My MK2 Turbo
My MK2 Turbo
Postby xrt-mart on Sun Mar 19, 2006 10:42 pm
The car was originaly purchased as a run around while I fitted a ERST engine to my old fiesta. But the look of the STD XR won me around after sitting on my dads drive for 12 months then this happend a few years ago now...
1st not rebuild but engine install.
Ended up like this at FITP 2004..
xrt-mart
Postby xrt-mart on Sun Mar 19, 2006 10:44 pm
heres removing the engine probably 12 months after last pics..
and de kitted for propper repairs. NOT like who ever did the last lot.
The started to remove the interior (just the dash for now, gets the wiring out of the bay!!! )
xrt-mart
Postby xrt-mart on Sun Mar 19, 2006 10:47 pm
Picked up my 2ltr mondeo zetec engine last week :)
need to get the pistons fitted into it now :lol:
I already have a full 1.8 escort zetec to take the sump, pick-up pipe, inlet manifold etc . I need to sort some niggly bits like getting the injector convertors from chopper (on XRTwo.com)and fuel rail from focus zetec
Then it engine boring and machine etc.. off to Ian howell for that lol
thats it for now
mart
xrt-mart
Postby Pez on Sun Mar 19, 2006 10:51 pm
Awesome! Love Mk 2 XR2's, that'll be a nice tool when its done, good luck with the project, keep us updated :)
Pez
Postby xrt-mart on Thu Mar 30, 2006 12:10 am
Update time finaly :lol:
Ive managed to remove the inlet off the 2ltr zetec and check the fit of the 1.8 injector plate and manifold which was fine.
This allowed me to get the plate sent off to Chopper who is a GOD and managed to make me some injector convertors for the plate and press them in for me (also cleaned it up a treat too and is highly recommended!!)
with trial fit FRST injector..
Chopper has also made from scratch for me a convertor for the 2ltr TPS allowing me to put the FRST one on as it is different to the zetec.
and finaly both built up together
I still need the fuel rail as mentioned previosly though.
Also heres a pic of the intercooler to be used :)
Also thanks to streetdragster for the diagrams of the TPS convertor :bonkers:
mart
xrt-mart
Postby ianFRST on Thu Mar 30, 2006 6:24 pm
:Q :Q :Q
engine bays look sooooooo nice when theres nothing in there and they have just been painted :Q :bonkers:
ianFRST
Postby heeman10 on Thu Mar 30, 2006 10:59 pm
Did Ian recommend the Arias pistons? Has he made any comments about them?
Postby xrt-mart on Fri Mar 31, 2006 1:34 pm
I hope so I got them from him :)
They are originaly intended for the duratec so its overbore time for me.
Also they are rated to 900BHP so that will do :lol:
The rod needs the little end honing to 21mm as though.
mart
xrt-mart
Postby heeman10 on Fri Mar 31, 2006 1:47 pm
Cool, how much do your bores need stretching by to fit those? Should be safe using 900bhp pistone eh? :lol:
Postby ianFRST on Fri Mar 31, 2006 1:55 pm
heeman10 :Cool, how much do your bores need stretching by to fit those? Should be safe using 900bhp pistone eh? :lol:
most are 86mm :wink:
ianFRST
Postby heeman10 on Fri Mar 31, 2006 4:32 pm
Duratec pistons??
Postby xrt-mart on Fri Mar 31, 2006 7:59 pm
bore size 85.5mm
compression height 29.50mm
pin diameter 21.00mm
flat top
Ian says 7.4:1 compression ratio
HTH mart
xrt-mart
Postby xrt-mart on Sat May 06, 2006 8:19 am
bit of a update
tested the manifold just to make sure and all was fine..
while I was there thought that I would try the other half of it to get an idea how much space there was left to fit the fuel rail (not alot is the answer :lol: but the ISCV can have its face skimmed to help)
next i removed the seats and carpet to inspect the inner sill/floor and prepare for welding the outer sills. They dont look to bad IMHO but need 1/2 patches. excuss the mess too :oops:
and after looking at MK's thread thought id show you what I meant about my intercooler. this is the position I want it to be in..
excuss the blue paint. the car isnt going any different colour :lol:
Also bought some rear caliper brackets off big rich
still got a lot to do :lol:
mart
xrt-mart
Postby Sphinx on Sat May 06, 2006 9:54 am
I'm confused, why is the battery track back in the last pics? :s
Postby heeman10 on Sat May 06, 2006 9:58 am
Floor looks very good for a Mk2 :)
Postby xrt-mart on Sat May 06, 2006 9:59 am
I want to keep the battery in the engine compartment this time and there is moe space with efi.
Its not welded in yet but i will do that when I get round to it.
xrt-mart
Postby xrt-mart on Sat May 06, 2006 10:00 am
the floor is the best Ive had. This is my fourth :lol:
Thats why ive kept this one
xrt-mart
Postby xrt-mart on Wed May 17, 2006 11:14 pm
Had another go at the inlet after getting my fuel rail off mk1turbo at fitp. (Thanks mate!!!) here's the result.
how it came
1/2 stripped
fitted to sandwich plate and standard FRST injectors
and trial fit to the engine
It looks like it will work well :D All I have to do is grind off the original mounting lugs and use some munson rings ( pipe clamps for plumbers :wink: ) to hold it in place thanks to streetdragster for the idea. The ISCV needs to be milled to allow it to fit in the gap though but thats not much of a problem.
