RS Turbo EFI Running Rough - NEW FAULT :/
Postby mrknifey on Fri Jan 16, 2015 3:24 pm
Hi guys got my turbo conversion running just it's running like a bag of bolts with the map sensor vacuum on the map sensor. If I take it off it runs fine and revs up fine. Any ideas on this one?
mrknifey
Your car: MK2 XR2
Re: rs turbo efi running rought
Postby mrknifey on Fri Jan 16, 2015 9:30 pm
Got to the bottom of it, got sold an Escort Cosworth Small Turbo Map Sensor! :x
mrknifey
Your car: MK2 XR2
Postby georgiocat on Tue Jan 20, 2015 11:05 am
Ouch... this happens I am afraid, due to the same shape... they have different codes unfortunately and they are not interchangeable... I have one too, sitting in a box and reminds me my ignorance back then... :P
My Ford Escort ride
georgiocat
Re: RS Turbo EFI Running Rough - NEW FAULT :/
Postby mrknifey on Tue Jan 20, 2015 6:48 pm
Got the lend of the correct map sensor and cured most of my issues. I now have another issue, it idles fine, then from idle it will misifre, sometimes a bit sometimes hardly anything until it gets past a certain point then clears.
Any ideas on this? Ive tried a Co2 Pot, checked the plugs and they are still sooted up from the incorrect map sensor, what kind of gap should they have? Ive checked for boost leaks and all seems ok!
Cheers guys
mrknifey
Your car: MK2 XR2
Postby georgiocat on Tue Jan 20, 2015 7:00 pm
If I am not mistaken the gap is around 0.8 - 1mm... I have write it down somewhere, but I think that I set mine at 1mm. Regarding misfiring, it may be running rich. Have you set it up? What's the AFR it is running under full boost and idle? You can't tell without a setup or a wideband nstallation. Further that it is dangerous to melt a piston, if it is running lean under boost...
My Ford Escort ride
georgiocat
Postby mrknifey on Tue Jan 20, 2015 7:16 pm
I havent had it setup no, doesnt smoke much tbh and I havent driven it just got it in the garage. Cant see why it would need setting up running standard ECU etc?
mrknifey
Your car: MK2 XR2
Postby mrknifey on Tue Jan 20, 2015 7:17 pm
Forgot to add, when I start it pretty much runs spot on straight away might I add, takes 20 secs then I get issues, even if its been running for ages ill knock it off, start it back up and it will be fine for 20secs
mrknifey
Your car: MK2 XR2
Postby nralden21 on Mon Feb 16, 2015 11:59 pm
Just the same as the problem I'm having and I've changed all sensors for new, new ecu and loom and this weekend a new fuel pump and it's still giving me grief. Have you had any luck yet?
nralden21
Your car: xr2i turbo
Postby mikeymikeyp on Tue Feb 17, 2015 8:38 am
have you still got the fuel acumulator box on the fuel pump
mikeymikeyp
