Popular Plus - 04/02/14 - Page 19 - The End!
Re: Popular Plus 16v - 31/05/10 - Page 10
Postby Smo on Sun Jun 20, 2010 10:34 am
Really and truthfully the biggest thing I've done is the 4-2-1, but it's some weird job which is apparently a Tube Torque, however I don't know. It's very dodgy and strangely works really well. I remember going back to the standard Zetec manifold and cat for a while when I snapped the manifold and it felt gutless! I don't know how it compares to the Ashley manifolds (or any others), but even with its dodginess, it works well.
Part of the manifold needs changing though because where I had to make it fit, at the time I could only find a bit of old Zetec midsection which has quite a restrictive bend in it, and I don't think it's helping matters. Also I'm still running the exhaust system which I was running last year at Ford Fair which is a REALLY cheap pattern job, and the bends in that are even worse than the one in the manifold :lol:
Smo
Re: Popular Plus 16v - 20/06/10 - Page 11
Postby Smo on Sun Jun 20, 2010 1:32 pm
Right, quick few photos.
Nothing exciting!
Cleaned up the new coil pack to go on as the old one was pretty buggered:
Exhaust manifold got a bit of VHT paint because it was so ugly :lol: :
Inlet went on with a nice new gasket as the other one was a bit dodgy:
Also gave a few bits of the engine bay a bit of a clean, but need to go over it again properly yet!:
Majority of it back together:
And I had a think about why the gearbox might be a little notchy and my suspicions were confirmed!:
... One of the detent plungers was buggered. I tried pushing it in and it was so stiff. The reason:
The box had previously been reconditioned, and obviously not very well. However, it's made a world of difference and it seems to be a fairly nice box now :) Now if only I can get it to go straight :lol:
Smo
Postby jonyb4 on Sun Jun 20, 2010 5:01 pm
hmm whats that plunger then? not seen one of them before :oooh:
looking nice and clean, loving the four branch, i want me one!
my engine is idling really lumpy now, i aint a clue what it is, and since i fitted the 2.0 cams yesterday it whines at 3k rpm, but it hink thats the cam belt cover rubbing on the belt or tentioner :rolleyes:
Postby sjoyce666 on Sun Jun 20, 2010 5:27 pm
jonyb4 :hmm whats that plunger then? not seen one of them before :oooh:
What ECU, MAF and throttle body are you running ?
Scott
sjoyce666
Postby jonyb4 on Sun Jun 20, 2010 6:52 pm
umm BLOB 1.8 mondeo ecu, 2.0l TB on a H.O inlet, and the maf i honestly have no idea what it is, this one came with the Si engine loom i bought when i done the engine conversion, i can only imagine its from a 2.0
but i havent a choice atm my 1.8 maf was franked, made it run worse than it runs now
guess i should start by getting a 1.8 maf :rolleyes:
Postby Smo on Sun Jun 20, 2010 7:47 pm
jonyb4 :umm BLOB 1.8 mondeo ecu, 2.0l TB on a H.O inlet, and the maf i honestly have no idea what it is, this one came with the Si engine loom i bought when i done the engine conversion, i can only imagine its from a 2.0
2.0 MAF is right for your ECU :)
You need 1.8 or 2.0 injectors from a Mondeo though (or late Escort 1.8 ones)... What are you using?
Smo
Postby jonyb4 on Sun Jun 20, 2010 7:57 pm
late if you call it 1997 1.8 escort injectors
Postby Smo on Sun Jun 20, 2010 8:10 pm
They should be fine then :)
Make sure you've not developed any air leaks at all.
Also, are you 100% sure the timing is spot on?
