Guide to fitting e/w's for a 3-door mk3 Fiesta inc. PICS!
52 posts • Page 2 of 2 • 1, 2
Yes worth ago i mean getting a door inner will be easy from a junkie yard
Any tutoisals on doing this lol
Choobe de daaa, chaboo da dee
- rumtickler
- bluefiestamk3
- BANNED MEMBER
- Phil Si
Car: 2000 BMW 330 Ci
i might be getting 2 doors from an xr2i monday with electric windows and central locking already fitted,
but my car is a mk3.5 classic without central locking or electric windows
i just would like to now if ill still be able to use these doors or not
any help will be appresciated
thanks
thanks
- Rimmer
Re: Guide to fitting e/w's for a 3-door mk3 Fiesta inc. PICS
alwaysmods2do :Wiring the electric windows:
I will now tell you how to wire up 1 of the electric windows and the same method applies for the other side.
· Hopefully you will have the other side of the plug which attaches onto the side of the motor.
From this there will be 1 blue and 1 green wire. Feed these through the door loom (if you manage to get them through the original rubber grommet thing.....well done!).
i cant find this in the car though or should that come with the door
and about the central locking will i still be able to key lock the door instead of setting the central locking up
- Rimmer
Yes you can lock the door with the key still, but the central locking is so easy to wire in you'd be a fool not to!
4 wires
2 Run to the other motor unit.
1 is a earth.
1 is a live.
Easy. (My colours may be wrong in that diagram)
As for that plug, it should still be attached to the motor. If its not, ask where it is, as you will need it!
4 wires
1 is a earth.
1 is a live.
- Badgerboy
Rimmer :i might be getting 2 doors from an xr2i monday with electric windows and central locking already fitted,
thanks
Would it not be better to take the electrics from the older door and put it into your car doors? If you swap for an early door you will lose the side impact protection bars!?!
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
So? You have a donor door. Electric window motor is seven bolts. Central locking is three screws. The wiring loom will just need snap-tying in. The difficult part is the manin wiring loom plug coming out of the fuse box which you are going to have to deal with anyway.
It is of course up to you, I just cannot see the point in changing the whole door on each side, having to paint them both and losing some of the your impact safety.
I put an electric pack in my '96 Classic in about three hours using this guide, it isn't that hard.
- Ollybee
ollybee :It is of course up to you, I just cannot see the point in changing the whole door on each side, having to paint them both and losing some of the your impact safety.
i need to replace the one door because somebody tried to break into the car and bent it back, the doors im getting are the same colour as my car so the wont need painting, and ive been offered both doors for the less then what it would cost me getting doors withour any electrics in and getting them painted from a scrappie
all i was asking was if i would have all the wiring needed in my car at the moment for the electric windows and whether or not i needed to set the central locking up or not
- Rimmer
great guide, fitted drivers side today.
only trouble was drilling out rivets but they came out then i moved drill round a bit.
also unscrewing the window from the regulator was a dam hard job but i had a strong rachet screwdriver which did the job.
do any of u think it will be ok not hooking the electric windows to the ignition? so that means i can use them without the keys?
wont be any kids in car or nething usin them all the time and ive hooked onto permanent live now. stil got passengers side to do but its pissin down.
also i cudnt get it through the door grommet thingy lol! had to pncture holes either side of gromment and thread cable through the outside of gromment but i taped it up good after.
cheers, jammy.
cheers, jammy.
- jammyradnor
Re: Guide to fitting e/w's for a 3-door mk3 Fiesta inc. PICS!
im hoping to do replace both my manual window winders for the motors, ive got the mechs and the switches adn the wiring in,
quick question anyone know what exact size dril bit use for drilling out the rivets?
and what size bolts to replace the rivets with?
- ford_09
