Fiesta RS Project - *29.9.06* - f**k IT, I GIVE UP!!!
And have you tried Turbo Technics? It seems weird to me they couldn't supply them
Calling Honeywell you're getting right through to the top, so at worst they'll give you a guaranteed supplier's contact details.
** 7.9.06**
finally got all the bits i needed to finish the T3 conversion, so todays job was to fit it all, fit the exhaust, and get it started
for the 1st time in nearly 2 years, the car sports a complete exhaust system
sneaky pic of the new recon turbo
the car started 1st time after we primed the turbo
with no rattling or anything, which i was impressed about, seeing as its been stood for 4 weeks or so.
and now for the bad bit
got the car started, manifold smoked as you expect when you dirty hands over it etc, but sadly the turbo never stopped smoking
switch off, have a look about, and find this underneath
as you can see, thats the reason why it didnt stop smoking
it looksl ike its leaking form that bolt, HOPEFULLY thats all it is, else it will have to come off again
think ill just insure it, and burn it
- ianFRST
Bummer dude, who bolted the turbo together? Good that the engine all started up and ran fine though
You still haven't put my bloody brake fluid reservoir on there, not happy! Everything else looks spot on!
james james james, its on the next thing to do list
the cars still not road worthy, but when it is, the brakes will be bled properly, and yes, your nicer than mine reservoir will go on
yes i was plesently surprised with the engine - but i did swap the top inlet over. if you see my other pics, it had a black powder coated inlet, but for some reason, where the black pipe from the brake servo goes into the side of the inlet, it was kinda leaking air. so i thought id do a straight swap for my other one, and its sorted the air leak, and the idle is now perfect, and the revs dont stick
- ianFRST
Give it time mate, metal to metal joins sometimes take a litle while to seal. How long did you leave it running for?
Excursion :Give it time mate, metal to metal joins sometimes take a litle while to seal. How long did you leave it running for?
till the fan cut in 3 times or so. so i guess a good half hour? maybe a bit more
sent a picture to who rebuilt it, and he says take it off and send it back to him so he can inspect it
- ianFRST
ianFRST :till the fan cut in 3 times or so. so i guess a good half hour? maybe a bit more
sent a picture to who rebuilt it, and he says take it off and send it back to him so he can inspect it![]()
Hmm so it's definitely oil then and not just a bit of carbon coloured water! Who built the Turbo?
right well this afternoon, i stripped it all down again
i was going to do what excusrion said, and run the car for a bit longer, so i had a quick look under the turbo again, to see it has got worse
so i didnt bother running it, and juts cracked on with getting it off, as i expected, the turbo wouldnt come out with the rad in place, so it all had to come out
so it looks s**t again
- ianFRST
great ive got all this to come ian
, hopefully start on sunday/monday!
are you breathers, crank not blocked at all?
turbo technics did mention about the oil return (mine is old) and about the pressure from the uprated exhaust i have.
rob
rob
- rob pace
ianFRST :no mate, not blocked. was all cleaned when i removed the engine to put it in this one.
oh yeah did you remember to prime it?
bet your pissed off mate, i know i am!
well he said along the lines of upgrading to 2 piston rings in the turbo instead of 1 ring (excuse my mechanical talk here
rob
- rob pace
What exactly did they say about the backpressure relating to your aftermarket exhaust system? The backpressures should be lower if anything, just wondered how reduced backpressure would cause a leak like this
TT have been very short-staffed today, I managed to get nowhere with my problem, and now have a sheared off bolt to resolve too.
Ian - I remove my turbo on the exhaust manifold, did you try that, rather than removing the turbo from the manifold?
heeman10 :What exactly did they say about the backpressure relating to your aftermarket exhaust system? The backpressures should be lower if anything, just wondered how reduced backpressure would cause a leak like this
that what i thought james, that there would be lower pressure with no centre box and 3" pipe, but he was sure it would cause higher pressure and seemed to be pointing the problem in this direction
well he said send it back and they will check it over for me, also reccomended buying a new oil return which is £27.50 inc VAT.
