Guide to fitting e/w's for a 3-door mk3 Fiesta inc. PICS!
Postby alwaysmods2do on Wed Jun 25, 2003 1:12 pm
Guide to fitting electric windows:
This guide tells you how to fit electric windows from an xr2i onto any 3-door mk3 fiesta.
I decided to write this guide because all the people I asked for advice had no idea at all! So now that I've finally worked it out here it is-
Fitting the electric mechanism:
· Take off the door card and handles etc. This just involves taking out screws, and the only tricky bit is the original manual window winder, there is a clip on the back of the window winder between the plastic circular thing (pic's later), which jus needs to be prized off and then the window winder just pulls off.
· Now you have to drill out the old rivets....simply drill them until they fall out (worked for me). There should be 4 rivets on the window rack....2 at the top and 2 at the bottom....and there should be 2 either side of the manual winder mechanism.
· Detach the window from the mechanism (two screws on bottom of window).
For the next step I left my window in the door....but you might feel safer if you take it out.
· Now find a way to take the whole thing out....window rack and winder mechanism etc. It's a bit fiddly but it is possible!
· Insert the new electric mechanism and rack etc. (again its fiddly but possible!). On my doors the holes for the screws on the motor etc. were already there.....I'm not sure if this is always the case. Simply bolt the motor mechanism into place with the provide bolts and nuts (the bolts should already be attached onto the motor bracket).
· Now you have two options- you can either do what I did and find some nuts and bolts which fit through the holes where the rivets were and bolt the window rack thing onto the door with those.....or put new rivets in. Nuts and bolts worked fine for me.
· Now you need to fix the window onto the new window rack thingy....this simply screws back into place.....all holes should align as they did on the original manual mechanism.
· Thats basically the mechanism fitted. I left my door card etc. off the door until I'd tested the wiring and checked it worked.
Wiring the electric windows:
I will now tell you how to wire up 1 of the electric windows and the same method applies for the other side.
· Hopefully you will have the other side of the plug which attaches onto the side of the motor.
From this there will be 1 blue and 1 green wire. Feed these through the door loom (if you manage to get them through the original rubber grommet thing.....well done!).
· On the back of the switch there are 5 pins....
...again I hope you have the plug which attaches to the back of this! From this there are now 5 wires:
2 Brown- earth
1 Black and Yellow- live
1 Blue- attach to blue wire from motor
1 Green- attach to green wire from motor
Ok ok...on this switch the wires are coloured...2brown, 1 yellow and black, and one blue and yellow, and one green and yellow. Same principle jus with added yellow stripes on the blue and green wires!
· And thats basically it....connect the wires like above and you should find that the window works perfectly!
· I took a separate live directly from the battery and used 2 inline fuses....1 by the battery and 1 by the center console inside my car....from this power source I run my central locking boot release and electric windows....I found that the windows only worked with a fuse no lower than 15A, so thats what I'm using at present.
Hope this helps!
Any problems please ask....pictures will be uploaded soon.
Dave
Last edited by alwaysmods2do on Fri Jun 27, 2003 11:03 am, edited 3 times in total.
|-Good things come to those who wait-|
alwaysmods2do
Postby eXtreme-fiesta on Wed Jun 25, 2003 1:29 pm
im very very impressed dave!
You can come and help me when i get some now :D
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby gambo_si on Wed Jun 25, 2003 4:39 pm
cheers, my drivers side wire has snapped so i need to get a hole new electric motor kit from scrappy for 25 quid.
gambo_si
Postby Liebo on Wed Jun 25, 2003 5:47 pm
Central locking and boot release fitting guide in order please :)
Liebo
Postby alwaysmods2do on Wed Jun 25, 2003 5:55 pm
those guides are on the sticky threads on the top of the technical forum m8...i'v done both those on my car as well so i can help u if u want it m8
dave
alwaysmods2do
Postby eXtreme-fiesta on Wed Jun 25, 2003 6:26 pm
I vote for a seperate guides forum
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Liebo on Wed Jun 25, 2003 6:35 pm
A guides/tutorials/faqs section.
