Scuttle panel help
Scuttle panel help
Postby Fraggle on Sat Aug 24, 2013 7:27 pm
Gents anyone know where i might find one(your wiper panel if that helps :lol: )??
..or if the 3.5's are the same as the 3?
Im pretty sure they are but as always id REALLY appreciate the help and knowledge :Q :Q
mine has suffered the chop, now im in tears and cant find one :lol: :cry:
PLUS I NEED a passenger one of these http://www.ebay.co.uk/itm/Ford-Fiesta-C ... 27cd601793
MANY CHEERS all :wink: :Q
Fraggle
Re: Scuttle panel help
Postby Dave_B on Sat Aug 24, 2013 8:10 pm
Try rs turbo breakers in Southampton, they sorted all my parts for the rs, wings, rear arch repair panels, front valence and filler cap.
They had quite a good contact for panels!
Dave
Dave_B
Postby Fraggle on Sat Aug 24, 2013 8:16 pm
Thanks Dave :wink:
ive found the inner wing section(hopefuly..) but scuttle is the one i need, just missed a gen ford one for 40 notes :cry: :cry: praying it aint sold tbh.
I hate mk3's :rolleyes:
Fraggle
Postby fezzRS on Sun Aug 25, 2013 8:54 am
Fraggle :Gents anyone know where i might find one(your wiper panel if that helps :lol: )??
Theres a breakers by me mate that has them ill find out for u
Your car: run about
Postby jayrs on Sun Aug 25, 2013 11:32 pm
Could fit a later model one if ya want mate, Clark wanted a mk5 one on his car so he got one through work (ford panel) and I fitted it.
Needed a little tweaking while fitting, and I had to réclame it a few times but once fitted a little flex here and there to seat it and job done. Looks good too, I think if I ever had to do mine I would fit a mk5 one
Postby Fraggle on Mon Aug 26, 2013 9:21 am
Cheers mate.. :Q
See i have looked at the MK4 ones(you know the one's with the slightly oval headlights..) as i obvs wanna get as easy a fit as poss shape wise.
The one Mr C bought, what year was it off..(guessing its from the ZS shape)..so like a Y-reg?
I'll update tonight hopefully..
Fraggle
Postby Fraggle on Mon Aug 26, 2013 9:22 am
fezzRS : :lol:
CHEERS MATE :Q :Q ,
Id be much appreciated if a mint one could be found :Q :Q
Fraggle
Postby fezzRS on Mon Aug 26, 2013 11:39 am
Ill do my best bud im going to manchester later so if i see one ill let u know :)
Your car: run about
Postby fezzRS on Mon Aug 26, 2013 11:41 am
Is it the drivers side scutle panel your agter
Your car: run about
Postby jayrs on Mon Aug 26, 2013 3:15 pm
Pass mate your have to ask him.
The big difference though with clarks one is it only have 1 vent each side, not 2 each side like the mk3, so if your wanting it to be a mk3 then the later ones are not te way to go lol
Postby Fraggle on Mon Aug 26, 2013 6:08 pm
Cheers jay i will pm...
how much of a mare were it to fit boss,guessing the wiper mecs all good..?
Fraggle
Postby jayrs on Mon Aug 26, 2013 9:01 pm
Not much to be fair mate, I clamped it to the support under it first and it wouldn't line up right against the bulk head (windscreen part) so had to start again and I clamped it along the windscreen lip first, then tweaked it down and about until I was happy with it then clamped it to the support and spot welded it up.
Once all sport welded I had to Tweek it here and there to get it to sit right, once happy I brazed the edges up.
In short it wasn't a direct fit it in place clamp and weld, but tbh I would t expect any panel to be like that anyway, if it is then bonus.
If you go that way, just make sure you have decent clearance between the scuttle and underside of bonnet before final welding I would say
Postby tompeteRS on Tue Aug 27, 2013 2:20 pm
The MK4/5 ones should be pretty much interchangeable, they only real difference is that the MK4/5 one has holes in the recess for the windscreen wipers to allow water to drain out. On the MK3 the nuts under the wiper arm caps corrode and the rusty water/residue has nowhere to drain to.
Genuine ones are very hard to come by, pattern ones are no longer made for the MK3.
tompeteRS
Authorised Trader
Authorised Trader
Postby Fraggle on Sun Sep 01, 2013 11:33 am
tompeteRS :The MK4/5 ones should be pretty much interchangeable, they only real difference is that the MK4/5 one has holes in the recess for the windscreen wipers to allow water to drain out. On the MK3 the nuts under the wiper arm caps corrode and the rusty water/residue has nowhere to drain to.
Many thanks Tom.
So there is no chance a wizard like you has or could find said illusive MK3 scuttle then..?
Pleeeeeeeeeeeeeeeeaaaaaaaaaaaaaasssssssssssssssssssssssseeeeeeeeeeeeeeeeeeeeeeee :cry: :cry: :lol:
Fraggle
Postby tompeteRS on Mon Sep 02, 2013 1:04 pm
Unfortunately not, MK3 Fiesta panelwork is very hard to find.
I've had one come in all the time I've been dealing in NOS and it went to a member on here.
tompeteRS
Authorised Trader
Authorised Trader