It allows use of the FRST fuel pressure regulator as well :)
I still need to sort the thorttle body out with the correct linkage, which I still need to find, and think of a way to get a idle air bypass on the throttle as the zetec doesnt use one and the FRST does. I am thinking of using a bleed valve with two connections (like a restrictor not to bleed) one connection to the charge carrier and one to the inlet. Any opinions?
Thats all for now
mart
xrt-mart
Postby StreetDragster on Fri May 19, 2006 8:02 am
xrt-mart :
mart
No problem pal, the injector converters look familar too :)
Good effort by the way, i have a soft spot for Mk2 XK2's, i really want one as a track weapon
Matt
http://www.StreetDragster.com
StreetDragster
Postby xrt-mart on Mon May 22, 2006 11:34 pm
The idea for the munson rings holding the fuel rail comes from you too :lol:
xrt-mart
Postby Growler on Mon May 22, 2006 11:58 pm
fecking hell yu could eat yur dinner off that
what you doing with old engine?
have you canabalised anything?
Mint H Plate XR2i in Black
Growler
Postby xrt-mart on Tue May 23, 2006 1:33 pm
The ERST engine is long gone via ebay mate :( needed the money to do the ZT.
mart
xrt-mart
Postby Mikee_RS on Tue May 23, 2006 7:37 pm
looking good mate
a zt in a mk2 fiesta will seriously chip
Image Image Image
Mikee_RS
Car: 1995 Ford Fiesta
Postby xrt-mart on Wed May 24, 2006 10:58 pm
:Q
xrt-mart
Postby xrt-mart on Thu May 25, 2006 7:33 pm
Mikee liking the look of your Fezz mate :Q just had a look at your "my thread"
mart
xrt-mart
Postby xrt-mart on Wed Jun 07, 2006 7:12 am
Been at it again. Trying to remove the sealer/sound proofing from the inside so I know what im dealing with (and loosing some weight too :lol: )
Not a lot to show but
a couple extra patches to do mainly on the passenger sill at the back :cry: but not to bad. Think I will put inner sills on both sides to go with the outer though just to be sure. Need to get scraping at the underneth now :(
mart
xrt-mart
Postby seano47 on Wed Jun 07, 2006 9:56 am
great project mate comming along good
Mk6 Fiesta Flame
seano47
Postby jayrs on Wed Jun 07, 2006 12:23 pm
glad to see a mk2 being done.
i miss my old xr2's a lot. they were great fun.
what fuel rail is it that you used in the end mate?
Postby xrt-mart on Wed Jun 07, 2006 11:05 pm
The project is coming along slowly :lol:
The fuel rail is a balcktop zetec item. Its the same on Focus and mondeo so I believe.
mart
xrt-mart
Postby jayrs on Wed Jun 07, 2006 11:08 pm
xrt-mart :The project is coming along slowly :lol:
mart
cool, be sure to post up full details on it like what had to be done to use frst injectors etc, not that im gunna do it just i would like to know the score.
some nice work gone into it i see mate.
makes me really wanna get another xr2 :( :lol:
Postby xrt-mart on Wed Jun 07, 2006 11:12 pm
will do mate. Looks pretty straight forward.
I need to cut off the mounting lugs and use some munson rings like streetdragser used on his. The FRST fuel pressure regulator is a straight swap. The ISCV will need milling a few mm though for it to clear, but its still a available, cheap and easy way around the injector problem.
mart
xrt-mart
Postby jayrs on Wed Jun 07, 2006 11:23 pm
xrt-mart :will do mate. Looks pretty straight forward.
mart
yeah it is, i didnt think about this when i considered doing a ZT as i have beiges in my FRST, and dude to paying out for other injectors and ecus etc i went with rebuilding my frst lump.
doh. :lol:
Postby jayrs on Wed Jun 07, 2006 11:26 pm
just a thought, how come ya never used the cvh EFI fuel rail?
Postby xrt-mart on Wed Jun 07, 2006 11:31 pm
The cvh efi fuel rail is just wrong for the manifold. The injectors are on the piss like the manifold. This way it keeps the injectors central like they should be and you might aswell mod this one to a FRST because neither are a straight swap.
Also yes keep your FRST fuel and management set-up. Get a 2.0.ltr zetec engine put some low compression pistons and with a rebuild your laughing.
mart
xrt-mart
Postby jayrs on Wed Jun 07, 2006 11:36 pm
xrt-mart :The cvh efi fuel rail is just wrong for the manifold. The injectors are on the piss like the manifold. This way it keeps the injectors central like they should be and you might aswell mod this one to a FRST because neither are a straight swap.
mart
yeah i looked into it big time but the live mapping put a damper on it, dunno if i really needed it or not but seeing as my car is a FRST and i had all the bits there as it was only a big end that went i decided to do that, its all done just needs putting together but i'll keep it in mind in case i get a mk2 as i was thinking of getting one for a winter car and dropping a 2.0 mondeo lump in, non turbo but ya never know :lol:
