the 4 point harnesses
Postby sam-si on Fri Feb 01, 2013 12:36 am
the 4 point harnesses with the nascar style buckle (the rotate 90 or 180 deg) are they legal to use on the road?
sam-si
Your car: FORD FIESTA
Re: the 4 point harnesses
Postby MB7201 on Fri Feb 01, 2013 8:07 pm
No, they need to be a push button type
MB7201
Your car: Fiesta lx
Postby sam-si on Fri Feb 01, 2013 11:59 pm
MB7201 :No, they need to be a push button type
if i used the twist to release type on the road and got caught what do i get? fine or points?
sam-si
Postby MB7201 on Sat Feb 02, 2013 12:17 am
Probably more like a vehicle defect rectification notice.
MB7201
Your car: Fiesta lx
Postby sam-si on Sat Feb 02, 2013 8:04 am
MB7201 :Probably more like a vehicle defect rectification notice.
sam-si
Postby willowandmikey on Sat Feb 02, 2013 10:22 am
You would have to be unlucky and get caught by traffic. If caught it is a £40 fine no points. Vehicle rectification notices are hardly used. They are notices that make you get the car fixed or rectified but with no fine or points. They are a lot more work so hardly get used
willowandmikey
Your car: ford fiesta xr2i 8V
Postby rs_fiesta on Sun Feb 03, 2013 10:38 pm
My rally car has them and thats road legal and passes a mot.Id argue that they are safer than a normal seatbelt!!Hence why they are used in motorsport
rs_fiesta
Postby andymac on Mon Feb 04, 2013 3:26 pm
rs_fiesta :My rally car has them and thats road legal and passes a mot.Id argue that they are safer than a normal seatbelt!!Hence why they are used in motorsport
Only when used properly. If they're not properly fitted then you might well end up as a pink splodge rattling around inside that weld in cage of yours if you stuff the car properly. This is the problem with multi-point harnesses in road cars, if you don't wear them properly then you're basically signing your life away and hardly anyone does because of the myriad of things people want to do in road cars that isn't driving. :)
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
