Finally
Finally
Postby Mattious on Tue Jan 28, 2014 10:58 pm
Finally think I've fixed my rs I've now actually completed 50 trouble free miles with no problem starting her back up ! Yesssss!
Stuck my hand down the back of the drivers seat and found this. Am I right in thinking its a reverse light switch ? :-?
This is the first time I've driven the FRST properly since it's been t3'd, what should I do next? stick a cam in and if so what one ?.
Mattious
Your car: Fiesta rs turbo
Re: Finally
Postby Mattious on Tue Jan 28, 2014 11:17 pm
Also the t3 I got came with a bleed valve fitted , shall I ditch this for the Amal valve ? The only problem I have is my air filter hose doesn't have the nipple coming of it for the pipe to run to the Amal valve. What should I do ! .
Cheers matt
Mattious
Re: Finally
Postby jayrs on Wed Jan 29, 2014 3:06 am
Yeah that's a reverse light switch.
I'm not a fan of bleed valves, although I have one fitted to my rs in the line from Amal to intake pipe, I fitted this years ago when I upped the boost, it's set and never messed with, so provided you don't mess with you if it's set to a safe limit, leave it there
Re: Finally
Postby mikeymikeyp on Wed Jan 29, 2014 11:40 am
you use the 2 nipples on the turbo for an bleed valve
mikeymikeyp
Re: Finally
Postby jayrs on Wed Jan 29, 2014 11:58 am
If you choose to do away with the std pipe set up and run the bleed valve directly on the turbo with no form of boost control what so ever, then yes, you can fit one from the nipple on the compressor housing to the nipple on the actuator.
If you want boost control still, then you fit it in line from the T piece from the turbo and actuator to the Amal valve.
Mattious, what I forgot to put yesterday was, the pipe from the Amal valve to the intake pipe is nothing but a vent pipe, rather than it venting into the engine bay, ford piped it into the intake system via the intake pipe, so you don't really need to have it piped to the intake pipe, a vac house hanging in the bay will be fine, with the exception of there not being an air filter to stop any crap getting into the Amal valve
Re: Finally
Postby Mattious on Fri Jan 31, 2014 7:58 pm
Thanks jay,
Going to do the reverse light this weekend , I'm going to install the Amal valve aswell , well that's if the weather picks up , it's like April showers here today !
Btw jay thanks your help with the car over the last few months.
Cheers matt
Mattious
Re: Finally
Postby jayrs on Fri Jan 31, 2014 10:07 pm
Yeah we could do with some dry weather, I gotta sort a heater matrix on a pug again, carpet out to be cleaned again, fcuking thing lol
And no worries mate, anytime dude
