my 2.0 si...reversed into :(
Re: 2 litre si and xr2i rep, roose hoses & anti roll bar convo
Postby fiestasiphil on Thu Jan 06, 2011 4:06 pm
been spending some money this week
bought a recon alternator for my 1.8 xr2i front bracket got it from motor parts direct for £120 exchange it look the same as my si one i exchanged it for but its slightly different to where the manual adjuster bolts on to :)
also i went down to a powder coaters yesterday about 10 miles away from me with all these parts plus the exhaust hanger brackets which bolt on to the lower strut brace :)
im having the radiator fan surround, coil pack bracket done in the black chrome finish same to my gearbox cradle, and having the front mount and front engine mount bracket done in silver and the exhaust hangers x2 and battery clamp done in satin black
it came to £50-60 :) plus VAT at 20% :x oh well not too bad
pick them up in 2 weeks cant wait :)
also took the front bumper off the si and cleaned and polished behind it although i forgot to get a pic of that, but i also removed most pas stuff from it minus a few pipes at the back and the rack :)
also i tried the vinegar trick on the rear exhaust bracket which bolts up on the rear axle it was really rusty and flakey, but it came up like new after leaving in the a small tub on vinegar and scrub with a tooth brush then i painted it hammerite smooth :)
also spent £16 on all new bolts for the alternator and front mount bracket and rear anti roll bar ones gotta wait till next week to pick them up :)
thats it for now but on the 15th january the cylinder head is coming off then to be skimmed and have new stem seals fitted all with genuine parts :)
its all starting to come together now :)
fiestasiphil
Postby jonyb4 on Fri Jan 07, 2011 3:38 am
looking good mate
its your cars shade of pertol blue i like, or is it just the new paint fromt he respray?
looks greeny/blue where as mine is more blue
thats alot of money on painting them bits few ppl will see :(
not my cuppa tea
Postby RS rob on Fri Jan 07, 2011 8:52 am
its called doing things properly without cutting corners,
his car, his choice
good on you phil
RS rob
Postby FiestaBen on Fri Jan 07, 2011 1:30 pm
mmm I love power coated parts, especially engine parts!! :Q
Was thinking about getting similar parts on mine done but no places around here that I know off!!
Going to look smart, every bit makes a huge difference!
FiestaBen
Car: 1995 Vauxhall Astra
Postby fiestasiphil on Fri Jan 07, 2011 3:38 pm
jonyb4 :looking good mate
not my cuppa tea
its not petrol blue mate its mallard green :wink:
ive owned the car for 6 and half years never plan on selling it and really like the look of the other powder coated parts i already have, so thought why not :) it will last a lot longer and look nice too :)
RS rob :its called doing things properly without cutting corners,
his car, his choice
good on you phil
cheers mate :)
FiestaBen :mmm I love power coated parts, especially engine parts!! :Q
thanks, i wasnt sure where the nearest one from me was i know there are a few around southend way i just did a search on google for the nearest one and wasnt far away and have a decent website...result :)
fiestasiphil
Postby FiestaBen on Fri Jan 07, 2011 8:35 pm
Can I have the link please? Essex isn't far from me so if worst comes to worst, I'll use the same one as you :lol: :Q
FiestaBen
Postby jonyb4 on Fri Jan 07, 2011 9:31 pm
its green?!
jesus lol its very blue for a green
Postby fiestasiphil on Sat Jan 08, 2011 12:28 am
mallard green is pearlescent sometimes looks blue and sometimes even purple at night. Fiestaben will post up the link for you mate tomorrow morning :)
fiestasiphil
Postby fiestasiphil on Sat Jan 08, 2011 8:54 am
FiestaBen :Can I have the link please? Essex isn't far from me so if worst comes to worst, I'll use the same one as you :lol: :Q
http://ctc-powder-coating.co.uk :)
fiestasiphil
Postby fiestasiphil on Tue Jan 11, 2011 10:17 am
well yesterday i took the cam cover off, the cams were full of mayonaise :( :rolleyes:
it was really bad, the engines going to need a full oil flush out once its all done and back together
also heres a pic of some of the stuff thats been taken off, most of it is pas stuff but thats no good to me now :)
i also gave the cam cover a polish but it didnt come up very well, so im thinking about getting it powder coated in the black chrome colour, although im not sure atm if it will match :?
