Fiesta RS Project - *29.9.06* - f**k IT, I GIVE UP!!!
Postby heeman10 on Sat Aug 12, 2006 11:59 am
And have you tried Turbo Technics? It seems weird to me they couldn't supply them :-? Calling Honeywell you're getting right through to the top, so at worst they'll give you a guaranteed supplier's contact details.
Postby ianFRST on Thu Sep 07, 2006 7:24 pm
** 7.9.06**
finally got all the bits i needed to finish the T3 conversion, so todays job was to fit it all, fit the exhaust, and get it started :Q
for the 1st time in nearly 2 years, the car sports a complete exhaust system :o :lol:
sneaky pic of the new recon turbo
the car started 1st time after we primed the turbo :D :D :D with no rattling or anything, which i was impressed about, seeing as its been stood for 4 weeks or so.
and now for the bad bit :x got the car started, manifold smoked as you expect when you dirty hands over it etc, but sadly the turbo never stopped smoking :( :cry: switch off, have a look about, and find this underneath :cry:
as you can see, thats the reason why it didnt stop smoking :( it looksl ike its leaking form that bolt, HOPEFULLY thats all it is, else it will have to come off again :x :cry: :cry:
think ill just insure it, and burn it :rolleyes: :lol: :cry: :x
ianFRST
Postby heeman10 on Thu Sep 07, 2006 9:45 pm
Bummer dude, who bolted the turbo together? Good that the engine all started up and ran fine though :) You still haven't put my bloody brake fluid reservoir on there, not happy! Everything else looks spot on! :(
Postby ianFRST on Thu Sep 07, 2006 10:35 pm
james james james, its on the next thing to do list :lol: the cars still not road worthy, but when it is, the brakes will be bled properly, and yes, your nicer than mine reservoir will go on :Q :P
yes i was plesently surprised with the engine - but i did swap the top inlet over. if you see my other pics, it had a black powder coated inlet, but for some reason, where the black pipe from the brake servo goes into the side of the inlet, it was kinda leaking air. so i thought id do a straight swap for my other one, and its sorted the air leak, and the idle is now perfect, and the revs dont stick :Q
ianFRST
Postby Excursion on Thu Sep 07, 2006 11:47 pm
Give it time mate, metal to metal joins sometimes take a litle while to seal. How long did you leave it running for?
Postby ianFRST on Fri Sep 08, 2006 9:20 am
Excursion :Give it time mate, metal to metal joins sometimes take a litle while to seal. How long did you leave it running for?
till the fan cut in 3 times or so. so i guess a good half hour? maybe a bit more
sent a picture to who rebuilt it, and he says take it off and send it back to him so he can inspect it :cry: :x :cry: :( :cry:
ianFRST
Postby Excursion on Fri Sep 08, 2006 10:23 am
ianFRST :till the fan cut in 3 times or so. so i guess a good half hour? maybe a bit more
Hmm so it's definitely oil then and not just a bit of carbon coloured water! Who built the Turbo?
Postby rob pace on Fri Sep 08, 2006 2:43 pm
let me know the outcome ian of what was wrong. im going tonstart on mine next week!
good luck matey :wink:
rob pace
Postby ianFRST on Fri Sep 08, 2006 3:04 pm
will be removed and sent off tomorrow hopefully, and then stripped down in the week sometime, he will then let me know whats happened to it, and then rebuild it for me, i hope.
ill keep you informed :cry:
ianFRST
Postby ianFRST on Fri Sep 08, 2006 5:58 pm
right well this afternoon, i stripped it all down again :cry:
i was going to do what excusrion said, and run the car for a bit longer, so i had a quick look under the turbo again, to see it has got worse :(
so i didnt bother running it, and juts cracked on with getting it off, as i expected, the turbo wouldnt come out with the rad in place, so it all had to come out :cry:
so it looks s**t again :rolleyes:
ianFRST
Postby rob pace on Fri Sep 08, 2006 6:03 pm
great ive got all this to come ian :x :x , hopefully start on sunday/monday!
are you breathers, crank not blocked at all?
turbo technics did mention about the oil return (mine is old) and about the pressure from the uprated exhaust i have.