Smo
Postby jonyb4 on Sun Jun 20, 2010 8:42 pm
90% yea lol
screw driver on piston 1 trick at tdc, and the cams were locked up, held the pullies lossend the pulleys and tightend the belt ncie and tight, held the pullies and tightened them up
Postby Minstral on Sun Jun 20, 2010 8:54 pm
looks a lot better than before smo man. you'll have to take me out in it as i still aint been out in it since you've high comped it
Minstral
Your car: *
Postby Smo on Sun Jun 20, 2010 11:45 pm
jonyb4 :90% yea lol
Might just be worth checking to make sure they're definitely spot on... I have to admit, I've never done it using the piston position and always done it using the mark on the sump - never ever had a problem! If I were you, I'd spin the bottom pulley round to TDC using the sump as a guide, get it so that the second mark on the pulley (clockwise) is in line with the diagonal step on the sump, and then whip off the cam cover just to see where abouts the cams are. You never know, the crank may have moved ever so slightly when you tightened the belt up or something - it's very easy to do! You only need it to be a tooth out and it can run a bit pants.
Toby, your Polo is probably more fun than mine :lol:
Smo
Postby jonyb4 on Mon Jun 21, 2010 1:39 am
grr, problem i have is ive painted my crank pully, quite thickly too :rolleyes:
so cant see no markings on it :lol:
well it still pulls same as before if not more so for now im not too fussed
it can stay liek it im not bothered enough to strip it back down again :rolleyes: :(
Postby mrorange2 on Tue Jun 22, 2010 9:23 am
Looks nice mate hope i can get my engine bay as clean as that one.
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby Excursion on Tue Jun 22, 2010 11:29 am
I find the standard mark is slightly out, so I always use a dowel down the spark plug hole. When building an engine it's a good idea to use a gauge to get exact TDC.
Postby jonyb4 on Thu Jun 24, 2010 12:46 am
mrorange2 :Looks nice mate hope i can get my engine bay as clean as that one.
aye my si too :wink: its stinking under the bonnet
orange (tim isnt it?) do you have any thing like mirrors colour coded in caymen blue lieing around you dont need to do you? seing the si is the same colour lol :Q
Postby Smo on Thu Jun 24, 2010 8:31 am
If your Si is blue it's probably petrol blue :)
Smo
Postby jonyb4 on Thu Jun 24, 2010 11:53 am
lol every ones saying that, i feel a right muppet :rolleyes:
cheers mate
Postby Sphinx on Thu Jun 24, 2010 4:03 pm
I'm really starting to miss the nice simple Fiesta engine bay :lol:
Mine's not too bad but then I see that and think 'ahhhh, see if you wanted to work on...that bit, you can actually get yours hands on it'
Looking clean lover :aviator:
Postby Smo on Thu Jun 24, 2010 6:17 pm
Are you lot looking at the same pictures as me? Seriously, there's still loads to do :lol: My battery tray is soooooooo bad, and I've still not painted the bit by the driver's side strut top :lol: That's been like that for years now!!!
Smo
Re: Popular Plus 16v - 17/07/10 - Page 11
Postby Smo on Sat Jul 17, 2010 7:34 pm
Three words:
Knackered gearbox. Again.
Smo
Re: Popular Plus 16v - 17/07/10 - Page 11 - Knackered Gearbox
Postby Rhinopower on Sat Jul 17, 2010 7:59 pm
Hahahahaha, i can only laugh :)
Now you need to do it quicker than me and dave 8)
Rhinopower
Your car: Volvo FH330
Postby jonyb4 on Sat Jul 17, 2010 8:08 pm
lol oh no
Postby Smo on Sat Jul 17, 2010 8:15 pm
Rhinopower :Hahahahaha, i can only laugh :)
I knew it would happen, just wasn't sure when :lol:
I'm risking Ford Fair with it and will worry about it next year!
Smo
Postby ~nomad~ on Mon Jul 19, 2010 12:45 pm
sure it will be fine. I am sure own new one is whining a bit, might just be paranoid lol
~nomad~
Your car: Breadvan
Postby Rhinopower on Mon Jul 19, 2010 12:59 pm
its the cams whining, not the box :)
ours was whining for 600 ish miles before it gave up
Rhinopower
Postby ~nomad~ on Mon Jul 19, 2010 1:43 pm
I reckon the box has a little whine tbh
~nomad~
Your car: Breadvan
Postby Smo on Mon Jul 19, 2010 2:20 pm
Well hopefully mine will take one more day of abuse and then I'll get another in :lol:
Hopefully sourced one!
