TTF Si 2.0 - WOAH! An update! - 29/08/2014
Re: TTF Si - Painting continues - 19/01/2011
Postby - Danny Boy - on Thu Jan 20, 2011 10:23 pm
Nah, dont live with my parentls lol. You should tell them to f-off :lol:
- Danny Boy -
Your car: Fiesta Si 2.0
Postby EUFez on Mon Jan 24, 2011 12:36 pm
Did you spray that on the headlights? Looks good.
EUFez
Postby Minstral on Mon Jan 24, 2011 3:21 pm
EUFez :Did you spray that on the headlights? Looks good.
comes like that from factory james dont know if they done it to every ford at the time. ttf was stamped everywhere which was why i was relecutant to replace many things
Minstral
Your car: *
Postby - Danny Boy - on Mon Jan 24, 2011 4:18 pm
As Toby said James, its the original part from the factory. All windows, sunroof, front + rear lights (the original rears that are in my box of bits not my smoked ones) and whatever else was stamped from the factory has it on there from what ive seen so far :)
- Danny Boy -
Postby EUFez on Mon Jan 24, 2011 4:28 pm
Ahhh :lol: You see I thought you sprayed it on LOL because obviously you sprayed other bits so I just thought you did. Mine has been stamped, but most parts have been replaced.
EUFez
Postby Minstral on Mon Jan 24, 2011 5:31 pm
you can buy some sort of etching thing i was talking to someone about it once cant remember who.
Minstral
Your car: *
Postby jonyb4 on Mon Jan 24, 2011 6:07 pm
yea my sunof and windows have been done (except ther RS pop outs)
its so i someone steals the part you can trace it
or if someone breaks the window to steal it you can identify that shafd etc as yours and check it for prints etc
i used one of them kits on my mk4, they dont last long though
you can use a dremal and a stencle (sp)
Postby Ratspeed on Mon Jan 24, 2011 6:59 pm
All the windows on my mk1 are still marked up :Q
Ratspeed
Re: TTF Si - Update with painted bits added to car - 18/02/2011
Postby - Danny Boy - on Fri Feb 18, 2011 8:25 pm
Hey guys, been a while since I updated this, nearly an exact month to be precise! I wasn't going to update it today, was going to next week with even more progress I had made, but I couldnt hold back lol.
Lets start with a list of whats happened since the last update.
- Replaced both anti-roll bar drop links.
- Replaced both lower arms for brand new ones - not camber adjustable or polybushed, as thats for a later date on another set.
- Replaced the ford lower arm bolts with new high tensile stainless ones.
- Replaced aux belt.
- Changed rocker cover for spray painted one.
- Fitted sprayed throttle body onto inlet.
- Fitted sprayed exhaust headsheild.
- Fitted K&N bananananananaaaaaa pipe and filter with the painted maf back on to the car.
- Fitted painted stut tops.
- Sprayed radiator fan housing.
- Fitted sprayed engine hooks and other nuts and bolts that was sprayed.
- Replaced fuel filter.
- Snapped ball joint pinch bolt.
- Started to underseal the car - pics of that later this week/next. Wanted to inclide it in this update next week lol.
So, onto the pics yes? :)
Lets start with this one, got this taken going into ford fair, not the best pic as the angle makes it look funnily shaped I personally think lol, but still, its one of the car to add to the collection lol.
Onto progression pics.
Got these through the post, but havent fitted yet:
Old anti-roll bar drop links:
New anti-roll bar drop links:
Old lower arm bushes:
New lower arms, new nuts, bolts and washers to replace ford crap lol. And some evo stick: sticks like s**t - thats for later use:
Random selection of painted bits:
Painted strut tops (blue tape in 2nd pic is there for good reasons! its insulating one of them crappy in line fusion fuse holders, had a tiny bit of condensation inside the housing, so deided to tape it up and got carried away lol):
New lower arms fitted with all new nuts and bolts ect:
Then the ball joint pinch bolt.... I got a bit superman with this lol. Will be getting some high tensile stainless ones in there like I did with the lower arms.
Rad fan surround being sprayed:
New aux belt:
New fuel filter:
Engine hooks fitted. Look better after a fresh lick of paint.
This is what you have been waiting for! Rocker cover, throttle body, exhaust heat sheild on....
Banana pipe and maf fitted:
- Danny Boy -
Postby Ratspeed on Fri Feb 18, 2011 8:35 pm
fffffffrrrreesh :Q
Ratspeed
Postby jonyb4 on Fri Feb 18, 2011 8:49 pm
lookign good mate, efforts paid off so far
the intake completes the bay in the second but last pics, separates all the silver :Q
Postby jonyb4 on Fri Feb 18, 2011 8:54 pm
like jays breath :)
Postby jayrs on Fri Feb 18, 2011 10:03 pm
jonyb4 :like jays breath :)
Postby EUFez on Fri Feb 18, 2011 10:44 pm
Saw the photos on Facebook, looks fecking awesome mate. :)
EUFez
Re: TTF Si - Small update, couple of new parts - 27/02/2011
Postby - Danny Boy - on Sun Feb 27, 2011 7:38 pm
Only a small update, not alot of progress on the car as I have been busy with things and the weather has been pants too.
I'll save the current car progress for a later update so I can just do it all in one.
But for this update, I popped over to the isle of wight on saturday (yesterday) to see family and also to meet up with Jon (FRSJON) to get a couple of bits.
