H116 FCM - Breaking, Rawli -now with prices
Postby RS_Rawli on Fri Jul 24, 2009 6:15 pm
As above, ive had a quick reckon up and i think im going to break the fiesta.
im 90% decided so will post a list up of parts and prices when i get chance.
quick spec
Custom bumper
needs brackets fabricating as original mounts are knackered, comes with fogs and custom ducts - 100
Cossie intercooler, brackets cut off from sierra fitment - £30
GRS Evo3 intercooler, mark in the back, bracketrs missing off one side, pipes cut down by previous owner, never fitted by me, want my money back £150
T2 turbo, no smoke, only ran 8psi on mine, good unit as far as im aware, forge actuator - £130
Custom Pipework - £40
Rebuilt 1600cvht, very clean engine, little tappy but nothing serious, was out of a FRST i bought for the engine, engine had been freshly rebuilt, done about 500 miles with me tops - £350
Rebuilt s2 gearbox - done about 1500 miles, was my long ratio gearbox, bearings s**t out and i had it rebuilt about 2 years go, only to standard spec though unfortuantely so 135 top speed! - £150
Pro alloy radiator, 2 veins been sealed off, works and cools just fine - £80
helix 4 paddle, comes with pressure plate - £100
325mm AP Racin 4 pots, Focus RS discs, custom mounts and radial mount CP5200 AP Racing calipers, pads are getting low - £450 ultimate brake setup, 17inch minimum!
RS2000 rear disks, drilled disks, disks have been skimmed, cant remember if theres pads with them or not, £100
Beiges, never used them seals are good, £80
195 Chip, again, never used it £100
cossie fuel pump, always worked fine in mine - £50 on cradle
half safety devices cage, aluminium diagonal set in for show, cna remove it if need be, in white - Prov sold
flocked dash, very clean, as in pics - £100
armtech launch control, flat shift, rev limiter, pop pop bang bang £70
loom and alarm, auto watch blue alarm, heated screen full electric model - £100
mint delocked doors, in white, no stripes, £50 each bare doors
mint delocked boot lid, in white, delocked and dewipered with fiesta turbo spoiler- £60
mint bonnet, paint is a bit nasty but its straight and no rust, no charge carrier dents either £85
new heated screen - replaced 2 years ago, done sod all mileage since - £100
green drop glass - £15 a side
pop outs, rubbers and catches £45 pair
rear bumper, cut out for 17s, smoothed swage line - £40
avo coilovers, platforms seized as normal, started drilling the grubscrews out on the front and never finished it, need new platforms really - £80 set
frst gen ford lower arms - £50pr
blue 4 point harnesses - £50 pair with eyelets
front and rear strut braces, £50 or 35 each
indiglo dials on FRST clocks, total mileometer doenst work propperly apart from that, fine - £40
mongoose with 4 inch tail, heat wrapped tailipipe, T2 back - £120
clear rears, mint no cracks etc - £50
standard lights - £10pr
quads with inners removed, usual business with the mounts rattling loose - £100
standard fronts - £10pr
full mint FRST trim with door cards, 2 passenger seats, but only difference is the side the winder is on, minty mint £250
flocked centre console - £35
mirrors, colourcoded - £30
single wiper, £15 home made one
raceline RL7s 17x7, with 205 40 17 falkens - provisionally sold
loom and ecu , ofac - £100
loads of other bitrs to, just ask
chris
few pics i have lying about
mark on the back of the cooler
RS_Rawli
Re: H116 FCM - Breaking - Rawli - Ex Feature car
Postby andymcd on Fri Jul 24, 2009 6:21 pm
sad day :cry: :cry:
price on grs pls and the front bumper :D
andymcd
Postby Dazza on Fri Jul 24, 2009 7:11 pm
Nooooo :cry:
If its what you want to do, goodluck mate
Dazza
Postby FRST_ZVH on Fri Jul 24, 2009 7:35 pm
Great spec'd car by the sounds of things..
Would be interetsed in the flocked dash items, indiglo dials and maybe the RS2000 rear discs.
FRST_ZVH
Postby Shell on Fri Jul 24, 2009 8:51 pm
Bad times Rawli... Bad times... :cry:
Good luck with the breaking! :) x x
Shell
Postby slaney21 on Fri Jul 24, 2009 8:53 pm
same as frst zvh
interested in the flocked bits and the dials. :)
slaney21
Your car: Zafira A SRI 2.216V
Postby FRSJON on Fri Jul 24, 2009 9:21 pm
price on wheels please... :D
FRSJON
Postby RS_Rawli on Fri Jul 24, 2009 9:30 pm
Cheers for the comments.
Want 100 for the dash and 40for the clocks,
Wheels are 900 but provisionally sold
Chris
RS_Rawli
Postby slaney21 on Fri Jul 24, 2009 10:42 pm
you getting pics up soon bud? really sorry to see this being broken :(
slaney21
Postby FRST_ZVH on Fri Jul 24, 2009 11:52 pm
RS_Rawli :Cheers for the comments.
Wheels are 800 but provisionally sold
Chris
Cool, happy with the price, will wait for you to get a couple of pics up :)
edit - where are you Rawli ?
FRST_ZVH
Postby andymcd on Fri Jul 24, 2009 11:58 pm
FRST_ZVH :Great spec'd car by the sounds of things..
hello :-?
andymcd
Postby gibbonuk on Sat Jul 25, 2009 1:04 am
hi mate what cossie cooler is it? And does it have modified end tanks? If u have any pics of it could u send me sum threw?
