Haynes manual..... explained.....
Jokes, random babbling and personal crisis counseling.
Postby ianFRST on Sun Jul 16, 2006 6:04 pm
stolen off pf. i thought it was a post on here :D :lol:
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now
you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out the bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing then re-check the manual because what you are doing now
cannot be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this... so how did you manage to botch it
up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, ikkle number... but you also thought that the wiring diagram was a
map of the Tokyo underground (in fact that would have been more use to
you).
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search for it in the dark corner of the
garage.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are
looking at, then declare in a loud knowing voice to your wife "Yep, as I
thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking feeling in the pit of your stomach has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to do!
ianFRST
Postby nearly17 on Sun Jul 16, 2006 7:11 pm
:lol: !! I liiike!
nearly17
Postby John_D on Sun Jul 16, 2006 7:20 pm
1st saw this on MEG a few year ago and had me in stitches :lol:
John_D
Postby nick050 on Sun Jul 16, 2006 7:49 pm
:lol: fudgekin great
nick050
Postby GOODY-ST on Sun Jul 16, 2006 10:57 pm
fookin quality :D
If we really learned from our mistakes id be a f**king genius by now
GOODY-ST
Postby jess_09 on Mon Jul 17, 2006 12:16 am
jess_09
Re: Haynes manual..... explained.....
Postby Tweek on Mon Sep 15, 2008 2:49 am
Had to search through the archieves for this to show someone, thought I'd bump it whilst I was here :lol:
Your car: VW Golf GTD
Postby Ruishy1 on Mon Sep 15, 2008 8:37 pm
fooking quality :lol:
Ruishy1
Postby M1K3Y_B on Thu Sep 18, 2008 2:17 am
Very true :lol:
M1K3Y_B
Car: 1996 Ford Fiesta Classic