rob :Q
rob pace
Postby ianFRST on Fri Sep 08, 2006 6:05 pm
no mate, not blocked. was all cleaned when i removed the engine to put it in this one.
ianFRST
Postby rob pace on Fri Sep 08, 2006 6:10 pm
ianFRST :no mate, not blocked. was all cleaned when i removed the engine to put it in this one.
oh yeah did you remember to prime it? :lol:
bet your pissed off mate, i know i am! :x cant believe it was on exactly the same day as you.
well he said along the lines of upgrading to 2 piston rings in the turbo instead of 1 ring (excuse my mechanical talk here :P ) and it will cope a lot better from the back pressure of the exhaust, well along these lines anyway- it is £45 + VAT which seems reasonable.
rob
rob pace
Postby heeman10 on Fri Sep 08, 2006 6:17 pm
What exactly did they say about the backpressure relating to your aftermarket exhaust system? The backpressures should be lower if anything, just wondered how reduced backpressure would cause a leak like this :-?
TT have been very short-staffed today, I managed to get nowhere with my problem, and now have a sheared off bolt to resolve too.
Ian - I remove my turbo on the exhaust manifold, did you try that, rather than removing the turbo from the manifold?
Postby rob pace on Fri Sep 08, 2006 6:25 pm
heeman10 :What exactly did they say about the backpressure relating to your aftermarket exhaust system? The backpressures should be lower if anything, just wondered how reduced backpressure would cause a leak like this :-?
that what i thought james, that there would be lower pressure with no centre box and 3" pipe, but he was sure it would cause higher pressure and seemed to be pointing the problem in this direction :-?
well he said send it back and they will check it over for me, also reccomended buying a new oil return which is £27.50 inc VAT.
rob pace
Postby ianFRST on Fri Sep 08, 2006 6:49 pm
i dont have any baffles what so ever, just the back box, would that make any difference?
heeman10 :Ian - I remove my turbo on the exhaust manifold, did you try that, rather than removing the turbo from the manifold?
i didnt want to remove the manifold, as when we put the T2 on it before, 2 of the threads fooked, so had to helicoil them, i felt like it was tempting fate TOOOO much to have to remove the manifold :lol:
rob - by oil return, i presume you mean the thing that bolts to the underside of the turbo? why would that make any difference? its not a think piece of pipe that wouldnt get blocked is it, lol
ianFRST
Postby rob pace on Fri Sep 08, 2006 6:56 pm
ianFRST :
yes to the underside of the turbo into the block/sump.
thats one of the first things he mentioned to me about the oil return (it can get blocked causing oil to come back up into the turbo unit), he noticed it looked old in the photos i e-mailed them. also the oil return is mentioned in my thread in general. however i do believe the t3 return is far better.
rob pace
Postby garyhurn77 on Sat Sep 09, 2006 1:03 am
bad news about the turbo i hope danny will sort it out for you!
on a plus point glad to see my rubber return hoses working well :D
fingerscrossed you get it sorted asap!
gary
garyhurn77
Postby ianFRST on Mon Sep 11, 2006 2:08 pm
garyhurn77 :fingerscrossed you get it sorted asap!
ive got everything crossed mate :cry: :lol:
sent the turbo off on sat morning (£11.50 :aaah: ) so he should get it tuesday or wednesday, thursday at the absolute latest. dunno why i sent it parcel force :oops: should have sent it through work, ait it would have got there tomorrow :rolleyes:
will update, when i know more :Q
ianFRST
Postby chris-fiesta on Mon Sep 11, 2006 2:11 pm
good luck m8, hope it all gets sorted..
chris-fiesta
Postby ianFRST on Fri Sep 15, 2006 2:47 pm
**update 15.9.06**
got a pm on passionford regarding my turbo.....
the bearing failed. now im not sure which bit this is :lol: but its beign repaired FOC and sent back to me asap.
