MOONDUST MONSTER update feb 2013
Re: SEG’S 2.1 ZETEC TURBO MOONDUST FRST
small update
fitted the the 2wd cossie 4pots with new hoses as well, along with the area six lower arms and new ball joints. atm the castor is WAY out
done a bit of work on the engine as well, fitted a new oil pump and timing belt.
- SEG1
Re: SEG’S 2.1 ZETEC TURBO MOONDUST FRST engine in 28/5/10
got the engine in yesterday, went in with no hassle looks like its all factory.
just need to wire in the loom ,fit both manifolds, custom downpipe and custom driveshafts.
- SEG1
- FRSJON
looks stunning
but lose the chrome,
- andymcd
andymcd :looks stunningbut lose the chrome,
theres only a little bit
whats too much?
- SEG1
getting there mate..
did you see my motor in performance ford
- FRST SILVER
FRST SILVER :getting there mate..
no havent had time to buy the newest issue .how was it?
going to buy one now
- SEG1
love how it all fits
decided what brake servo and master cylinder your going to run ?
- knuckles
- Your car: Fiesta Rs turbo
knuckles :love how it all fits![]()
the fiesta rs one is the only one that fits
- SEG1
- - Danny Boy -
- Your car: Fiesta Si 2.0
coming on nice mate.
how come you didnt paint the block and gearbox?
Looks great mate keep up the good work.
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
cheers guys
sent the driveshafts off today. takes three weeks to make them
i dono i should have painted the block and gearbox, might mask it all up while the exhaust manifold off
jayrs :coming on nice mate.
- SEG1
- AW3K
would love to try mate,but from that picture the servo looks way too big. the standard rs one sits about 10mm from the gearbox mount.
- SEG1
RS_seg :cheers guys
i dono i should have painted the block and gearbox, might mask it all up while the exhaust manifold off![]()
i would mate why ya can
the mondeo servo is massive, but its wider, not longer, so if you have 10mm in front, it might just fit
Saw this at topgear on wednesday mate, looks spot on. My friend was having some stuff done on his MK2.
- MK2 Jamie
1800 Jamie :Saw this at topgear on wednesday mate, looks spot on. My friend was having some stuff done on his MK2.
yeah spoke to your mate ,his mk2 was pretty mint. i liked the colour too.
- SEG1
loving the work mate, that cam cover looks mint
big engines need big gearboxes
Re: SEG’S 2.1 ZETEC TURBO MOONDUST FRST small update
FRST SILVER :how you getting on with this mate
hi mate, yeah i have done a lot mate, just haven’t had time to update the thread.
manifolds are both on ,turbo has been fitted with a custom down pipe and turbo damper, omex 710 has been wired in with a base map. roose hoses have been fitted along with the grs intercooler and rad. custom driveshafts have turned up and fitted.brakes sorted, hydraulic clutch tested and working.
few other bits and bobs that i have forgotten.
Drove it the other day ,the tracking is way out!lol
Needs a few small bits done then mot tax and insurance!
few pictures from a month ago,i will get some more updated ones
- SEG1
looks great mate
are they dave MAC shafts?
- andymcd
andymcd :looks great mateare they dave MAC shafts?
no there from rob swift @ elite transmissons. very helpful company
- SEG1
when you going to come and buy a new brake fluid reservoir and header tank
- knuckles
knuckles :when you going to come and buy a new brake fluid reservoir and header tank
there old pictures. i have fitted the new brake fluid reservoir i got off ya!
just need a header tank now
- SEG1
- SEG1
Nice!
Those driveshafts look the nuts
I think I might invest in some once I break the "cut & shut" efforts that I currently have
How much were they if you don't mind me asking?
- jimmyesh
- Your car: Yes
how comes the idle speed control valve is mounted on the bulkhead ?
dont your inlet have a mount for the iscv ?
the bulhead mounted valves often get clogged up and often cause funny idle. Hence why ford did away with them and replaced them with the inlet mounted items.
- knuckles
jimmyesh :Nice!Those driveshafts look the nuts
they were 150+vat each ,which isnt bad imo
- SEG1
knuckles :how comes the idle speed control valve is mounted on the bulkhead ?
the inlet has a mount for the iscv ,but as i have converted the sandwich plate to take the top feed injectors it leaves no space for an idle valve.The iscv mount has been blanked and a take off has be drilled and tapped at the back off the inlet for the remote iscv.
i cleaned the iscv before i installed it, and when i was playing with the idle controls on the omex software i was impressed with the control capabilities of it.but we will see how long that lasts
- SEG1
RS_seg :jimmyesh :Nice!Those driveshafts look the nuts
That's good
- jimmyesh
- Your car: Yes
- corrupt_panda
- Your car: Fiesta RS Turbo
looking good mate... whats the white pot behind the servo?
- scouse-sambo
scouse-sambo :looking good mate... whats the white pot behind the servo?
the white pot behind the servo is the hydraulic clutch reservoir
- SEG1
Haven't done much tbh
just,
bonnet pins
new road tyres (T1Rs)
fitted laguna splitter
fitted AVCR boost controller
cut the front bumper out for the grs intercooler.
o and sourced the last 5 centre cap in england!!
also the alloys need a refurb and i need some opinions . i was thinking polished lip with black,sliver or gold centres or even the whole alloy polished.
just,
bonnet pins
- SEG1