Got myself a FRST spoiler, some pop out rear windows and a 2nd rear anti-roll bar. So, obviously the spoiler will be painted up and will replace my standard rubber painted one as all the paint has cracked from I guess heat and flex, who knows. The windows will be changed over obviously, and the 2nd rear anti-roll bar will be cleaned up, painted and polybushed.
Thats it for the update.
Couple of pics.
- Danny Boy -
Postby jonyb4 on Sun Feb 27, 2011 7:57 pm
nice, the pop outs were bit of a pain to fit i found, are you going to tap the holes to screw the hinges on?
is the RS spoiler plastic then?
Postby fezza89 on Sun Feb 27, 2011 7:59 pm
everyone told me the pop outs were hard to fit, i think they are one of the easiest things ive done to the car
fezza89
Postby jonyb4 on Sun Feb 27, 2011 8:06 pm
fezza89 :everyone told me the pop outs were hard to fit, i think they are one of the easiest things ive done to the car
lol how did you do it?
Postby fezza89 on Sun Feb 27, 2011 8:10 pm
i didnt have the correct fittings for the hinges, had a look in my sisters ka at her pop outs and see they were rivited, so i got the rivits, all the holes were already there to rivit on, and i already had the right size threaded bolts for the handle end. just luck that i had the bolts really. had them both fitted within 30mins :D
fezza89
Postby jonyb4 on Sun Feb 27, 2011 8:19 pm
agh! you baxtered i didnt think of rivets :lol:
:rolleyes:
Postby - Danny Boy - on Sun Feb 27, 2011 8:58 pm
:lol: you tit Jony. Did you not know they need to be riveted in? Silly :P should do some research before you fit them :P
I dont know what the spoiler is made out of, but its seems much more sturdy than the normal ones.
- Danny Boy -
Postby fezza89 on Sun Feb 27, 2011 11:16 pm
jonyb4 :agh! you baxtered i didnt think of rivets :lol:
:rolleyes:
how did you do it then? origional fixings?
fezza89
Postby jonyb4 on Mon Feb 28, 2011 1:06 am
tapped the holes and used self tappers, but they didnt go as tight as id have hoped, so now they can squeek with movement :rolleyes:
i may one day tint the rears to a light tint, so when i take them out to do that i can amend them
Re: TTF Si - Bit of an update, painted bits- wheels - 30/05/2011
Postby - Danny Boy - on Mon May 30, 2011 7:14 pm
Sup guys. Thought I would update my thread as its long over due. Some of you will have seen what I have been upto on the world of facebook.
So what I have been doing recently is just getting rid of the little rust underneath the car that there is, and a fair bit of painting and some under sealing and generally cleaning up the car.
I shall let the pics do the talking. Enjoy.
Crappy pic of the under seal. Will get better soon:
Sanding down process of the wheels began:
Then came the curb marks:
Then came the filler:
Who can see whats on the news paper?
Oh yeah! More of her later ;)
So then it was time to get the garage ready for spraying:
Then the painting process began:
First few layers of paint:
After a fair few layers of paint, and then lacquer, i moved onto the spoiler, strut brace and roof strips. Dont worry, we will come back to the wheels later :)
Peek-a-boob:
Yep, thats a colour coded strut brace! Wanted to be different:
Back to the wheels! Dont worry about the tyres, new ones are coming:
While it was in the air, i couldnt resist to see a trial fit:
Poor pic of the roof strips on:
Reflection - car isnt even polished:
And one of the mascot:
Should have another update tomorrow :)
- Danny Boy -
Postby jonyb4 on Mon May 30, 2011 7:24 pm
titties!
Postby jayrs on Mon May 30, 2011 7:24 pm
looking good mate, how you gunna get over that over spray? tyre wall paint
loving the boobs too :Q :Q
Postby Fraggle on Mon May 30, 2011 7:42 pm
:bonkers: Crackin job,wanna see it sitting on them rims!! :Q ...An no comment on her [ERRR] i'll get a slap :cry:
Fraggle
Postby - Danny Boy - on Mon May 30, 2011 9:30 pm
jayrs :looking good mate, how you gunna get over that over spray? tyre wall paint
Im getting 4 new tyres, so that will solve that problem :)
Boobies ftw. Keeps me entertained when im bored ;) lol
- Danny Boy -
Postby knuckles on Mon May 30, 2011 10:17 pm
- Danny Boy - :Im getting 4 new tyres, so that will solve that problem
hope the fresh paint dont chip when you remove the old tyres :(
knuckles
Your car: Fiesta Rs turbo
Postby jonyb4 on Mon May 30, 2011 11:58 pm
knuckles :
hes right leave it a week before you remove them
Postby jayrs on Mon May 30, 2011 11:58 pm
dont wanna know how they keep you entertained mate :lol:
jayrs :dont wanna know how they keep you entertained mate :lol:
oh yea, like none of us know :lol:
Postby Excursion on Tue May 31, 2011 10:03 am
The photos don't work for me, mate?
Postby - Danny Boy - on Tue May 31, 2011 11:33 am
Excursion :The photos don't work for me, mate?
Thats strange. They are linked from my facebook, but that shouldnt cause any problems as I know a fair few people who dont use facebook can see them.
Hmm. Try this: http://www.facebook.com/media/set/?set= ... 5592c1a90a
It says its a public link. If that doesnt work, ill upload them to photobucket especially for you :aviator: :lol:
- Danny Boy -