perhaps put them on the main site? proper guides with good pictures
Liebo
Postby alwaysmods2do on Wed Jun 25, 2003 7:23 pm
may b a combination between the two?
dave
alwaysmods2do
Postby alwaysmods2do on Thu Jun 26, 2003 6:24 pm
huge BTTT for AL :D
alwaysmods2do
Postby alwaysmods2do on Fri Jun 27, 2003 11:01 am
pictures now added [ERRR] b clearer for u all now! Hope ur car is ok Jay m8!
dave
alwaysmods2do
Postby RS rob on Sat Jun 28, 2003 1:11 am
good guide! cant be arsed for all that tho! i'll just get jamie to do mine, once he learns from mods to 2!!!!!!!!!!!!!!!!!!!
haha you know you wanna jamie!
RS rob
Postby buff on Sat Jun 28, 2003 7:19 pm
on later models (newer switches) its the exact same but, you have 2 more wires, another brown (pin4) and a grey yellow (pin5), they are simply for illumination! and the switchs and multiplugs are different design.
fitment (mechanically) is exactly the same as above
there are 2 ways to wire them.
1: a switch on each side ie 1 for passenger, 1 for driver
OR
2: a switch on the passenger side and 2 switches on the driver side, 1 for each window
its only the driver side (on later models and both multiplugs from that side) that uses the above wiring colour codes
on the multiplug for the switches, it gives you pin numbers beside each wire. these are the pin numbers and connections required for both wiring options. these are for the passenger side, but follow the above wiring colours etc for the drivers side
................. (single passenger switch )
1- blue/y.......... to motor
2- bk/y............ live
3- grn/y......... earth
4- br........ earth
5- gr/y........ illumination live
6- blu/y......... earth
7- grn/y ....... to motor
..................... (connections to second passenger switch on drivers side)
1- blue/y......... to blu/y on passenger switch (pin4)
2- bk/y........... live
3- br.............. earth
4- br.............. earth
5- gr/y........... illumination live
6- br.............. earth
7- grn/y ........ to grn/y on passenger switch (pin3)
NB do not earth pin 3 and 4 on passenger side if you want to connect the second switch to it.
buff
Postby alwaysmods2do on Sun Jun 29, 2003 1:36 pm
nice1 buff
alwaysmods2do
Postby eXtreme-fiesta on Thu Jul 31, 2003 6:11 pm
bridgend_boy :good guide! cant be arsed for all that tho! i'll just get jamie to do mine, once he learns from mods to 2!!!!!!!!!!!!!!!!!!!
p-m-s-l just noticed this... You wish mate, do something yourself you lazy old git :lol:
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby DaveZetec on Fri Aug 01, 2003 10:08 am
eXtreme-fiesta :I vote for a seperate guides forum
I vote for a forum for scouts aswell!
DaveZetec
Postby zetec_si on Sun Aug 03, 2003 10:05 pm
Cheers for the guide mate, fitted mine over the weekend and they work a treat! :D
I have now finally got an Si with full electrics. :)
Mk3.5 1.6 Si -> 2.0 Zetec Conversion - SOLD :(
MKIV Supra, S362 Billet Single Turbo (624.7HP/520ftlb) - http://www.youtube.com/user/MrG33kman
zetec_si
Location: Near Bristol, Drives: Something with a 3.0 Straight Six.... oh yeah, and 2 turbos!!
Postby Percy! on Wed Aug 20, 2003 4:12 pm
Great guide, will be doing this myself soon.
Percy!
Your car: Citreon
Postby eXtreme-fiesta on Tue Sep 16, 2003 7:21 pm
Just done one side! :D
Cheers dave!
Sorry about calling you so many times with regards to the rivets :lol: :lol:
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby zetec_si on Tue Sep 16, 2003 9:57 pm
They are a right pain mate! Took ages to drill them out. (Mind you, for the first 5 or 10 mins I didn't realize I was using a wood drill bit :rolleyes: )
zetec_si
Postby dj_mase69 on Tue Sep 16, 2003 10:17 pm
iv got an electric window kit but its not from a existing fiesta. looks bloody complex. how long did it take you lee? was urs from a fiesta?
dj_mase69
Postby zetec_si on Tue Sep 16, 2003 10:42 pm
Mine was from a fiesta mate and fitted easy as all the holes are already there. It was literally drill out old rivets, take out manual window runner, put in electric runner, bolt in and wire up. Job done.
