Guide to silencing those noisey HCS tappets of yours
126 posts • Page 3 of 4 • 1, 2, 3, 4
Fiesta LX :RS_Rawli :if you dont want to do it, dont fouquette do it, i dont care.
Its not I dont want to do it, I want to make my Fiesta quieter. Its just I dont to do it before knowing that its safe to do and wont fouquette up my car. I cant afford to get another car just cause some guy over the internet said its fail safe.
I think 'buying a new car' is a little extreme, or do you have visions of the car exploding becuase the tappets were not set correctly? If so, I would advise not driving a car again.
I heard if you put too much air in the tyres, the doors can fall off!
- Badgerboy
PaulC :VUK :i find changing oil harder![]()
llama
I was only joking
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm
), focus inlet in, + k&n, passed mot without a cat
< FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW
http://www.finalgear.com
- VUK
IF! if you break something, which can be either tappets or conrods you can pop down your local scrappy and get new set for like £5
- VUK
Badgerboy :I heard if you put too much air in the tyres, the doors can fall off!
I best go and check my pressures!!
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Fiesta LX :Taken from here: http://www.fordfans.cz/download/manual/0686-02a.pdf
"It is seldom that the cam followers wear in their bores, but it is likely that after a high mileage, the cam lobe contact surface will show signs of a depression or grooving. Where this condition is evident, renew the cam followers. Grinding out the wear marks will only reduce the thickness of the hardened metal of the cam follower and accelerate further wear."
I haven't read the rest of that as i can't be bothered to download the .pdf, however, i'm thinking it'll priobably be for the CVH engine which uses cam followers in a bore driven from a rocker operated from the cam.
I do see what you are saying and your tutor does have a point as you shouldn't do this on something that has a hardened coating. However i think you will find the HCS rockers in yours and everyone elses don't have hardened rockers.
- James-UK
- Location: Cornwall Drives:Whatever is outside at the time.
Oh in that case, the followers are burried in the block, i didn't know they ran in a bore of they're own?
As you've got the cam, then the follower on top of the lobe, then the pushrod, rocker, valve. It's the rocker clearence that you adjust. I'm pretty sure it isn't hardened, best check with ford though or a engine builder if you are concerned.
- James-UK
Max M4X WW :Did you adjust the tappets? (properly!)
i guess he didn't
there is nothing to it, if done right it will be quet
- VUK
I must admit i usually have to do mine a couple of times because i manage to mess them up.
I changed my oil recently, its cheap mineral stuff and probably the wrong grade. My dad got it. I think its made it louder.
What you mean pretty tight
They should be that size lol.
How did you do them? i find jacking up the front drivers side wheel, in 4th gear is the easyest way to turn the engine over. Then adjust in 9's..
1 down adjust 8
2 down adjust 7
3 down adjust 6
4 down adjust 5
5 down adjust 4
6 down adjust 3
7 down adjust 2
8 down adjust 1
1 down adjust 8
2 down adjust 7
3 down adjust 6
4 down adjust 5
5 down adjust 4
6 down adjust 3
7 down adjust 2
8 down adjust 1
Remember, the exhaust and inlet valves swap halfway through.
If its still making a noise, then your valves are not seating properly, your timing chain is worn, or your engine is knocking. (Big End bearings)
- Badgerboy
Badgerboy :Remember, the exhaust and inlet valves swap halfway through.
or the camshaft is worn
- VUK
I didn't jack up the car or put it in any gear. I just cranked the engine using a spanner. I set the gap in order (from left to right)...
1st = 0.3mm
2nd = 0.2mm
3rd = 0.3mm
4th = 0.2mm
5th = 0.2mm
6th = 0.3mm
7th = 0.2mm
8th = 0.3mm
1st = 0.3mm
2nd = 0.2mm
3rd = 0.3mm
4th = 0.2mm
5th = 0.2mm
6th = 0.3mm
7th = 0.2mm
8th = 0.3mm
- Fiesta LX
this does work.........but saying that you are going to need alot of things in time with each other and some decent oil.
im doing this again tomorow as mine have got loader again, but i cant afford the oil
so i have to wait a bit or borrow some cash
- Ghost
will try this myself when i get the right tools but there are many different clearences going around,......my fez has about 110,00 on the clock and so can anyone suggest the best clearences for me?????
please
please
Radient red 1.1i = R.I.P K-Tay June 2006
June 2006- present 1991 Polo Coupe "Turbo"
June 2007-September 2007 Mk2 Golf Ryder - R.I.P,. my your heart live on! 1.3Turbo engine!!!
