rich_frst
rich_frst :TomRS1800 :Looks an awesome bit of kit Rich
will do mate,
Whay money for fuel or money for the truck itself?
If you need a taxi ride down I'm sure I can come pick you up and get it sorted well untill you could hack the ride of a 4x4!
Lemme know if you need a hand
- TomRS1800