Smo
Postby Smo on Mon Jul 19, 2010 9:02 pm
Took it out for a bit of abuse this evening and the notchiness and inability to get it into gear sometimes seems to have cleared up now.
It was actually quite alright when it was cold, but it was when it warmed up that it started playing up... Really not sure what's going on with it.
Not sure whether to go get this possible gearbox tomorrow or not... I'm a little unsure on the ratios so I may wait until I can get one I'm certain of :-? :)
Smo
Postby Sphinx on Tue Jul 20, 2010 7:30 pm
Have you ever thought it might be you? i've heard you grab your knob pretty hard at times and are a bit violent with it.
Postby Capri on Tue Jul 20, 2010 8:42 pm
Sphinx :Have you ever thought it might be you? i've heard you grab your knob pretty hard at times and are a bit violent with it.
I've grabbed his knob and it seemed fine to me at the time. :-?
Capri
Postby Smo on Tue Jul 20, 2010 10:48 pm
I guess I just go that little bit too far with my knob sometimes :(
Alex, you had some very nice things to say after that moment... It made me feel extra tingly inside :oops:
Smo
Re: Popular Plus 16v - 22/07/10 - Page 11 - Hunting Idle Cured
Postby Smo on Thu Jul 22, 2010 11:12 pm
Yeah baby! Tonight, I have cured my hunting idle issue that I've had ever since some caveman bodged a Zetec into my car... Oh hang on, that was me.
"What was it?" I hear you ask... Well, I had always ruled out the lambda sensor (which has pretty much killed any sort of build up to me revealing what the cause was now), purely because it's always driven fine and even when I had it rolling roaded, the fuelling was spot on.
I'd looked at buying a new sensor through work purely for the sake of replacing it as a service item, but could never justify it because I didn't see that it could be the problem. However, we've recently taken on a new supplier of lambda sensors and the prices were a bit more attractive :) So today, I took out my old one and tested it over a nice hot flame with a digital multimeter... Unfortunately, it seemed to be fine, producing a voltage pretty quickly over the flame, and reducing back to near enough 0v immediately when I took the sensor away from the heat. "Bum" I thought. (I wasn't literally thinking about a bum, by the way.) But I just felt like I hadn't gotten anywhere... again!
Randomly, I decided to check for a resistance over the heating element wires, not actually expecting there to be a problem, but there it was... No resistance at all! So I tested the new one, which showed there was some sort of continuity across the element wires. Excited about my find, I ran outside and screwed the new sensor into my downpipe, plugged it in and started the car, and... and... My god, no more hunting idle! :lol: (Can you tell I was very excited about this?)
It all makes sense, though. When it's idling, the exhaust gases are probably not getting hot enough to heat the sensor, hence the requirement for the heating element, and therefore the sensor wasn't operating at idle, and possibly not at low speeds around town, either. With the new sensor, it is impossible to make it hunt, something I used to be able to make it do the very moment I came to park up somewhere or when sitting at traffic lights for anything over 30 seconds to a minute or so.
I'm so chuffed :D :lol:
Oh, but yeah, still have a noisy gearbox :cry:
Smo
Postby bakewell001 on Fri Jul 23, 2010 9:12 am
bakewell001
Postby Excursion on Fri Jul 23, 2010 11:00 am
A lambda doesn't measure heat, it measures o2 - it would be reading it's maximum in most environments other than an exhaust.
EEC-IV only operates in closed-loop mode up to 3k or so, and not at all in WOT mode, so the lambda sensor wouldn't have much effect on your rolling road run.
It's pretty easy to spot a broken Lambda as the low-speed characteristics change and response isn't crisp, you can also hear it in the engine note.
Postby Minstral on Fri Jul 23, 2010 2:04 pm
no update from tuesday evening :P
Minstral
Your car: *
