Re: "K80" ZT - More Pics (21/07)
Postby jayrs on Sun Jul 21, 2013 8:25 pm
Coming on well Wayne :)
Re: "K80" ZT - Meh! (18/07)
Postby Rhinopower on Sun Jul 21, 2013 8:48 pm
Excursion :
Rhinopower :Also needs the spacer plate to route the bypassed air for the iscv if you go that route.
It will bolt on fine if you get the right version - some of the Mondeo bodies have the air bypass built in to the TB.
Isnt that 'Ollie's' Mk5 escort? He is using the white spacer plate too. Why would ford develop a white plate to use, if they already had a casting that was correct for the frs?
Rhinopower
Your car: Volvo FH330
Postby Excursion on Mon Jul 22, 2013 10:02 am
Rhinopower :Isnt that 'Ollie's' Mk5 escort? He is using the white spacer plate too. Why would ford develop a white plate to use, if they already had a casting that was correct for the frs?
Because the FRS manifold is the early manifold which won't fit a Fiesta Bay without modification - it is different to the later two-piece manifold which will fit a Fiesta bay. The TB design changed twice over the years.
Postby russ-RST on Mon Jul 22, 2013 9:28 pm
I was told the 2 piece plastic inlet manifolds aren't that great at holding boost? Or is this more rumours more than truth ? If I'm honest I haven't looked into it much so this is great info for me as I just got told to use a blacktop inlet :lol:
Russ
russ-RST
Your car: fiesta rs turbo
Postby Rhinopower on Mon Jul 22, 2013 9:50 pm
Excursion :
I originally started with the later manifold which still didn't line up with the tb correctly, and then got an earlier manifold
Rhinopower
Re: "K80" ZT - Injectors Sealed - IT'S ALIVE! (23/07)
Postby Tweek on Tue Jul 23, 2013 9:27 pm
Well, the idea I had paid off. I went for some tighter but chunkier seals and it's cured! I even managed to seal them with the pintle caps fitted too :D
OEM Ford seals are 7.52 x 3.53 x 14.8mm (ID x CS x OD)
New better ones are 7.0 x 4.0 x 15.2
The difference...
Completed injector:
IT'S ALIVE!
Issues remaining...
- Turbo oil return is leaking pretty badly from the joint at the turbo itself
- Still doesn't idle. I've put a pen top in the old breather intake vac-leak lol.
- Rear brakes are largely ineffective
- ECU needs configuring to a safe driving map
- MOT
Once those are sorted, you might be seeing it at Ford Fair :D
Oh, the chatter is epic, here's a sample ;)
(clunk at the start = I caught the exhaust)
Your car: VW Golf GTD
Postby Dave5300 on Tue Jul 23, 2013 9:36 pm
chatter :Q :Q :Q :Q :Q
Dave5300
Postby Gus!! on Tue Jul 23, 2013 11:04 pm
Brilliant!! :) see you at ford fair then??
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Postby jayrs on Wed Jul 24, 2013 12:04 am
I see the vid on FB mate, glad to see is up and running now, and them few probs left to sort are nothing major, with this, Jess car and some others, I'm a bit gutted I won't be at ford fair this year :(
Postby jonyb4 on Wed Jul 24, 2013 1:31 am
now that sounds really quite something!
im excited to see this at FF now
(wheres nick going on about no tax, test and mot?! :P)
great job man something to be really proud of here, on the clock now! whens the painting stage likely to happen, you think?
Postby - Danny Boy - on Wed Jul 24, 2013 12:52 pm
That does sound pretty awesome :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Tweek on Wed Jul 24, 2013 5:57 pm
Struggling to find an MOT at the moment. The contact I was given no longer works there :(
Postby Ratspeed on Wed Jul 24, 2013 8:52 pm
Road trip then :wink:
Ratspeed
Postby Tweek on Wed Jul 24, 2013 9:04 pm
Probably wouldn't go down well driving across the country for a test :lol:
Postby jonyb4 on Wed Jul 24, 2013 11:54 pm
what is it stopping you? cat?
Postby Excursion on Thu Jul 25, 2013 10:30 am
Excellent news :D
Postby GRP16V on Fri Jul 26, 2013 3:05 pm
Superb job,
i like
"Top Gear" addicted
Image Image Image
GRP16V
Your car: Fiesta Si /Escort mk6
Postby knuckles on Fri Jul 26, 2013 7:18 pm
well done wayne ! :D
knuckles
Your car: Fiesta Rs turbo
Postby Smo on Sun Jul 28, 2013 12:27 am
That's fantastic, Wayne! That chatter is a little bit mad! :D
Smo
Re: "K80" ZT - Onboard Video (29/07)
Postby Tweek on Mon Jul 29, 2013 9:12 pm
Got it idling today albeit hunting so took it to the end of the estate and back, thought I may as well record a video. Jess recorded it and soiled herself when I booted it so that's why it stops and restarts in the middle :lol:
Enjoy :Q
Random geeky video after setting up the wideband properly:
Postby Gus!! on Tue Jul 30, 2013 11:04 am
That sounds loud as fook!! I like :)
Gus!!
Postby jonyb4 on Tue Jul 30, 2013 12:37 pm
does sound fudgekin immense thou
Re: "K80" ZT - Road Legal (07/08)
Postby Tweek on Wed Aug 07, 2013 11:04 pm
Thought I'd leave an update saying the car now has an MOT and road tax. I've given it a blast down the road (under 4k) and it goes like fudgekin stink, making 16psi boost. Now I need to calm it down and run it in properly before I blow it up.
Oh, the radiator started leaking though *sigh* More stuff to do!
Unless something bad happens I'll see you guys on Sunday ;)
Postby Max M4X WW on Wed Aug 07, 2013 11:07 pm
I'm jealous of your 16psi, but I'm equally paranoid about my map so have only used 3/4 throttle or less really at 10psi!
Postby Tweek on Wed Aug 07, 2013 11:09 pm
It's probably a bad thing I even made 16psi on the adaptive mapping! Gonna drive it properly and steadily now before it all goes wrong.
Postby FRSJON on Thu Aug 08, 2013 10:50 pm
:lol: yours makes more boost than mine mapped :oooh:
FRSJON
Re: "K80" ZT - Ford Fair Beckons... (10/08)
Postby Tweek on Sat Aug 10, 2013 9:32 pm
Let's hope it makes it :lol:
Postby Ratspeed on Sat Aug 10, 2013 10:05 pm
spotted the obligatory spare oil in the boot! My fiesta doesn't go anywhere without it! :lol:
Ratspeed
Postby Tweek on Sun Aug 11, 2013 8:21 pm
Made it there and back without issues. Car is so much fun to drive and the noise is beyond EPIC. Full of win! :D
Postby Ratspeed on Sun Aug 11, 2013 8:59 pm
:Q
Ratspeed
Postby johnson91 on Sun Aug 11, 2013 9:14 pm
Seen this today and it looks nice in the flesh think the yellow hoses set it off
johnson91
Your car: ford fiesta
Postby hb69 on Sun Aug 11, 2013 9:44 pm
Good to hear it was a successful journey. Look forward to seeing it at Combe :Q
hb69
Your car: Fiesta 1.1 LX
Re: "K80" ZT - Ford Fair Success! (11/08)
Postby knuckles on Sun Aug 11, 2013 10:46 pm
As already said today - very impressed that you shoe horned that in whilst maintaining looks of the car.
Start saving for a paint job now :)
knuckles
Postby Rs Adz on Sun Oct 20, 2013 8:36 pm
just re read this from the start top work carnt wait to see it at the shows nxt year
Rs Adz
Your car: xr2i and mk1 fiesta