Taken me a year to get off my arse and fit them! :lol:
zetec_si
Postby dj_mase69 on Tue Sep 16, 2003 10:57 pm
u reckon i might be able to find a kit in a fiesta already? like in a scrappie? what model fiesta am i looking for then?
dj_mase69
Postby zetec_si on Wed Sep 17, 2003 12:16 am
I think most Ghias came with them and some xr2i's? Someone here is bound to know more. :)
zetec_si
Postby eXtreme-fiesta on Wed Sep 17, 2003 10:12 am
As far as i know,
Fiesta Ghia's had them, Xr2i's, RS Turbo's, RS1800's and the Si had them but it depends what door cards you are using, as i think it was the Si who had the switch on the doors instead of the centre console?
There is plenty of online scrappies mate who offered me them for about £30 or so, but make sure you get the wiring looms and the plug that connects to the back of the switch, as Ford wanted £30 for this alone per side!! :o :o
As for the rivets...what an absolute pain in the arse! I did not succesfully drill out one rivet, the only way i got them off was by banging the heads off them with a screw driver and a hammer, but still gets them off!
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby dj_mase69 on Wed Oct 08, 2003 2:41 pm
people iv managed to get hold of an electric window kit but it aint got the wireing loom on it. is there anyways around this? iv got all buttons motors and other parks but no wires. help!
dj_mase69
Postby eXtreme-fiesta on Wed Oct 08, 2003 3:30 pm
yeah! I had loads of problems tryin to get hold of a wiring loom! Ford wanted about £37 per side so i made my own!! Just use some 10amp wire from halfords!
Sorted!
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby dj_mase69 on Fri Oct 10, 2003 10:28 pm
the waires aint a problem its just the connecters that fit to the motor. spade ends are fine on the buttons but on the motor its just little metal sticks but dont know how to connect the wire to this? can anyone help with this??
OR HAS ANYONE GOT A WIREING LOOM FOR SALE??
dj_mase69
Postby zetec_si on Sat Oct 11, 2003 12:31 am
Clean the metal connectors off and scratch them up a bit with wet and dry, then solder the wires on directly :)
zetec_si
Postby dj_mase69 on Sat Oct 11, 2003 10:37 am
yea but i cant get inside the plastic mate, is it poss to cut the plastic so i can get in there and solder it?
dj_mase69
Postby zetec_si on Sat Oct 11, 2003 4:34 pm
Yeah, I would carefully cut it out of the way.
zetec_si
Postby Escort Cos on Tue Nov 11, 2003 2:00 pm
When you remove the rack and clamp bit that goes on the bottom of the window, will the window stay up i.e. closed, if so, how? what holds it up?
What I'm asking is, can you remove the whole motor and rack togeter with the window still in, without the window falling inside the door.
Escort Cos
Postby eXtreme-fiesta on Tue Nov 11, 2003 3:03 pm
as soon as you undo the two screws that hold the window to the rack it will gradually slowly slide down :aviator:
Jamie
eXtreme-fiesta
Fiesta XR1.3i
Fiesta XR1.3i
Postby Escort Cos on Tue Nov 11, 2003 3:26 pm
Isn't this a pain to get the rack out once the window starts to slide down?
Escort Cos
Postby rumtickler on Wed Nov 12, 2003 12:06 am
i would imagine so
WHats the time scale if you went throgh a day to do it and are XR2i door cards the saem size as the 5 door cause using one would eliminate the winder holes?
Choobe de daaa, chaboo da dee
rumtickler
Postby zetec_si on Wed Nov 12, 2003 12:27 am
Nope XR2i's are 3 door cars and the doors are much longer than a door from a 5 door fiesta. May be able to cut them down or something? Retrim them at same time :)
zetec_si
