rs turbo running temperature.
6 posts • Page 1 of 1
Hi, does anyone know what temperature in degrees Celsius a fiesta rs turbo should run normally. I changed all the cooling system parts including radiator and thermostat which opens at 74 degree. I bought a water temperature Gauge as the one in the dash was not reading well. The temperature running is between 80 and 95 degree Celsius. Is this good please? Is it true that rs turbo's run hot?
Any advice would help. Thanks alot.
Russellffrst
Russellffrst
- russellffrst
- Your car: 1994 diesel
Re: rs turbo running temperature.
Not 100% sure but normally the cars are fitted with an 88Deg stat.
And yes they run hot, my pals one in the summer gets so hot, you cant lean on the slam panel!!!
- RS EDDIE
Agree with what ed has just said. You could probably cook and egg on my bonnet
- rsturbonutter
- Your car: Fiesta RS turbo
Thanks for your replies.
As I can see this is something common about rs turbos that they run hot. My slam panel gets so hot too. So I think that it's all fine.
Russellffrst
Russellffrst
- russellffrst
Its because the rad is so close to the slam panel and that the hottest part of the rad is the top. Also you got to consider that heat rises and the turbo gets bloody warm
. I got a airtec escort rs rad and grs evo intercooler and its still hot. This is the issue with the fiesta I'm afraid. I wouldn't want to run a 74 degree thermostat though as it is too cold for the RS turbo. Standard is 88 degrees and was obviously designed for this temperature. I run a 82 and thought about the ones off ebay but after advice off here opted against it. Running an engine below normal operating temperature is no good for fuel economy or the life of your engine
- rsturbonutter
Hi rsturbonutter,
With a 74 degree thermostat the engine won't run below it's normal temperature. I always wait till the engine is at running temperature before pushing the gas pedal down. A 74 thermostat will open early and the engine won't raise the temperature that much but still reaches operating temperature.Thanks for your advice.
- russellffrst
