Re: Introducing Katie's Dirty Little Sister...
Postby GRP16V on Mon Apr 23, 2012 8:20 pm
nice catch,
looks well preserved
good luck
"Top Gear" addicted
Image Image Image
GRP16V
Your car: Fiesta Si /Escort mk6
Postby Max M4X WW on Mon Apr 23, 2012 8:28 pm
Yea is it just self tappers? Being picky :lol:
Postby Rhinopower on Mon Apr 23, 2012 8:29 pm
Max M4X WW :Yea is it just self tappers? Being picky :lol:
Yes
Rhinopower
Your car: Volvo FH330
Postby trecoll on Mon Apr 23, 2012 8:33 pm
Nice find. Looks tidy enough :)
My frascati had everything on it! (Was an 'N' plated state blue one too! :lol: )
trecoll
Postby jonyb4 on Mon Apr 23, 2012 8:54 pm
mid level? central locking, electric windows, twin air bags, pas, and most had the 1.3
seems quite high to me
anoying place to rot
Postby Max M4X WW on Mon Apr 23, 2012 9:00 pm
Don't forget the boot pop!
Postby Tweek on Mon Apr 23, 2012 9:04 pm
Yeah that too Max lol, plus intermittent front wipers. It is missing many minor items though as I said, fag lighter, rear speakers, door trim, boot pannels, C-pillar covers etc.
Your car: VW Golf GTD
Postby Minstral on Mon Apr 23, 2012 9:05 pm
my first mk3 had a passenger airbag as well. it was a mistral
Minstral
Your car: *
Postby Excursion on Mon Apr 23, 2012 9:05 pm
That looks like a cracking base, Wayne. What's the ZT spec?
Postby Tweek on Mon Apr 23, 2012 9:11 pm
So far since I'm still making it up as I go along...
Bored out 2ltr engine with ARIAS pistons (from a F22 engine of all things)
mk1 Focus RS conrods + ARP bolts
T3 turbo, not entirely sure what it's from but 'rs200bhp' off here had it on a FRST, has an uprated actuator though
Exhaust is here too, again unsure on make but it's a T3 with a phat 4" outward rolled tip
Also have manifold adapter plates to fit a FRST inlet and ERST exhaust manifolds.
Still chewing over rad and intercooler. I don't really want to cut out the front bumper much so may go for a double-capacity FRST one and radiator, would have to find new yellow hoses though too. Also need to relocate PAS cooler.
ECU isn't certain yet but I am very keen on going towards Emerald, Gearbox will be uprated too. My ERST LSD box is already starting to whine.
Those are the key elements anyway, all the bits in between will come when they're needed. My personal target for at least having it on the road is FITP 2013, what state the external is in though is another matter.
Postby Max M4X WW on Mon Apr 23, 2012 9:28 pm
Tweek :Yeah that too Max lol, plus intermittent front wipers. It is missing many minor items though as I said, fag lighter, rear speakers, door trim, boot pannels, C-pillar covers etc.
Door trim? Boot panels?
Postby FRSJON on Mon Apr 23, 2012 9:29 pm
nice project :)
FRSJON
Postby MB7201 on Mon Apr 23, 2012 9:32 pm
Looks solid, time for the fun to begin.
MB7201
Your car: Fiesta lx
Postby Rhinopower on Mon Apr 23, 2012 9:34 pm
You sure those pistons will fit those rods? I thought frs rods only took frs pistons
Rhinopower
Postby Tweek on Mon Apr 23, 2012 9:35 pm
Max M4X WW :
2-point door handles, manual-window doorcards with bungs in, no carpeted suspension turrents, just bare with caps over the top mounts
Postby Max M4X WW on Mon Apr 23, 2012 9:49 pm
Ah ok, forgot about all this stuff lol. Mine will have a full dark frst interior and that's it.
