Help! I need advice on Boost settings
Postby rsclaire on Mon Mar 16, 2009 3:08 pm
Hi all i have just bought my first RST i have had to change the turbo and engine. I have the refurb turbo on now and it has a uprated actuator on , could someone give me some advice as to what would be a safe boost, that would not harm my engine or turbo i have the bleed valve turned right down and it is running just under 14psi thanks
rsclaire
Re: Help! I need advice on Boost settings
Postby Chris 2i on Mon Mar 16, 2009 3:48 pm
Hi, welcome to FT :)
I have absolutely no idea about your problem, but you'll have more luck posting in the tech forum
http://www.fiestaturbo.com/forums/technical-problems-queries-vf14/
if you're sticking around, you'll want an FT keyring. Link under my sig :Q
Chris 2i
Postby JamieFRST on Mon Mar 16, 2009 8:14 pm
I've moved the post to the correct forum for you. Need more info about the car's spec really. Is the new engine standard, chipped, uprated intercooler? etc
JamieFRST
Keep It Tidy
Keep It Tidy