CheeRS
Gib
gibbonuk
Your car: Fieata Turbo
Postby dijsil on Sat Jul 25, 2009 1:17 am
pmed
dijsil
Postby RS_Rawli on Sat Jul 25, 2009 9:30 am
HI, sorry pal, yeah those prices were to everyone, dunno what rs2000 rear brakes are worth these days, ill have to look into it
the car is situated between manchester and liverpool, just off the M6 so easy enough to find
i need to sit down and put figures to eveyrthing and update this post with pictures and prices, just bare with me as im very busy at the moment.
the cossie cooler is an early 2wd item, i had it fitted upside down with a custom T2 setup, if you can find the old feature from years ago it shows this set up, basically a t2 rotated to exit forward, short pipe to the intercooler and then out to the charge carrier on the other side. single pass and short inlet tract
chris
RS_Rawli
Postby andymcd on Sat Jul 25, 2009 11:07 am
sorry mate am after the grs cooler and front bumper pm me :Q
andymcd
Postby RS_Rawli on Sat Jul 25, 2009 11:51 am
just thought id add the bumper and the cooler arent matched, my bumper is for the cossie cooler, its also been cut out at the sides cos of the wheels and the mounts are a bit knackered, needs attention!
chris
RS_Rawli
Re: H116 FCM - Breaking - Rawli - Ex Feature car (with pics)
Postby Dazza on Sat Jul 25, 2009 12:11 pm
Just a silly bit really but how much for passenger wing? Is it ok?
Dazza
Postby RS_Rawli on Sat Jul 25, 2009 12:14 pm
wings are cut out for 17s mate, also have the arches bonded and smoothed in, you'd be better with a new one
chris
RS_Rawli
Postby M1K3Y_B on Sat Jul 25, 2009 12:59 pm
Bonnet Price?
M1K3Y_B
Car: 1996 Ford Fiesta Classic
Postby SEG1 on Sat Jul 25, 2009 1:35 pm
Is the shell 4 sale? Any rot or rust?
SEG1
Postby andymcd on Sat Jul 25, 2009 2:15 pm
RS_Rawli :just thought id add the bumper and the cooler arent matched, my bumper is for the cossie cooler, its also been cut out at the sides cos of the wheels and the mounts are a bit knackered, needs attention!
chris
i want the cooler for my own bumper has a cut out :D price on the cooler mate
andymcd
Postby Dave_B on Sat Jul 25, 2009 3:26 pm
pm'd fella
dave
Dave_B
Postby RS_Rawli on Sat Jul 25, 2009 3:28 pm
Shells been welded up too many times to remember sorry
Bonnet is mint, dent and rust free will need painting though 100quid
Want 150 for the grs. Will need brackets making up for it and the pipes have been cut down. Think this is what I gave for it and its completely as it was. Never got round to fitting it
Chris
RS_Rawli
Postby muz on Sat Jul 25, 2009 4:22 pm
Shame really Chris but needs must. Will it be at Ford Fair to get a last look?
muz
Postby RS_Rawli on Sat Jul 25, 2009 4:31 pm
Na no tax on it. Will trundle down in the audi
RS_Rawli
Postby andymcd on Sat Jul 25, 2009 5:10 pm
ok mate pic pls :D
andymcd
Postby xr2i1990 on Sat Jul 25, 2009 6:26 pm
how much for the front bumper ?? and how much for fog lamps
xr2i1990
Postby RS_Rawli on Sat Jul 25, 2009 6:32 pm
dunno what to ask for the bumper, it will need the mounts either remaking or redesigning, it pulled the bolts out of the foam s**t htey have in them
the fogs on mine have air ducts that i was going to use for brake cooling, i do have some spare sets of fogs though if youd like some
chris
RS_Rawli
Postby slaney21 on Sat Jul 25, 2009 7:26 pm
you got any pics of the dials working? really tempted on these :)
slaney21
Postby Max M4X WW on Sat Jul 25, 2009 7:37 pm
How mint is the interior? Only interested in seats :)
Postby RS_Rawli on Sat Jul 25, 2009 8:03 pm
Max got a mint pair of passenger seats and 2 back benches to choose from.
RS_Rawli
Postby xr2i1990 on Sat Jul 25, 2009 9:54 pm
RS_Rawli :dunno what to ask for the bumper, it will need the mounts either remaking or redesigning, it pulled the bolts out of the foam s**t htey have in them
chris
i like them with the gaps are u selling the set that are on the car ?? give me a price for bumper and the fogs ??? keeping in mind the ork that needs 2 be done 2 the bumper ?
xr2i1990
Postby Max M4X WW on Sat Jul 25, 2009 10:43 pm
RS_Rawli :Max got a mint pair of passenger seats and 2 back benches to choose from.
Any chance of any pics mate and if you think I'll want them hold them for me?
They are the seats I'll want at some point and know you've had loads in the past!
Re: H116 FCM - Breaking, Rawli -now with prices
Postby RS_Rawli on Sat Jul 25, 2009 10:51 pm
yeah mate, ive kept hold of these ones for a few years, theyre as good as the ones i sold heeman but his were a matching pair. let me know when you want them, ill try and get some pics as soon as i can
RS_Rawli
Postby slaney21 on Sat Jul 25, 2009 11:25 pm
pm'd regarding dials
slaney21
