Start up after 3 year lay up
Postby milla.reed on Fri Jun 10, 2016 7:22 am
2i Start up after 3 year lay up.
Hi I have read lots of info on how to start up a car after a long lay up. I think some info is unnecessary. (Squirt oil down plug holes into cylinders!?) I've decided to drain oil and change filter on my 2i, check plugs, siphon out old fuel, put in some fresh fuel and a fuel additive then just fire it up. Anything else yous would recommend before starting engine? Thanks
milla.reed
Your car: fiesta XR2i
Re: Start up after 3 year lay up
Postby Mav Singh on Sun Jun 26, 2016 8:10 pm
what I do is take out the spark plugs and give direct power to the start motor so its the motor spinning the engine up. I let it do this for about 4-5 mins, this pumps oil around everything, put the plugs back in and then fire up as normal.
1.6 si
Mav Singh
Your car: 1995 Fiesta Si 1.6
