Need help wiring in push button start
Postby bretjaso07 on Wed Aug 14, 2013 2:12 pm
Hi, I've picked up a push button start which I need help wiring in my fiesta, the car will still be used for road use but won't use the key as my barrel has nakered. On my barrel is a red wire, black , black wire and blue wire and a yellow wire. The switch panel I picked up had a plane style flick switch and beside that is the start push button. The kit also come with a relay. 30 - 85 - 86 - 87. I've looked it up but can't find out how to do it
bretjaso07
Your car: FXRT
Re: Need help wiring in push button start
Postby mikeymikeyp on Wed Aug 14, 2013 3:42 pm
have you got pats
mikeymikeyp
Postby bretjaso07 on Fri Aug 16, 2013 1:08 pm
I don't think so
bretjaso07
Your car: FXRT
Postby mikeymikeyp on Fri Aug 16, 2013 4:04 pm
if its pats youll need the key
i wired mine in but its on the trailer and im not taking it off to check but heres what i mind
2 connectors on the push 1 earth and one cranking live do this first and check it works with the key and ignition on
and i think it was the ignition live and an earth on the flip switch
do you have a multi meter
mikeymikeyp