- rob pace
i dont have any baffles what so ever, just the back box, would that make any difference?
heeman10 :Ian - I remove my turbo on the exhaust manifold, did you try that, rather than removing the turbo from the manifold?
i didnt want to remove the manifold, as when we put the T2 on it before, 2 of the threads fooked, so had to helicoil them, i felt like it was tempting fate TOOOO much to have to remove the manifold
rob - by oil return, i presume you mean the thing that bolts to the underside of the turbo? why would that make any difference? its not a think piece of pipe that wouldnt get blocked is it, lol
- ianFRST
ianFRST :heeman10 :What exactly did they say about the backpressure relating to your aftermarket exhaust system? The backpressures should be lower if anything, just wondered how reduced backpressure would cause a leak like this
i dont have any baffles what so ever, just the back box, would that make any difference?heeman10 :Ian - I remove my turbo on the exhaust manifold, did you try that, rather than removing the turbo from the manifold?
i didnt want to remove the manifold, as when we put the T2 on it before, 2 of the threads fooked, so had to helicoil them, i felt like it was tempting fate TOOOO much to have to remove the manifold![]()
yes to the underside of the turbo into the block/sump.
thats one of the first things he mentioned to me about the oil return (it can get blocked causing oil to come back up into the turbo unit), he noticed it looked old in the photos i e-mailed them. also the oil return is mentioned in my thread in general. however i do believe the t3 return is far better.
- rob pace
bad news about the turbo i hope danny will sort it out for you!
on a plus point glad to see my rubber return hoses working well
fingerscrossed you get it sorted asap!
gary
gary
- garyhurn77
garyhurn77 :fingerscrossed you get it sorted asap!
ive got everything crossed mate
sent the turbo off on sat morning (£11.50
will update, when i know more
- ianFRST
- chris-fiesta
**update 15.9.06**
got a pm on passionford regarding my turbo.....
the bearing failed. now im not sure which bit this is
but its beign repaired FOC and sent back to me asap.
he didnt have one in stock so is having to order one in, so hopefully tues / wed next week ill have it back rebuilt again
- ianFRST
Which bearing? Did he tell you why? That's the most important part - don't want to bolt everything back in only for it to happen again!
My turbo's being sent back to me today, should be here on Monday - race you!
well ian, hopefully that will be the same problem for me, i have just sent him an e-mail at TT expalning that you have recieved the results of your problem. i havent had a chance to take it off due to my working hours but hopefully on monday.
hopefuly mine will be FOC as well, fingers crossed.
regards
rob.
regards
rob.
- rob pace
heeman10 :Which bearing? Did he tell you why? That's the most important part - don't want to bolt everything back in only for it to happen again!My turbo's being sent back to me today, should be here on Monday - race you!
no he didnt say which. all i got was....
the bearing housing has failed for some unknown reason
- ianFRST
Is it definitely all new, not just blasted off? It really can't have been right! Perhaps the bearing seats in the centre housing (that's what that part is btw...the centre housing and rotating assembly, or CHRA) itself were duff, not the seals themselves. That's promising!
Took mine out today and all is well, though it seemed down on power and more laggy than before. Might've been because I was running it without the dump valve for a change...hope it's not those damaged compressor fins!
Hurry up and get it back on the car, this time it'll be fine
**UPDATE, friday 29th***
well, fitted the turbo this morning, waitied for the rain to stop before trying it, primed it as per usual, and can you foooooooooooooooooooking believe it!!!!!!!!
it smokes even worse than last time
literally, i could tell straight away something was wrong, as the the smoke coming from the back of the exhaust was a real white, not like the condensation white, and when it lifted a bit higer, the smoke was blue, so had a look under neath and............
that is literally 2 minutes, IF THAT from starting the car to having a look and taking the picture
got a vid, but you cant see the smoke very well, but its smoking worse that last time from the actual turbo unit
I GIVE UP!!! i honestly 110% give up with the car, its fudgekin tug, im now gona get a crow bar and smash every single panel of the fudgekin thing
- ianFRST
Maybe it's finally time you broke it and put the lot on ebay.........
....oh wait a minute, you're banned!
Seriously Ian, bad bad luck. It's just ashame you're so close to finishing it. Give it a few days so you can think about it, don't make any silly decisions in the heat of the moment
Chin up!
Chin up!
- mike_wall15
Car: 2002 BMW M3