he didnt have one in stock so is having to order one in, so hopefully tues / wed next week ill have it back rebuilt again :Q
ianFRST
Postby MarkRS2K on Fri Sep 15, 2006 2:56 pm
good stuff, hope its not to costly for you? :)
MarkRS2K
Postby heeman10 on Fri Sep 15, 2006 3:06 pm
Which bearing? Did he tell you why? That's the most important part - don't want to bolt everything back in only for it to happen again! :-? My turbo's being sent back to me today, should be here on Monday - race you! :D
Postby Excursion on Fri Sep 15, 2006 3:16 pm
Ian, I'm sorry to hear, it couldn't have happened to a nicer guy ( :lol: :rolleyes: )
Postby rob pace on Fri Sep 15, 2006 3:17 pm
well ian, hopefully that will be the same problem for me, i have just sent him an e-mail at TT expalning that you have recieved the results of your problem. i havent had a chance to take it off due to my working hours but hopefully on monday.
hopefuly mine will be FOC as well, fingers crossed. :devil:
regards
rob. :D
rob pace
Postby heeman10 on Fri Sep 15, 2006 5:46 pm
Ian's wasn't from Turbo Technics :-?
Postby ianFRST on Sat Sep 16, 2006 4:38 pm
heeman10 :Which bearing? Did he tell you why? That's the most important part - don't want to bolt everything back in only for it to happen again! :-? My turbo's being sent back to me today, should be here on Monday - race you! :D
no he didnt say which. all i got was....
the bearing housing has failed for some unknown reason
ianFRST
Postby Superal on Sat Sep 16, 2006 4:49 pm
One thing after another...will your car even make it onto the road again :lol:
Superal
Postby ianFRST on Sat Sep 16, 2006 8:34 pm
Superal :One thing after another...will your car even make it onto the road again :lol:
tell me about it :rolleyes:
and i cant honestly answer that question either :lol: :oops: i HOPE one day :bonkers:
ianFRST
Postby ianFRST on Wed Sep 20, 2006 5:21 pm
got the turbo back today :Q
still no real idea of what went wrong tho, but looking at the turbo its had a new bit :lol:
is that bit the bearing housing? where the oil feed, and the water feeds bolt to? :-?
ianFRST
Postby heeman10 on Wed Sep 20, 2006 5:51 pm
Is it definitely all new, not just blasted off? It really can't have been right! Perhaps the bearing seats in the centre housing (that's what that part is btw...the centre housing and rotating assembly, or CHRA) itself were duff, not the seals themselves. That's promising! :D
Took mine out today and all is well, though it seemed down on power and more laggy than before. Might've been because I was running it without the dump valve for a change...hope it's not those damaged compressor fins!
Hurry up and get it back on the car, this time it'll be fine :aviator:
Postby ianFRST on Wed Sep 20, 2006 6:15 pm
heeman10 :Hurry up and get it back on the car, this time it'll be fine :aviator:
fingers, legs, toes, everything i can cross is crossed :oops:
ianFRST
Postby ianFRST on Fri Sep 29, 2006 12:59 pm
**UPDATE, friday 29th***
well, fitted the turbo this morning, waitied for the rain to stop before trying it, primed it as per usual, and can you foooooooooooooooooooking believe it!!!!!!!!
it smokes even worse than last time :x
literally, i could tell straight away something was wrong, as the the smoke coming from the back of the exhaust was a real white, not like the condensation white, and when it lifted a bit higer, the smoke was blue, so had a look under neath and............
that is literally 2 minutes, IF THAT from starting the car to having a look and taking the picture :x
got a vid, but you cant see the smoke very well, but its smoking worse that last time from the actual turbo unit
I GIVE UP!!! i honestly 110% give up with the car, its fudgekin tug, im now gona get a crow bar and smash every single panel of the fudgekin thing :x
ianFRST
Postby mike_wall15 on Fri Sep 29, 2006 1:36 pm
Maybe it's finally time you broke it and put the lot on ebay.........
....oh wait a minute, you're banned! :oops: :lol:
Seriously Ian, bad bad luck. It's just ashame you're so close to finishing it. Give it a few days so you can think about it, don't make any silly decisions in the heat of the moment :wink:
Chin up! :Q
mike_wall15
Car: 2002 BMW M3
Postby MarkRS2K on Fri Sep 29, 2006 1:40 pm
cant you just send it back to who ever 'repaired' it?
MarkRS2K
