rear discs
rear discs
Postby rst_fiesta on Mon Aug 04, 2003 12:07 am
i am about to upgrade the front discs on my fezzie to 300mm 4 pots and fit a rear disc conversion on the rear.the rears will be 273mm from an ecy cos with 4b4 calipers but i dont want the back end spinning round on me so what do u lot suggest
rst_fiesta
Postby MikeyXR2i on Mon Aug 04, 2003 12:15 am
HI m8, ive got disks all round, cossie stuff, you won't have to worry about it spinning around, as the master cylinder aint big enough to make the brakes that sharp. You will see what i mean when you do it. I changed my master cylinder as the bigger the brakes the more fluid pressure you're gonna need to operate them.
MikeyXR2i
Postby xrsi on Mon Aug 04, 2003 11:04 pm
how exactly did you change the master cylinder?? and what to??
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby MikeyXR2i on Mon Aug 04, 2003 11:10 pm
hi XRSi, i changed it to MK5 Escort servo and master cylinder, fiddly and hard to do, but the result is well worth it. Add me to MSN will tell you m8.
MikeyXR2i
Postby Stoned on Tue Aug 05, 2003 8:28 am
Better yet, do a guide on here so we can all benifit from your wisdom and do it too :lol:
Stoned
Postby MikeyXR2i on Tue Aug 05, 2003 12:18 pm
yeah i will have to do a write up about it some time.
MikeyXR2i
