M4X WW - ZT Project - For Sale / Breaking (soon!)
Re: M4X WW - My Zetec Turbo Project
Postby jayrs on Sun Jan 03, 2010 2:36 pm
only just sen this thread.
good work so far mate :)
Postby Smo on Sun Jan 03, 2010 4:27 pm
Max M4X WW :
Smo :Is that a CVH engine mount you're using, Max?
I don't know, But where is there a photo of it?
It doesn't look like the one in bridgend boys post I know that much.
Sorry Max, was very tired last night and wasn't really paying attention - the mount I saw was just your old HCS one.
Was curious as to what mount you were using though. I have the Zetec one on mine, but it's just not strong enough without the front mount on too... just allows too much movement, even with Vibratechnics, and I remembered you saying yours was different to Rob's, so just wondered what you were using, whether it was a modded CVH one or not :)
Smo
Postby ~nomad~ on Sun Jan 03, 2010 4:43 pm
I cant actually remember where the front mount goes, do you have to weld a bit in for it? I dont think there is gonna be a better solution than a rs1800 mount or si one, unless you get that front mount in. The engine in the blue one does move a bit too, suppose i will see if it causes any problems.
~nomad~
Your car: Breadvan
Postby Smo on Sun Jan 03, 2010 5:02 pm
MK3.5 front mount has a bit (metal flap) that bolts to the inner wing, as well as the chassis leg, while the MK3 front mount only attaches to the chassis leg, with the addition of a right-angled bracket that bolts to the side of the leg.
Obviously both mounts only bolt up to the Zetec alternator bracket (which differs between PAS and non-PAS models - as I'm sure you know!). But if Max is going PAS, then I'm guessing he's got the Zetec alternator bracket to hold the PAS pump anyway?
I think my Zetec rear mount was fine at first, but if you look closely, the rubber is only clamped to the outer case of the mount, and the metal bends very easily, making the rubber loose and free to move. I did think about welding it, but I'm not sure if the heat will have an effect on the rubber or not, so I think the CVH mount may be a better solution. I do have a front mount (and I'm using a non-PAS Zetec alternator mount anyway), but I still wonder how long the rear Zetec mount will last even when I get round to fitting it...
The other thing to remember with the front mount is the lack of captive nuts in the chassis leg on non-16v models (as far as I've seen?), so best solution is probably to bolt all the way through the leg, possibly with a plate welded on the underside to spread the load, or some how weld some nuts into the leg.
Smo
Postby dangerousdave on Sun Jan 03, 2010 5:06 pm
~nomad~ :I cant actually remember where the front mount goes, do you have to weld a bit in for it? I dont think there is gonna be a better solution than a rs1800 mount or si one, unless you get that front mount in. The engine in the blue one does move a bit too, suppose i will see if it causes any problems.
it goes on the chassis leg mate (where the 2i airbox normally sits) not sure if the holes are in all the shells bot nothing stopping it being nut and bolted it!! i think a piece attatches to the inner wing too iirc??
dangerousdave
Postby knuckles on Sun Jan 03, 2010 10:47 pm
is it dangerous not to use the front engine mount for the 2 litre zetec ?
its alot heavier than a cvh ? :-?
knuckles
Your car: Fiesta Rs turbo
Postby dangerousdave on Sun Jan 03, 2010 11:18 pm
edit, reread the question lol
doubt it..... garys was using 1 for his blacktop....
dangerousdave
Postby Max M4X WW on Sun Jan 03, 2010 11:18 pm
Loads of people dont, Will worry about it later.
If I can fit it easy, I will!
Postby RS rob on Sun Jan 03, 2010 11:25 pm
the zetec engine front mount was different on the early 2i 16v's to the si 16v
but you can see the extra top bracket on the inside of the wing
RS rob
Postby RS rob on Sun Jan 03, 2010 11:26 pm
will get a ford diagram to explain myself better tomorrow :lol:
RS rob
Postby Mikee_RS on Mon Jan 04, 2010 12:19 am
just get some vibratech engine mounts in there and it wont move an inch
Image Image Image
Mikee_RS
Car: 1995 Ford Fiesta
Postby Smo on Mon Jan 04, 2010 12:21 am
Mikee_RS :just get some vibratech engine mounts in there and it wont move an inch
What engine mount did you use with that engine?
