My car!! UPDATE
Re: My car!!
Postby Dave G fsi on Thu Dec 17, 2009 2:39 pm
Looking good mate. :aviator:
Will it not fail mots without the towing eye on the back?
Dave G fsi
Your car: Mk1 FRS and FRST
Re: My car!!
Postby white diamond on Thu Dec 17, 2009 3:26 pm
im not too sure iv heard as long as theres one on the front it should be ok, if not il have to make one up under the rear bumper somewhere
old fords never die...............they just get faster!!!!!
white diamond
Re: My car!!
Postby Big_Phil on Thu Dec 17, 2009 6:32 pm
Mine has been through 2 MOT's with no towing eyes and hasn't failed :-?
Should be okay mate.
Big_Phil
Re: My car!! UPDATE
Postby white diamond on Tue Nov 30, 2010 1:03 am
corrr been ages since an update.
well after a lot of hard work put in to the car i had finished all the body work n had it painted! looks the nuts now!!
it now has a half stripped interior aswel, painted the dash n all plastic in black so they look new, the rear is fully carpeted with black carpet
unfortunatly the head gasket went so it is now back off the road again. i have a new headgaset kit to fit along with a new thermostat, plugs, leads, oil + filter
whilst it was stripped down i thought i would give 'polishing' a try!!! it is cast alloy so i had to sand back all th casting marks with 80grit, then 120, 240 etc etc
then went through the wet sanding with 400, 600, 800 then 1200. finished off with some autosol metal rubbing compound.
heres the results!!!!!
thought i would polish up my thtottle body so it flows better, also removed one of the springs so it opens more freely. painted the brackets so it looks a bit newer
Before!
After!
Shortened my gear lever by an inch so it gives a 'short shift' effect, it now has a much better feel to it.
Before!
After!
white diamond
Re: My car!!
Postby white diamond on Tue Nov 30, 2010 1:09 am
Now have 1600 escort brakes to fit, vented discs and bigger calipers
Also got some H&R coilovers to go on!!!
Going to strip them all down an give them a repaint so its all new n fresh!
white diamond
Re: My car!! UPDATE
Postby jonyb4 on Tue Nov 30, 2010 3:44 pm
TB and inlet look amasin man!
did you get the coilovers from the Hog?
Re: My car!! UPDATE
Postby white diamond on Tue Nov 30, 2010 7:55 pm
Yes coilovers bought from THEHOG
white diamond
Re: My car!! UPDATE
Postby jonyb4 on Wed Dec 01, 2010 12:19 am
lol ya bugger i was going to buy them
Re: My car!! UPDATE
Postby xr2irhys on Wed Dec 15, 2010 9:06 pm
lol coilies get about dont they :P ;) fiesta is looking good
xr2irhys
Car: 1996 Ford Fiesta Classic
Re: My car!! UPDATE
Postby xuxumi on Fri Dec 17, 2010 9:30 am
So looking great car !
xuxumi
Re: My car!! UPDATE
Postby jonyb4 on Fri Dec 17, 2010 8:53 pm
you realise 1600 escort brakes are no bigger? only difference is theyre ventillated, much like the XR/SIRS brakes
Re: My car!! UPDATE!! Back again 2014!!! 2litre zetec!!!
Postby white diamond on Mon Jan 06, 2014 12:54 am
well im unsure why I stopped using the site and posting updates!!
anyway onto some pictures!!!
back in 2011
at a local cruise with a mates mk4 puma powerd fez
I then fitted some 13inch 5 spokes which I sprayed imp blue
I then drove it like this for ages attending various shows meets cruises etc!!
the car always got lots of attention!!! :D :D
]Image[/url]
white diamond
Re: My car!! UPDATE
Postby Gus!! on Mon Jan 06, 2014 11:37 pm
What happened to the cr in the end then mate??
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Previous
