Nick's ST
- - Danny Boy -
- Your car: Fiesta Si 2.0
Re: Nick's ST
Right-o, here's the latest updates...
Rear axle spacers fitted, brings the wheels out into the arches a little more so they no longer look lost, and I've also fitted two cold air feeds in place of the foglights. These need a bit more fettling until I'm totally happy with them. The passenger side one routes cold air to the K&N filter, and the drivers side one routes cold air to the power steering reservoir which is known to boil the fluid when the engine is hot.
- dontpannic
Re: Nick's ST
think id prefer having the lamps
looking fantastic nick
Re: Nick's ST
Burman id be more worried about your power steering fluid boiling when youre carrying out evasive manouvres on the motorway you maniac
Get an autospecialists inlet,and give that a cold air feed
- hb69
- Your car: Fiesta 1.1 LX
Re: Nick's ST
Axle spacers look good. This angers me though as me and smo couldnt get my poxy abs sensor out to get mine on so they wont be on for ford fair unfortunately
- hb69
Nick's ST
Yeah, one of my abs sensors mounting hole snapped. Grabbed the other one with a pair of mole grips!
They feel really good, but I'm getting some really strange noises that I'm going to have to investigate. First is the warped disc noise (probably is warped discs) and the other is a tinny rattle when going over bumps in the road - sounds like a loose washer or something. Going to take them apart tomorrow and have another look.
- dontpannic
Nick's ST
Wheel bearing is going! Just ordered a replacement one, then just got to get it fitted before next week!!
- dontpannic
Nick's ST
The bolts supplied were slightly too long so I've cut those down a bit, the discs are definitely warped but NSR has a bearingy grindy noise lol
- dontpannic
Re: Nick's ST
jack the wheel up and check for play
i thought the bearing in the mk2 were gone, went to replace it, bloody hub nut was loose as hell, lucky they use split pins, both sides
Nick's ST
It's not far enough gone to cause play yet, it's just very loud.
- dontpannic
Re: Nick's ST
Are the bearings not part of the discs?
- hb69
Re: Nick's ST
Nope, sadly not, they're pressed into the rear hub itself. Just short of £20 for a new bearing though.
I'm lucky that the snapped ABS sensor still works!
- dontpannic
Re: Nick's ST
What mileage has this done, Nick? These use the Focus bearings at the rear don't they?
Re: Nick's ST
Just clocked over 50k, Mark.
I think I put extra stress on the bearing though - when I originally fitted the axle spacers, the bolts supplied with the kit were too long, instead of going through the hub they stopped at the end of the thread and although looked done up, there was a small gap between the hub and the axle. I then had to take a heavy load so I'm thinking that's probably done it.
It's either that, or iron filings from when I was cutting down the first bolt to the shorter length.
Now I know how long the bolts are supposed to be (34.5mm), I can look at getting proper bolts rather than ones cut down to an approximate length.
I believe they are the same as the Focus bearings.
- dontpannic
Re: Nick's ST
Sheriff Burman :Just clocked over 50k, Mark.
Ahh, OK. Thanks. It's not done a big mileage then. I ask because I have the same hubs as what you have there,and I want to know how long they'll last.I don't think Ford specified particularly durable bearings in these! I'm not sure of any uprated replacements though.
Re: Nick's ST
The bolts shouldnt need cutting down surely as its a ford part
- hb69
Nick's ST
The kit I got was one of the Pumaspeed ones, the bolts Pumaspeed supply are 40mm long but if you put them on as they are, two of them rub the ABS ring, and the others don't go in far enough.
Mark - I'm led to believe the focus hubs eat bearings anyway if lowered. I haven't come across any updated ones so I think it's just a case of replace when necessary.
This one failing I'm certain is my fault, one way or the other!
- dontpannic
- dontpannic
Nick's ST
And back out again. The garage couldn't do it themselves so took the hub to another local garage with a press. But instead of pressing the bearing in, they heated it up. That's now f**cked this bearing up, so I've now ordered a second bearing which he'll press in instead of heating it.
Luckily the labour charge has been waived.
- dontpannic
Re: Nick's ST
Heated it?
I hope the part charge was also waived!
Re: Nick's ST
It's not as though they don't have a press either
It's a cash in hand job, I supply the bearing and it will get done properly this time.
- dontpannic
Re: Nick's ST
Sheriff Burman :It's not as though they don't have a press either
So you had to pay for 2 bearings?
- bakewell001
Nick's ST
Yeah, it's a bit of a difficult situation. The garage who I'm dealing with are removing and replacing the hub but a second garage did the bearing, I have no deal with the second garage who actually f**cked the bearing. If it was a larger amount of money I'd be worried but the bearings are fairly cheap OEM.
- dontpannic
Re: Nick's ST
ehh?! confused now
btw sounds like you have the 2 pairs of bolts in the wrong way around? if 2 didnt reach long enough, and the other 2 too long, wouldnt switching them around sort it?
as it sounds like the axle is thicker on one side than the other (or top/bottom)
that probably wont go understood, dont know how to word it lol
Re: Nick's ST
Its fairly simple
Me -> Garage 1 -> Garage 2 -> Garage 1 -> Me
Garage 1 doesn't have a press
Garage 2 does have a press, but labour is mucho expensive
I take my car to garage 1 (who do cash in hand jobs), they take off the hub and take the hub to garage 2 to get them to press the new bearing in, this is then brought back to garage 1 to fit back onto the car.
As for the bolts, its difficult to explain. Two of the holes on the hub have open ends, two of them stop at the end of the thread. When I put the long bolts in, the two open ended holes the bolts went all the way through and hit the ABS ring. The other two went into the hub as far as it would go, but didn't hold the hub to the axle quite correctly. By shortening the bolts, they don't go through the open ends, and they don't reach the end of the hub assy thus holding everything together properly.
- dontpannic
Re: Nick's ST
well thats squared away, this is why i want to have a press at home... so annoying relying on a garage for the bearings
- dontpannic
- Tweek
- Your car: VW Golf GTD
- - Danny Boy -
Re: Nick's ST
Sheriff Burman :7.1 to 60.
Well happy with that, a big improvement over the 8.4 of last year
Good one!
Re: Nick's ST
wow... impressive
how though? relatively standard aint it?
Nick's ST
Relatively standard if you don't count the stripped interior, k&n, decat and cat back
Rolling road day in a couple of weeks, find out what she's running
- dontpannic
Re: Nick's ST
stripped? cheating tugger
my "high spec" interior weighs me down
