petrol tank differences
Postby KINGHORN on Wed Jul 30, 2003 3:27 pm
is my 1.1hcs tank different to an xr2i 8v 1 as im putting in a xr engine and dont no wheather i have to change the tank or not. id rather not do it if possible
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
KINGHORN
Postby Project on Wed Jul 30, 2003 5:02 pm
If you have an injection engine, then you can keep the tank.
Otherwise, no - you need a new tank.
Project
fiftyoneCL
fiftyoneCL
Postby KINGHORN on Wed Jul 30, 2003 8:04 pm
engine is single point i think
its an m reg 1.1
KINGHORN
Postby FezzR on Wed Jul 30, 2003 8:13 pm
it will run, but i personally would go for 2i or rst pump,
depends on the condition of ur pump too.
i would imagine the 2i runs a higher pressure than the spi system so the spi pump may not be up to the job
HTH
Ian
FezzR
God Damn Lazy
God Damn Lazy
Postby Project on Thu Jul 31, 2003 2:19 am
Think FezzR's right on this one - I'm fairly sure the pumps are different internally.
For the sake of completeness, use the complete pump and sender unit from an EFi Fiesta.
Project
fiftyoneCL
fiftyoneCL
Postby KINGHORN on Thu Jul 31, 2003 10:34 am
CHEERS
SO KEEP THE TANK JUST CHANGE PUMP AND SENDER
KINGHORN
Postby FezzR on Thu Jul 31, 2003 7:58 pm
proj, u make it sound like i have little technical knowledge :P
as for tank all the same, unless u wanna look at summink like mk4/5
donno if theres any diff. mk5 is prob plastic not really worth hassle IMO
if u dont have a pump i think moondust has a tank and pump up for sale, IIRC the pump is not very old
FezzR
God Damn Lazy
God Damn Lazy
Postby 8skellerns on Thu Jul 31, 2003 8:15 pm
MK5 is still metal :rolleyes:
Drives: MK2 Fiesta 1.4 Ghia (1988) Focus 2.0 Zetec (2003)
8skellerns
Postby FezzR on Thu Jul 31, 2003 8:43 pm
8skellerns :MK5 is still metal :rolleyes:
that a bit poo
FezzR
God Damn Lazy
God Damn Lazy
Postby KINGHORN on Thu Jul 31, 2003 8:58 pm
IV GOT A WHOLE XR SO DONT NEED ANY PARTS
EXcept a clutch
KINGHORN
Postby Project on Fri Aug 01, 2003 1:50 am
FezzR :proj, u make it sound like i have little technical knowledge :P
You do that all by yourself mate ;)
Project
fiftyoneCL
fiftyoneCL
Postby FezzR on Fri Aug 01, 2003 7:41 pm
EFI should hold 3 times the amount of fuel pressure at idle than that of CFI, so i should imagine running it on CFI pump would loose quite a bit of power and run lean
FezzR
God Damn Lazy
God Damn Lazy