also collected all my new bolts for the xr2i 1.8 alternator mount :) new rear anti roll bar bolts and new top front engine mount bolts and in the pic is the mk3.5 manual steering column grommit
also bought a new pillar cover for one side, havent managed to get the other side yet but going to fit this when my rs turbo pop out windows are in :)
also got a brand new fog light switch and some new exhaust clamps
im really looking forward to getting the cylinder head off on saturday :)
fiestasiphil
Re: 2 litre si...mayonaise and some new parts
Postby Excursion on Tue Jan 11, 2011 10:30 am
Ouch - has it been stood like that for long? You've may have corrosion on the bearing surfaces if so. As you're removing PAS anyway, you may as well remove the sump (easier without PAS!) and check one of the main bearings before you run it up.
Postby fiestasiphil on Tue Jan 11, 2011 10:36 am
Excursion :Ouch - has it been stood like that for long? You've may have corrosion on the bearing surfaces if so. As you're removing PAS anyway, you may as well remove the sump (easier without PAS!) and check one of the main bearings before you run it up.
a year a 8 months, i ran it up in september 2010 sounded lovely, but was guzzling water and puffing white smoke out the exhaust
fiestasiphil
Postby fiestasiphil on Thu Jan 20, 2011 9:22 am
update here
well on saturday my mate took the cylinder head :shock: :)
cylinder 1 failed on the head gasket :doh: explains the water being burnt off
also drained and took the sump off, when the sump plug was undone water came out first then the oil :hmm:
which was all brown and mushy
with the sump off it needed a massive clean as it was soo gunky and sludgy, also going to take the pick up pipe off and clean that at the weekend
and while it was off i decided prefect time to give it a freshen up
before
after
also bought some stainless steel bolts and washers for the sump
also my mate took the pas rack off and its now gone down the tip! :P
just the front anti roll bar left now
also painted the exhaust manifold, im not sure if it will last but i used heat proof paint for up to 500 degrees :doh: but not to bothered about it
also painted the throttle bodie as i real liked how my mates came up so thought i gotta give it a go :) i would have had it polished to go with the rest of the engine bay but i can't afford it, but this way cleans it up nicely :)
thats it for now, but at the weekend the steering should be pretty much manual :)
fiestasiphil
Postby jonyb4 on Thu Jan 20, 2011 12:45 pm
you probably could have gotten a few bob for that rack if its in working order
yuuuk im glad oil didnt make its way into the water, or vice versa in your case when my gasket went, i was lucky tht only the water got into the bore, or id be having to spend a small fortune on oil changes and flushing fluids like your going to have to :(
id say two changes and the much should be gone, give it a good warm up before changing it too
Postby fiestasiphil on Thu Jan 20, 2011 3:37 pm
jonyb4 :you probably could have gotten a few bob for that rack if its in working order
it was pissing out :lol:
yeh got plenty of oil for 2 changes 2 oil filters and 2 cans of engine flush :)
fiestasiphil
Re: 2 litre si...cyinder head off and pas rack binned
Postby jonyb4 on Thu Jan 20, 2011 8:43 pm
sound sliek its sorted then mate, the turning point is here, everything is bolt back up after this :)
you should come to combe, id love to see this out on track :)
Postby fiestasiphil on Fri Jan 21, 2011 1:32 am
jonyb4 :sound sliek its sorted then mate, the turning point is here, everything is bolt back up after this :)
yeh its a good track that, hoping to take it on the track at ford fair this year :)
fiestasiphil
Postby fiestasiphil on Tue Feb 01, 2011 7:19 pm
got some more powder coat stuff from my mates si, wishbones carriers, front and rear anti roll bars and front brackets
rear one has a few marks on it but should clean up
and a mint boot with rs spolier , to replace my boot at some point prob wont be for a while yet to be honest
also took the steering wheel off ready for doing the manual conversion
and my speedo stopped working on the white fiesta runabout so after some advice from dan, i took the the dials out and check the cable all seemed ok then took the other end of the cable off the top of the gearbox and it was broken
got a new one on order from fords so should be doing that at the weekend typical tho it snapped when i joined the A14 on saturday which is average speed camera capital :lol:
AND IT BROKE DOWN AGAIN! (7th time)
dodgy alternator one minute it charges then it doesnt so gotta buy another asap :x
fiestasiphil
Postby Ratspeed on Tue Feb 01, 2011 8:36 pm
Love the powdercoated stuff! :Q
Ratspeed
Postby jayrs on Tue Feb 01, 2011 9:08 pm
coming on well with the fez mate
bad luck with the white one though, wouldnt have that prob if it were red though :oops: :lol:
you get the bit of speedo drive out the speed sensor ok?
