Guide to installing a Rev Counter mk3.5
Re: Guide to installing a Rev Counter mk3.5
Postby georgiocat on Thu Oct 22, 2009 6:41 pm
Nothing to do with the engine,if it has EDIS,internally or externally it will work right.
georgiocat
Postby FezzyGTI on Fri Oct 23, 2009 2:21 pm
[quote="georgiocat"]Nothing to do with the engine,if it has EDIS,internally or externally it will work right.[/quote]
??????????? it does hav e dis on the petrol but it mont on the diesalcame off will it???
FezzyGTI
Your car: Mk5 zetecs 2.0 ITB's
Postby georgiocat on Fri Oct 23, 2009 3:02 pm
[quote="FezzyGTI"][quote="georgiocat"]Nothing to do with the engine,if it has EDIS,internally or externally it will work right.[/quote]
??????????? it does hav e dis on the petrol but it mont on the diesalcame off will it???[/quote]
what?! lol.I didn't catch you...
georgiocat
Postby FezzyGTI on Fri Oct 23, 2009 10:30 pm
so where did it get the signal frm wen it was on a diesal? cos surely tht dont hav e dis since it has glow plugs?
FezzyGTI
Postby georgiocat on Fri Oct 23, 2009 11:15 pm
RPM signal on diesels comes from the alternator.At least on many diesels I've seen.There is a terminal on alternators,that it's voltage changes accordingly to it's rpm.So the tachometer "reads" from that.It's a common practice that is used even on marinized engines.Some vessels use diesel ford engines,that's from where I've seen it.Although can't tell you if the tacho from a diesel will work in a petrol engine and vice versa,although don't think so,since the working principal is different.
georgiocat
Postby FezzyGTI on Sat Oct 24, 2009 7:48 am
lol thats what i was tryin 2 find out, interesting 2 find out how it works and why it dont work on my petrol engine
FezzyGTI
Postby georgiocat on Sun Oct 25, 2009 6:59 pm
Glad I managed to answer some questions for you :)
georgiocat
Postby scottybo on Tue Sep 14, 2010 6:37 pm
f**k ALL OF WHAT YOU HAVE JUST READ IN THE ASS! GO ON EBAY AND BUY URSELF A REVVO FROM EITHER A FIESTA SI OR AN XR2I, REPLACE THE OLD CLUSTER AND IT WILL WORK STRAIGHT AWAY, THIS IS FAR TOO MUCH EFFORT
scottybo
Your car: mk3 frescrati
Postby FezzyGTI on Thu Sep 16, 2010 12:25 pm
[quote="scottybo"]f**k ALL OF WHAT YOU HAVE JUST READ IN THE ASS! GO ON EBAY AND BUY URSELF A REVVO FROM EITHER A FIESTA SI OR AN XR2I, REPLACE THE OLD CLUSTER AND IT WILL WORK STRAIGHT AWAY, THIS IS FAR TOO MUCH EFFORT[/quote]
not entirely true, not all fiestas hav the wire already in the loom for the rev counter feed, eg 1.1 pops from 1991, cos mine didnt
FezzyGTI
Postby b0yracer on Tue Oct 12, 2010 7:21 pm
i was only asking about rev counters yesterday, good to come accross this post, ive just been to my shed to check my clocks after reading (the older clocks will give the wrong revs) and though well ill have the older set its typical of what happens to me.
but luck would have it written on the back fiesta 3 "M" petrol, and on a original ford sticker is the date 27 may 94 also marked fiesta 3 1.6 si
so it seems buy luck ive bought the correct set ready to fit to my N reg 1.1 which i now believe to be the mk3.5 (something ive not heard/known untill i joined this forum.
lets hope the green wire is in the plug on the car (fingers crossed)
i also wasnt thinking about this coil pack set up, ive been so used to oldskool (drove a cortina untill end of sept just gone) and just thought it was a matter of connecting the rev counter to the coil duuhhh
b0yracer
Your car: ford
Postby FezzyGTI on Wed Oct 13, 2010 11:06 am
will be a simple matter for ya mate, it is jus green wire on N reg 1.1 cos it is a 3.5, personally dun it my self on both mine, ya may be lucky enuf that it will just plug in and wrk, depends what model ya 1.1 is, think popular etc need the wire attatchin but decent models will jus plug in
FezzyGTI
Postby b0yracer on Wed Oct 13, 2010 6:04 pm
its a 1.1 azura
b0yracer
Your car: ford
Postby FezzyGTI on Fri Oct 15, 2010 10:40 am
should just plug in then i think, i had 1 of them too not certain tho it was a while ago
FezzyGTI
Postby b0yracer on Sat Oct 16, 2010 9:02 pm
i had to add the wire to no 10 but all working now thanks to you guys on this forum
b0yracer
Your car: ford
Postby cossiemark on Thu Dec 08, 2016 5:47 pm
I've purchased a set of clocks from a L reg RS1800 will they be suitable for my sons m reg 1.1 azura?
Cheers mark
cossiemark
Postby cossiemark on Mon Jan 02, 2017 11:26 pm
Anyone??????
cossiemark
Previous
