Guide to fitting central locking in a 3dr Mk3 Fiesta
Postby wywywywy on Sat Dec 13, 2003 1:11 am
Daniel :Im doing mine right now, all fine except I cant work out how to get the wires from the door into the car. The rubber sleeve has a plug in the end so i cant shove wires down there.. Any ideas? I dont really want to leave wires just hanging between the door and bodywork incase they get trapped or crushed between the two.
Hi,
Firstly, unplug it, then twist the clip to take it off.
The plug and the clip is simply glued on with weak epoxy, use a sharp knife to cut the contact point.
Then reconnect plug.
Now wires can pass through :D
wywywywy
Postby RS rob on Sat Jan 03, 2004 3:09 pm
any pics or a list of parts needed would be very helpful,
as i need to do this before i have my alarm put in!
its for a 3dr mk3 btw!
RS rob
Postby wywywywy on Sat Jan 03, 2004 4:54 pm
Parts needed:
- 2 x front doors motor + lock + latch (in one piece)
Hmm... that's it!
Of course you'd need some wires, and preferably you'd have a fusebox installed.
wywywywy
Postby fiestacollecta on Sat Jan 03, 2004 5:41 pm
set of c/l motors on ebay :wink:
fiestacollecta
Postby bluefiestamk3 on Wed Jan 28, 2004 10:55 pm
Why aint this a sticky :o
Would have saved me pssing off people asking stoopid questions all the time!
bluefiestamk3
BANNED MEMBER
Postby heeman10 on Wed Jan 28, 2004 11:01 pm
It's been sticky for months :)
edit: Just checked back...it's been sticky since June 26th :)
Postby festasi on Sun May 23, 2004 6:54 pm
" permanent live busbar on the back of the fuse box"
has anyone got a pic of where to actaully connect this to the busbar?
fittin into mine was easy [ERRR] i cud just plug the loom in under the drivers side cockpit, but ma gf's car hasnt got the multiplug in, so gotta wire up manually :x
festasi
Postby Max M4X WW on Mon Jun 07, 2004 10:15 pm
Hi, Got some motors coming soon for my car.
Anyone got any instructions on fitting the actuall motors to the locks or whatever? Thanks.
Postby Max M4X WW on Thu Jun 24, 2004 11:06 pm
Max M4X WW :Anyone got any instructions on fitting the actuall motors to the locks or whatever? Thanks.
Postby Project on Fri Jun 25, 2004 1:24 am
Err, you can't - not easily. You need the right latches with the c/l connecting rods.
Al
Project
fiftyoneCL
fiftyoneCL
Postby Max M4X WW on Fri Jun 25, 2004 8:19 am
Yea everything i need is coming i think.
But how do i remove the old bits? Looks confusing!
Postby Project on Fri Jun 25, 2004 11:29 am
Guide superseded - new guide here.
Al
Project
fiftyoneCL
fiftyoneCL
Postby heeman10 on Fri Jun 25, 2004 1:10 pm
Superseded, overcome, bettered, rendered useless :cry: And I thought this thread immortalised me on FT.com. Little did I know it was just a worthless string of text, merely to be deleted by a power-happy gay-named Channel 4 reality TV presenter :cry: Al, you suck willies. I thank you.
Postby AW3K on Fri Jun 25, 2004 6:01 pm
heeman10 :Superseded, overcome, bettered, rendered useless :cry: And I thought this thread immortalised me on FT.com. Little did I know it was just a worthless string of text, merely to be deleted by a power-happy gay-named Channel 4 reality TV presenter :cry: Al, you suck willies. I thank you.
Didn't mean to steal your glory heeman10 :p honest
Your guide is also good :)
AW3K
Postby heeman10 on Mon Jun 28, 2004 1:47 pm
lol cheers :p baxtered :bonkers:
Postby Project on Mon Jun 28, 2004 4:55 pm
Awww, it got a reprieve!
How sweet :P
Al
Project
fiftyoneCL
fiftyoneCL
Hmm, second thoughts, it might just be that Ade never moved it in the first place... ;)
Project
fiftyoneCL
fiftyoneCL
Postby heeman10 on Tue Jun 29, 2004 12:29 pm
Still trying to get rid of me then :lol:
Re: Guide to fitting central locking in a 3dr Mk3 Fiesta
Postby Xtreem on Sun Feb 10, 2008 10:03 pm
What you need if u like to add a remote central locking?
Does 1.1i hcs cylinder head fit for 1.3i?
Xtreem
Postby knuckles on Fri Feb 29, 2008 9:25 pm
You need a alarm to the car and then connect up the central locking to the remote function on the alarm. :)
knuckles
Your car: Fiesta Rs turbo
Postby xr_bass on Tue Mar 04, 2008 1:29 pm
this is gunna help loads cheers mate
xr_bass
Postby dijsil on Fri May 01, 2009 9:46 am
got a pair of central lock
one of them is of a fiesta mk3 and the otherone is probably from a fiesta mk4. every thing is the same apart from the inside handle which i can use the old one.
when it comes to the wires i found a small problem
the mk4 lock:
white purple
yellow black
black
red black
mk3 lock
white brown
yellow brown
brown
red yellow
i figured out that the white purple must go with the white brown
yellow black with yellow brown
now ...
black with brown (PROBABLY)
red black with red yellow.
am i right regarding when connecting the wires together ?
and thich one is the earth and live ?
dijsil
Postby dijsil on Sat May 02, 2009 3:51 pm
never mind ... connected the central lock with trial and error ..
works perfectly :D
dijsil
Previous
