mondeo brake servo
3 posts • Page 1 of 1
mondeo brake servo
Does anyone know how much mondeo brake servo is bigger than mk3 standart one. Want to make sure it will fit with rs2000 engine because theres not much space left between manifold and original servo.
- whitedragoon
- Your car: mk4
Re: mondeo brake servo
I can give you the diameter of one if you like? Then can compare to your current one. With my rs turbo engine fitted I have about 10-15mm gap between the servo and fuel pressure reg. you can use the escort servo which isn't as big but still bigger than the fiesta one. Will need the rod cut to length and welded on it tho easy job
Russ
Russ
- russ-RST
- Your car: fiesta rs turbo
Would be grateful if you could take measurements. Another idea to get from a newer mondeo. It looks bigger in length and believe it would give better results than older model?
http://www.ebay.co.uk/itm/ford-mondeo-m ... 4173caaedc
- whitedragoon
- Your car: mk4
