rs1800 still running hot
32 posts • Page 1 of 1
car still running with temp gauge at 'N'.still no mayo in oil,but fan only cuts in when temp right up.took off heater pipes yesterday& flushed loads of s**t out but still no joy!changed thermostat,& flushed rad already.changed gauge sender twice.does anybody know if ford used different senders for different 1800 zetecs as i dont have faith in my local dealer(ask for parts for fiesta rs1800 they say "rs turbo?"
fools. i need to sort asap as idont want to f**k the head if its not gauge.
- and.RS1800
- chumkila
- Dirty Post Whore!
the fan on my rs cuts in just above the "o" i think. if ur worried about overheating take ur themostat out all together and run ur fan on constant then i doubt it will over heat.
- Sunil_FiestaRS_16V
they all do it mate Si and rs1800 and 2L fiestas well mine did! if thats any help i was worried about it at one time! fan only come on in traffic normally!
- unknown_user
- chumkila
- Dirty Post Whore!
- chumkila
- Dirty Post Whore!
yes but the needle sits up this high all the time.fan cuts in fine but gauge doesnt go down again.didnt do this before sender packed in.needle used to sit on top of 'M'!
- and.RS1800
- chumkila
- Dirty Post Whore!
thats why i wondered if they used more than one type of sender for zetecs because the parts/service staff at my local dealers seem so vague about any parts i buy.
- and.RS1800
there are lots pf peeps on here with microcat CD's, i'm sure they could clear this question up.... just gota wait til they see this post.
- chumkila
- Dirty Post Whore!
also car didnt seem to run quite as well after cam belt change.didnt seem to have same kick up the arse at 3500 -4500revs.if yer man didnt get cam timing spot on could this have caused over heating & buggerd me head gasket?
- and.RS1800
- chumkila
- Dirty Post Whore!
- and.RS1800
- chumkila
- Dirty Post Whore!
yes fan sender is in rad.but what i was hoping it was just wrong temp gauge sender ,which would mean every thing else is fine.if not sender is it bad airlock?havetried every thing to bleed out any air by loosening all the hoses etc.only 4.5 -5 litres of coolant would go back in.haynes say 7.is this due to coolant which hasnt drained from block?
- and.RS1800
mobile man wasnt some chancer with a van & some tools,he was proper vehicle technician.franchiesed to green flag
.didnt really hav much choice as i say girlfriend wouldnt drop car off any where & iddont usually get home from work till after six.anyway i know people whove worked for main daelers like godfrey davis & perrys &they have not carried out certain service jobs which the customer is being charged for!!i had bad experiance with my old jag,where it whent to specialists for major service & i needed raer suspension rebuild,so did it my self,half the things they said needed doing were fine
they never even greased it.then had the cheeck to argue & ask if i knew what i was doing!anyone else had bad experiances of specialists/tuners?
- and.RS1800
Mav Singh :how will i be able to keep the fan running constantly on my Si?
unplug the fan plug and bridge the two connecions with a piece of wire
what is the optimum runnins temperature for an engine then? I know the thermostat doesn;t open until 88degrees so presumably about 90 degrees on a run would be ok?
what about oil temps?
- bcracknell
nope, bridged my FRST cos after the T3 conversion it allways got hot under the bonnet, now it never climes above the r on the dial. found that after the letter r it never ran well so was the best thing for it
" I LIVE LIFE A 1/4 POUNDER AT A TIME "
- Charliep
if it is cam timing & head been buggered how would i stand regarding recompense from mr green flag?also,how much to to get it checked? methinks about nearly the same as labour to do cam belt in first place?if it was out wouldnt it run very rough and not rev very well?she'll still redline through the gears.
- and.RS1800
Mine always runs up to N then fan kicks in i was on a paranoya when i got it that i was gonna cook it!
So i got a switch put in my car so i flick my fan on myself
228bhp...If In Doubt, Go Flat Out
- sexy-aRSe
yea my dumb si plays the scary game with me all the time the temp needle goes up to the N and then the fan kicks in untill the needle drops to the O. was wondering if someone could post me a guide on how to fiddle around with the fan to either make it stay on all the time or to make the fan kick in earlier like when the temp gets to the O insted of the N?
- Mav Singh
Mav Singh :yea my dumb si plays the scary game with me all the time the temp needle goes up to the N and then the fan kicks in untill the needle drops to the O. was wondering if someone could post me a guide on how to fiddle around with the fan to either make it stay on all the time or to make the fan kick in earlier like when the temp gets to the O insted of the N?
ur fan has a switch in the rad which switched to on at a certain temp u can either bi pass this (put a switch onit or bridge the connections so its on all the time) or u can get a switch which "opens" at an earlier temp. u can also change ur thermostat for one that kicks in at a lower temp.
just a note though zetec engines can run really hot so it is usuall for it to kick in above the "O" and just below the "N"
Re: rs1800 still running hot
is it possible to upgrade the rad in these cars? would like cooler running on my si. if its nailed in 3rd gear the temp does climb up but doesnt overheat. scary though.
or would just getting a new rad to replace my original 21 year old one make any difference?
1.6 si
- Mav Singh
got a new rad and makes no difference to how the temperature responds, got a lower opening fan switch which does kick the fan in a little bit sooner so that will have to do.
1.6 si
- Mav Singh