Smo
Postby Max M4X WW on Mon Jan 04, 2010 12:32 am
The one I've got :lol:
Postby Smo on Mon Jan 04, 2010 12:42 am
Max M4X WW :The one I've got :lol:
Yeah, but you don't know what you've got, do you? :lol: You said it's different to Rob's one, who has the same as meeeeeeeeeeeee! :bonkers:
Smo
Postby Mikee_RS on Tue Jan 05, 2010 12:19 am
i used the standard ford mount by the turret and 2 vibratech gearbox mounts, honestly it was rock solid. infact i actually managed to rip a hole thru the gearbox cradle and the front mount was fine
Image Image Image
Mikee_RS
Postby RS rob on Tue Jan 05, 2010 1:14 am
diagram as promised, dont know wether its any use now tho lol
RS rob
Postby jonyb4 on Thu Jan 07, 2010 5:42 am
oo only just seen this thread, max that is one clean car, what a find :Q
all the best of luck with it mate
all this engine mount talk is very helpful to myself, the mk4 mounts are completely different, so making my own from scratch is another story, but these pictures/diagrams do clear things out :D
Postby Sphinx on Thu Jan 07, 2010 11:50 am
More pics you gayer.
Postby Ruishy1 on Thu Jan 07, 2010 11:59 am
Sphinx :More pics you gayer.
seriously mate your one liners are comical :lol:
Ruishy1
Postby Max M4X WW on Thu Jan 07, 2010 4:29 pm
Postby ~nomad~ on Thu Jan 07, 2010 4:45 pm
lolz, i wanna play with it again!
~nomad~
Your car: Breadvan
Postby Max M4X WW on Thu Jan 07, 2010 4:51 pm
You can come round and play anytime you like! :aaah:
Postby Smo on Thu Jan 07, 2010 6:48 pm
Utter filth.
You doing this at your place, Max?
Smo
Postby Max M4X WW on Thu Jan 07, 2010 6:56 pm
Yep!
Postby jonyb4 on Thu Jan 07, 2010 6:58 pm
Ruishy1 :
haha funnies
Max M4X WW :You can come round and play anytime you like! :aaah:
even funnier haha
Postby heeman10 on Thu Jan 07, 2010 8:06 pm
Tut. Max. Car Cover!
P.S. I do hope you're going to put a "Max Power" sticker on this car once completed.
Postby jonyb4 on Thu Jan 07, 2010 8:36 pm
haha, do it :D
Postby hb69 on Thu Jan 07, 2010 9:10 pm
knuckles :is it dangerous not to use the front engine mount for the 2 litre zetec ?
I never had a front mount on my xr2i, never caused any problems. I wouldnt imagine it supports the engine much anyway
hb69
Your car: Fiesta 1.1 LX
Postby heeman10 on Thu Jan 07, 2010 10:10 pm
I didn't have one on my 1.8 ZT. Last year alone I demanded over 100 launches from the car, running Toyo R888s, a LSD and 245lbft of torque. Who knows how many more launches were performed in the four years prior to 2009?! Many hundreds, without doubt :)
Postby Max M4X WW on Thu Jan 07, 2010 10:21 pm
I'm thinking that whatever mount I am using may be making the engine sit too far back as its very close to where the mount bolts up. I need to look at an Si 16v in a scrappy!
Postby ~nomad~ on Thu Jan 07, 2010 11:29 pm
Max M4X WW :I'm thinking that whatever mount I am using may be making the engine sit too far back as its very close to where the mount bolts up. I need to look at an Si 16v in a scrappy!
I am fairly certain that your engine is mounted in exactly the right position. Next time I come up I will bring your inlet and rocker cover, can get the inlet and turbo mounted and then will know if everything is sat where it should be. You need to get the pas bits too so the rack can be bolted up before inlet
~nomad~
Your car: Breadvan
Postby jonyb4 on Thu Jan 07, 2010 11:38 pm
why have i gotta live so far away from everyone :( lol
Postby heeman10 on Thu Jan 07, 2010 11:54 pm
You live near Tom Jones and Gareth Thomas :)
Postby black2 on Fri Jan 08, 2010 12:03 am
The engine mount will be fine.
I run a 2.0l in my mk2 and just use the cvh engine mount. I to have done a lot of launches and never had a problem. It will be fine.
Gareth.
black2
Postby jonyb4 on Fri Jan 08, 2010 12:11 am
heeman10 :You live near Tom Jones and Gareth Thomas :)
pimsle, you forgot cathrine zeta jones, after all she is a supporter of the zetec engine :lol:
