Have engineering code but need FINIS number.
Postby Excursion on Mon Dec 31, 2012 10:21 am
All,
I have an engineering code 1M5Z1S175AC but I need the FINIS code to order it in the UK. Does anyone know where or if these two are mapped? My local Ford parts contact can't help.
Thanks.
Re: Have engineering code but need FINIS number.
Postby tompeteRS on Mon Dec 31, 2012 8:47 pm
I'll have a look on Wednesday for you Mark. Can't do it tonight / tomorrow unfortunately. What part does it relate to?
tompeteRS
Authorised Trader
Authorised Trader
Postby tompeteRS on Wed Jan 02, 2013 10:17 am
I can't find a match for it, have you got a description of the part?
tompeteRS
Authorised Trader
Authorised Trader
Postby Excursion on Wed Jan 02, 2013 11:54 am
Thanks for this Tom. The part is a water seal which pushes onto the spindle of a rear disc equipped Mk1 Focus. To my knowledge the water seal isn't listed or available separately in our country, and instead comes as part of the spindle assembly:
If it helps, the Motorcraft reference is BRS117.
Postby tompeteRS on Wed Jan 02, 2013 5:39 pm
It would be worth trying 1212557 / 1M51 4C007-AA as this is a seal that fits between the lockwasher and wheel bearing ring.
There is another seal shown that fits between the wheel bearing and hub which does not have a part number listed but I think the one above is the part you need.
If this isn't available or isn't the correct part I often get complete rear spindles which I can supply for a fraction of the list price.
tompeteRS
Authorised Trader
Authorised Trader
Postby Excursion on Thu Jan 03, 2013 4:28 pm
Thanks Tom forlooking. I had that part already, which isn't the one. I've ordered the seals from amazon.com of all places! I was hoping they were available separately in the UK but it doesn't look like it.
How much are the spindles?
Postby tompeteRS on Fri Jan 04, 2013 6:58 pm
They are around £150 each at list price, if and when I get them I normally sell them for £25 each.
These are the ones for models with Rear Discs and Fiesta ST 150. Focus RS ones would be considerably more expensive.
tompeteRS
Authorised Trader
Authorised Trader
Postby Excursion on Fri Jan 04, 2013 7:12 pm
tompeteRS :They are around £150 each at list price, if and when I get them I normally sell them for £25 each.
Please let me know when you get a pair of the non-RS ones, as I will buy them.
Postby tompeteRS on Sun Jan 06, 2013 8:19 pm
Will let you know if I find some / get some in. I've only got about another 1500 cubic feet of storage space to work through not including any new deliveries!
tompeteRS
Authorised Trader
Authorised Trader
Postby Excursion on Sun Jan 06, 2013 9:59 pm
:lol: I also need ABS sensors...
Postby tompeteRS on Mon Jan 07, 2013 9:19 am
I've certainly not got the ABS sensors - they are still a 'live' part and would sell through at full retail so I tend not to find them or can get them out of my main supplier.
tompeteRS
Authorised Trader
Authorised Trader
Postby Padrinho on Fri Jan 18, 2013 11:39 pm
Hi,
I have the same problem. I have the Fiesta ST stoped, because of that. I have found the US code, but could not find the right finis code for that. And my local dealer could´t help me.
That´s the right part number:
Here's how it comes from the package. The seal is inside the plastic cup. the cup is used to place the seal on the spindle and then discarded.
Padrinho
Postby Padrinho on Fri Jan 18, 2013 11:42 pm
tompeteRS :It would be worth trying 1212557 / 1M51 4C007-AA as this is a seal that fits between the lockwasher and wheel bearing ring.
That finis code is for this seal:
Padrinho
Postby Padrinho on Fri Jan 18, 2013 11:47 pm
I have tried to find this on "timken" uk and spain dealers. The only place that sell is in US. But i don´t know the right reference.
The only information i could find is:
Rear Wheel Seal
Part Number BRS94
ID 1.575
OD 1.929
Width 0.630
OE Number 1M51 4C006 AA
OEManufacturer Ford
OE Number 1M5Z 1S175 AA
OEManufacturer Ford
PS: Sorry for my bad english
Padrinho
Postby Padrinho on Sat Jan 19, 2013 2:48 am
I think that is not Motorcraft (BRS117 - Ford: 1M5Z1S175AC Ford Seal) but BRS94.
Padrinho
Postby Excursion on Sat Jan 19, 2013 9:32 am
Hello, I found all of the above during my research too, and I remember coming across BRS94 early on but I discounted it for some reason. I seem to recall that I found a Motorcraft spec sheet which mapped the Focus seal with BRS117, so I ordered a pair of them from the states. I'll let you know if they are correct once they have arrived.
Amazon was the a supplier who would send internationally for a reasonable price. Here's the link for the seals I ordered: http://www.amazon.com/gp/aw/d/B000IYHCD ... r1&pi=SL75
If you want to try the BRS94 then Rock Auto will ship a a pair for $81 USD all in http://www.rockauto.com/
It's really disappointing that Ford don't sell these separately!
Postby Padrinho on Sun Jan 20, 2013 10:33 pm
The BRS117 is for the Focus Mk2 i think, and the BRS94 is for Mk1 (Ford Focus). I will try to search in SKF a seal with that dimensions. If i could not find that, i will try in the US for BRS94.
If you could find some other information please share with me.
Padrinho
Postby Padrinho on Thu Jan 24, 2013 5:08 pm
Have arrived it´s the wheel seal Motorcraft BRS - 94, the right one.
Padrinho
Postby Excursion on Thu Jan 24, 2013 5:14 pm
Padrinho :Have arrived it´s the wheel seal Motorcraft BRS - 94, the right one.
Thanks. I ended up ordering new spindles because I want a spare set. Cheers.
