would I fail a mot if .....
Postby johnson91 on Wed Mar 27, 2013 8:33 pm
Just brought a bonnet with no holes for the washers jets would it fail a mot or does it not matter
johnson91
Your car: ford fiesta
Re: would I fail a mot if .....
Postby Tweek on Wed Mar 27, 2013 8:38 pm
As long as you can still get water onto the windscreen safely and securely then it's not a problem. Some cars/vans have the washers built into the wiper arm.
Your car: VW Golf GTD
Postby johnson91 on Wed Mar 27, 2013 8:40 pm
Do u no anyway I can safely do it lol
johnson91
Postby FRSJON on Wed Mar 27, 2013 9:13 pm
mk3 fiesta? theres two holes in the scuttle panel that could be used if for some reason you didnt want to cut the bonnet...or run the washer jet hose up the wiper arm with a stop end in it and some small holes along the hose to let the water out
FRSJON
Postby johnson91 on Wed Mar 27, 2013 9:22 pm
Yh mk3 fiesta mite run it up the wiper if I can figure it out if I was to put it in scuttle pannel wud I need diff jets or wud the stadard ones be ok
johnson91
Postby Ratspeed on Wed Mar 27, 2013 9:50 pm
I put some universal jets in the holes Jon is on about, worked a treat :)
Ratspeed
Postby tom9876 on Thu Mar 28, 2013 12:04 am
my old one had the washers in the scuttle panel worked fine for me
tom9876
Your car: frst