Postby Rhinopower on Mon Apr 23, 2012 9:53 pm
Rhinopower :You sure those pistons will fit those rods? I thought frs rods only took frs pistons
Just confirmed it, frs gudgeon pin is 22mm, all other zetec rods are 20mm
Rhinopower
Postby Tweek on Mon Apr 23, 2012 10:02 pm
One's already assembled from where it was previously test fitted in an engine, They're not Zetec pistons, they're Honda F22 pistons, info copied from ARIAS job sheet:
Displacement: 134.71 / 2208.36
Finished Bore: 3.386 inch / 86mm
Stroke: 3.74 / 95
Rod Length: 5.571 / 141.5
Comp. Height: 1.215 / 30.86
Compression: 8.2 / 8.2
Pin Diameter: 0.866 / 22
Top Groove: 0.06 / 1.5
2nd Groove: 0.06 / 1.5
Oil Groove: 0.158 / 4
Piston Weight: 313
Postby Rhinopower on Mon Apr 23, 2012 10:04 pm
They must also be 22's then :)
Rhinopower
Postby Tweek on Mon Apr 23, 2012 10:05 pm
Just added piston spec sheet above, bearing in mind they're Honda specs but the measurements tick the boxes.
Postby jonyb4 on Mon Apr 23, 2012 10:10 pm
id love to buy the old zetec hoses if your selling them
lol aye forgot about them smaller things, still higher than some Si's and xr 8v
Postby Tweek on Tue Apr 24, 2012 10:32 pm
Right, today I sat inside it inspecting everything to look for any bodge jobs that have been done or any broken things that need doing. It's major stuff!
- Driver's window switch faulty
- Clock doesn't work (replaced with the 5dr clock to test which worked fine)
- Cluch pedal manual adjuster is missing the white knob from the front
- Crack in passenger speaker grille
- Passenger door mirror adjuster "collar" missing
Might take me 5 mins if I drag it out :lol:
Everything else is as new, just dirty!
Postby jonyb4 on Tue Apr 24, 2012 10:55 pm
:lol: good stuff
Postby DanFraser on Tue Apr 24, 2012 11:03 pm
Tweek :Right, today I sat inside it inspecting everything to look for any bodge jobs that have been done or any broken things that need doing. It's major stuff!
Just gotta break something along the way. Something that you never, ever get round to.
DanFraser
Your car: Ford Fiesta SI 1.6
Postby trecoll on Wed Apr 25, 2012 9:06 am
Tweek :- Cluch pedal manual adjuster is missing the white knob from the front
That's weird. My Frascati was missing the white knob too.
Even with it replaced, I always had to stick my foot under the clutch pedal to bring it all the way up and stop the clutch slipping!! :lol:
trecoll
Postby DanFraser on Wed Apr 25, 2012 6:15 pm
trecoll :
There's a white thing on the clutch?
DanFraser
Postby Tweek on Wed Apr 25, 2012 6:43 pm
It is yes
Postby filtra on Thu Apr 26, 2012 5:09 am
I'd advised against the FRST double capacity cooler. I take it you mean the one that sits in the place of the standard one but is bigger?
If so, (and you are running with the frst rad) it means you have to have the radiator at a silly angle, then with the T3 turbo, it will look super bodged.
Ex Fiesta RS Turbo owner :(
filtra
Postby Tweek on Thu Apr 26, 2012 5:43 pm
Advice noted. Will have a rethink on that then cheers :)
Postby TIL13R on Thu Apr 26, 2012 11:09 pm
Chop the wings off and start fresh ;)
Looks good apart from that tho...
TIL13R
Postby jayrs on Sat Apr 28, 2012 2:17 pm
you got it then :Q
i suspect the rust on the wings where they meet the front panel is prob due to replacment wings early in its life and it was never protected right, cos ive not seen rot on a fiesta there that bad before.
i wouldnt mind betting the rust is deeper, beterrn the wing lip and slam panel, prob best to chop them sections out and replace them with new metal, not worth binning the complete wings though, although is that dirt, or rust on the tip of the drivers wing above the indicator?
Postby Rs Adz on Sun Apr 29, 2012 9:49 pm
nice project hopefully u do keep it a nice little sleeper
Rs Adz
Your car: xr2i and mk1 fiesta
Postby Russ FRST on Sun Apr 29, 2012 11:34 pm
Looks like a good base there Tweek Look forward to seeing this progress :wink:
1600cc T2= 220bhp 222 lbs/ft
Russ FRST
Postby Tweek on Tue May 01, 2012 8:38 pm
Just bought some very expensive number plates for this car :lol: Project will be known as "K80" ;)
Postby - Danny Boy - on Tue May 01, 2012 8:44 pm
I like what you did there!
I hope the last 3 letters was BHP so everyone thinks its got 80bhp and they dont realise it has about 200 on top of that :lol:
- Danny Boy -
Your car: Fiesta Si 2.0