Postby jonyb4 on Tue Feb 01, 2011 9:30 pm
:( sad about the issues with the 1.3
the coated bits look good, good choice of colours, i got bit of a thing for yellow myself :)
Postby fiestasiphil on Wed Feb 02, 2011 1:21 am
jayrs :coming on well with the fez mate
cheers mate, yeh it came out really easily got a new genuine one coming in from dagenham should be here tomorrow :)
fiestasiphil
Re: 2.0 si,more powder coated parts, more hassle from runabout
Postby jayrs on Wed Feb 02, 2011 9:15 am
thought it would, but you alway6s get 1 that wont, ive had some people pm me in the past asking how to get it out and some havent been able to.
what they con you for a new speedo cable then? £30?
Postby fiestasiphil on Wed Feb 02, 2011 9:28 am
jayrs :thought it would, but you alway6s get 1 that wont, ive had some people pm me in the past asking how to get it out and some havent been able to.
yeh i thought it was going to be an arse,i used one of those screwdrivers with a point at the end not sure what there called, got it for £20 :) some on ebay secondhand go for that near enough :o
fiestasiphil
Postby jayrs on Wed Feb 02, 2011 7:38 pm
i know what ya mean mate
yeah i know mate, ebay is a ngithmare sometimes, and some people will pay way over the odds, i mean do they not shop around... :lol:
Postby fiestasiphil on Sun Feb 06, 2011 8:10 pm
well yesterday i picked up the engine bay parts i took down to the powder coaters
really chuffed with the results :)
and at the weekend my mate sean is helping me out with doing my manual steering conversion :)
fiestasiphil
Re: 2.0 si picked up engine bay powder coated parts :)
Postby Excursion on Sun Feb 06, 2011 8:20 pm
Very nice Phil. I might get my parts done.
Postby fiestasiphil on Sun Feb 06, 2011 8:59 pm
Excursion :Very nice Phil. I might get my parts done.
cheers mate :)
fiestasiphil
Postby jonyb4 on Sun Feb 06, 2011 9:17 pm
oh yes i like them, even the lumpy cast iron mount come up well, looks very fresh
i demand more pics fo the car going back together :D
Postby Phil Si on Sun Feb 06, 2011 9:38 pm
I cover my parts with powder when I get out the bath :lol:
How's my moderating? Call 0800-U-R-BANNED
Phil Si
Crack Smoker Of The Year 1999
Car: 2000 BMW 330 Ci
Postby jonyb4 on Sun Feb 06, 2011 9:47 pm
Postby Excursion on Sun Feb 06, 2011 11:35 pm
Phil Si :
I cover my parts with powder when I get out the bath :lol:[/quote
I bet Tash loves that :lol:
Postby Phil Si on Mon Feb 07, 2011 9:49 pm
Excursion :
Phil Si :
Snort it off my sack baby!! :rolleyes:
Phil Si
Postby fiestasiphil on Tue Feb 15, 2011 6:30 pm
fixed the runabout :) put a new alternator and speedo cable on it all good :)
what a pain getting off the old alternator was though :x mainly because of the power steering pump being in the way and so the only option really was to take the exhaust manifold off and one of the 3 studs snapped off where it meets the downpipe :doh: , luckly my mate was fixing his jaguar at the time so he sorted the stud for me with a nice new one :)
new alternator
speedo cable
also got genuine ford head bolts and cam belt for the si
and zetec inside steering rack limiters
and then on saturday i removed the si's pas column and seannysi and me fitted the manual one with the new steering knuckle and recondition manual steering rack
it all fitted nicely but wasnt without problems, and manual steering grommet was being a pain to get in place then with it all bolted up there was a grinding sound which turned out to be the spring on the column.
then today when i was fitted the interior parts back together more problems the surrounds for the steering wheel wouldnt fit, i was like noo!!! its the wrong column but i had fitted the column too far down in the steering knuckle the other end doh! but finally sorted it
hoping to be getting the cylinder head back on the car on saturday :)
fiestasiphil
Re: my 2.0 si manual steering conversion and runabout fixed :)
Postby jonyb4 on Tue Feb 15, 2011 9:45 pm
nice progress
woop shall be running soon then :D
take it easy for 200miles or so after the new gasket :wink:
