Re: The Recaro Fiesta - New parts
it will do the job though.
i use borg and beck cluches in my rs and always have, well i say always ive only changed it twice
and one of them times was only cos i had the box out and was flush at the time
mind you i do have a brand new EBC one in the shed i got off someone on here years ago for £40
sorry to hear about the keying
tugger
why didint u tell me last night!?
your welcome to store the rs on my drive way under a car cover but ideally you should find a lock up, about £50 a month nowadays...
- GavStyli
- Your car: Fiesta Turbo
f**k sake man!!!!! Out of alot of poeple on this forum you have to be one of the most unlucky. Gotta give you alot of credit for sticking with this car mate
Alot of us would have given up long ago.
I really dont understand how instead of appriciating a nice example of what is now becoming a classic car people just get jeleouse of the owner and think it will be fun to deface it and ruin alot of hard work. A mate of mine has just had his nova totally striped and rebuilt with a full respray and some c**t has keyed up the bonnet and down both sides. He's absolutely gutted and just because of some sily little pikey scumbags
We should all go pikey bashing and clense our good nation of these dicks
olie
olie
- niracka
- Your car: E46 M3
Re: The Recaro Fiesta - here we go again ....
- knuckles
- Your car: Fiesta Rs turbo
didnt fall off fella, it could of been worse mate, still dont understand why it happened
that hub nut should not of come undone
knuckles :
passenger side wheel fell off
This is bad mate...
This scene could end much worse than it is.
- FlashXR2i
Re: The Recaro Fiesta - here we go again...
Hub nut came loose. Shaft came off from the outer cv joint.
The hubs splines were smashed to pieces and the wheel bearing was in numerous pieces.
Just goes to show that lowering your car and fitting 18 inch alloys to a fiesta takes its toll on wheel bearings
- knuckles
s**t news about the keying clark and the hub coming loose
chin up fella, you have resurrected and created a cracking fiesta
- onslack
- Your car: Si
Yeah mate, fiesta on 18's is an absolute overkill. Pointless.
- FlashXR2i
- jonboisescort
Car: 1994 Ford Fiesta
If your looking for a hub mine's only a few years old cost £127 from ford they did there bearing at the same time it still has the drive shaft in it will gaters i was going to keep it just in case i ever got a mk3 again as it cost me so much
- j7aoc
Bloody hell Clark you don't get alot of luck with this motor do you
Stick at it though fella
- Turboboy67
- Your car: 911GT3 RS
shame about the keying dude
lucky escape with the wheel, i had a simerler thing happen with a rear wheel on my RST, the rear wheel bearing went big time!! with no warning
keep going thow dude its a very clean, nicly tunned exsample.
keep up the good work
- rsonblackwheels
blimey this could have been alot more serious
keep telling you to stop taking corners over 100mph
- GavStyli
Re: The Recaro Fiesta - underneath !
not been updated lately as not much as happened.
but today i managed to get a ramp to use to have a butchers underneath at the Rs. I spent only half hour cleaning all the old oil and grease off the underneath.
Got a few areas that need some attention soon. Want to do some of the work my self but not sure how bad the rust is. Anyway here are some pics.....
Few scabs here nothing serious....
bit of surface rust here at the back ...
sills
Nothing is falling apart yet but bit worried that it will if i get a grinder on it ....
Broken arb clamps
Tank cleaned up alright. surprised this hasnt rusted
Drive shaft still not fully in gearbox. May have to refit the ball and cage type shaft as its slightly leaking transmission fluid
Thats it for now. Any advice on doing the rust will be much apreciated, Im glad there are no holes of bits falling off. My boss said its the best H reg he has seen underneath wise.
knuckles
sills
Broken arb clamps
knuckles
- knuckles
Re: The Recaro Fiesta - underneath...
nothing much there mate, all that surface rust will clean up fine.
thm bits at the back will more than likly need plating, common problem on mk3's, even the mk2's suffered from it and i wouldnt mind betting the mk4/5's too, its a bloody water trap.
tank must of had a coating on it like we spoke about on the phone, but if its bare metal now, get some paint on it
i recon it looks bloody good mate...very lucky.....most are alot worse...
- FRSJON
Yea man that looks real clean actually!!
Just attack it with a wire brush on a drill n see what happens lol. It doesn't look as if you will have many problems that will require majour attention
ollie
ollie
- niracka
- Your car: E46 M3
havnt seen your thread foe ages mate, and bloody hell ive missed a lot!
sorry to see things are going abit s**t with it, but as weve both said to eachother before, you gotta stick with it and it'll always put a big smile on your face when it all goes right
as for your undeside, after seeing those pics id say the value of your cars just rocketed up, your a very lucky chap for having an underside like that!
mines all rust free at the moment from what i can see, but when i take it off the road this winter il be removing all waxoil and giving it a good tidy up
keep it up mate it'll get there soon
- Ram
- rsonblackwheels
- knuckles
Re: The Recaro Fiesta - new bits ...
plug lead holder
rear arb bushes and brackets
rear beam bushes
header tank cap
spare wheel support bracket
temp sender
drive shaft seals
rear/side window caps
bonnet pull
brake fluid?
fuel rail bolts?
fuel tank/pump seal?
rear beam bushes
header tank cap
temp sender
drive shaft seals
bonnet pull
brake fluid?
fuel rail bolts?
- FRSJON
jayrs :it will do the job though.
i use borg and beck cluches in my rs and always have, well i say always ive only changed it twiceand one of them times was only cos i had the box out and was flush at the time
that was me
and it must have been nearly 4 years ago
- Ruishy1
you missed a couple jon
oil cooler seal
door wiring grommets
brake calipers blank plugs
it all cost a fortune never the less
oil cooler seal
- knuckles
Ruishy1 :jayrs :it will do the job though.
that was me![]()
was it, bloody hell mate how you remember that
some nice new bits there clark, bit over kill with some, but i guess working for fords now and the discount why the hell not eh
ill get you to get me some new bits if thats cool and send them over with the grear knob
jayrs :some nice new bits there clark, bit over kill with some, but i guess working for fords now and the discount why the hell not eh![]()
ill get you to get me some new bits if thats cool and send them over with the gear knob
Whats over kill there ?
i got a broken bonnet pull, broken arb clamps, rusty window caps, seized spare tray hook, leaky oil cooler, leaking drive shaft oil seal. split door grommets... shall i go on ?
- knuckles
if you want
knuckles - how much do ford charge the window caps? cheeRS
- Ram
That spare wheel thing is shiney
Ram :knuckles - how much do ford charge the window caps? cheeRS
£1.10 each fella
by the way the orange bonnet pull became Obsolete today so once they have gone they are gone !
- knuckles
knuckles :you missed a couple jon![]()
oil cooler seal
s**t ..didnt write down the door groments..ah..so its a oil cooler seal...didnt know what the plugs were for?/.. are the bolts injector rail ones??..
- FRSJON
nope...
they hold down 2 of the rear arb clamps to the beam
- knuckles
knuckles :Ram :knuckles - how much do ford charge the window caps? cheeRS
£1.10 each fella![]()
by the way the orange bonnet pull became Obsolete today so once they have gone they are gone !![]()
cool gonna go get me some tommorow as mine are abit crusty. better get me a bonnet pull too
- Ram
same happened to my old frst, got an afternoon off work because of it so it wasnt that bad
- Swanick
- Escort RS Turbo