- mk3phill
Badgerboy :Use the proper ones, they are in the Haynes manual.
I keep meaning to try haynes and steve's settings back to back but i can never be bothered
Just started doing this today.
Im stuck as to what rocking means exactly - i know its when the two tappers are at the same height, in the guide on here called "Adjusting your tappets" it said its when the left tapper is closing (ie coming up) and the right tapper on the same cylinder in opening (ie about to move down). Is the rocking position where this is a tansistion between the left coming up and just before the right begins to move down?
Its really difficult to tell on mine as the clearances are miles out.
- AGAR
The way i do mine is to get number 1 right down, theres usually two 'down' but one is lower.
When one is right down, do 8, then turn it till 2 is down, do 7 etc etc.
Id strongly advise using fiesta_steve's settings of..
Inlet.. 0.10mm
Exhaust.. 0.15mm
I did mine to ford settings for a change the other week and it was slow and very loud. A lot quieter now and a bit quicker.
HTH
Inlet.. 0.10mm
Exhaust.. 0.15mm
HTH
Max M4X WW :The way i do mine is to get number 1 right down, theres usually two 'down' but one is lower.
Inlet.. 0.10mm
Exhaust.. 0.15mm
HTH
That way seems alot better than the "rocking" way. I'll try those settings too.
Off to do it now
- AGAR
After reading cheby's guide i think as long as the two are moving the one you adjust will be in the same place regardless.
Max M4X WW :Inlet.. 0.10mm
Exhaust.. 0.15mm
HTH
these are good settings if they're worn (which they will be on any engine over 50k) as it takes into consideration the fact that the feeler can't register the worn out bit where they make contact.
- al_
al_ :Max M4X WW :Inlet.. 0.10mm
Exhaust.. 0.15mm
HTH
think you need to read the guide mate
- RS_Rawli
Hello all, i am a fellow hcs rattler
Hi guys. I am new to this forum, but as my Ford Escort has the old HCS engine, which I abuse horribly,but is stiill going strong at 142K, thought I would share my two bits worth.
All these engines rattle . Its a fact. The engine design is 40-odd years old.Primitive, but reliable. If u want quiet, get a zetec.
You are all correct that the pushrods wear grooves in the rockers which makes setting them more difficult. I have found that the rocker shaft off the 1.3 Endura-E KA engine fits my 1.3 HCS CFI J6 engine. These are often in better nick if u get em from scrap yard.
Grinding them down will quieten things down but you will remove the case hardening. For those who don't know, case hardening is where things which need to be really hard like cam-shafts and rockers etc are heated in an atmosphere of Nitrogen. This gets absorbed into the surface of the metal (don't ask me how) and makes the outer surface REALLY hard. But this is only skin deep, if you grind it down you will get down to the softer inner metal. So FIESTA LX is correct. It is then likely to wear more severley later on.
I am gonna try it though.
I can't see that it will do it any harm. What I do is put a few mobile phone magnets around the outer surface of my oil filter to catch any er... shavings.
Also, be careful not to adjust your valve clearences too tight. If too loose, they are noisy, and you will lose power, but that's it. If they are too tight, when the engine is hot or running fast, the valves will not close completely. Sure it will be nice and quiet, but it will burn away at the valve seats and the valves, which is more serious. And if you are really un-lucky it could crack or warp the head cos valves carry heat away into the head through the seats.
If your timing chain "jingles" especially at idle or when u blip throttle it is worth slackening the alternator drive belt a bit. People often run these too tight and it can cause the crank end bearing to wear slightly and make crank move a tiny bit, making chain rattle. I took mine apart and found tensioner was fine and hardly worn... turned out it was the alt that did it.
Anyway, I won't rattle on any more for now... want to see if I can make my camshaft disintergrate... :-0
tHE HAND OF GOD WILL COME DOWN AND STRIKE THE UNROADWORTHY!!
- roadwarrior
