Fiesta zetec turbo - now for sale!
Re: My Fiesta Turbo - piston rings gone!
ill get some pics of the head on monday , as am stripping it to clean everything up then lap valves back in and replace stem seals with new ones as replacing every gasket. the valves are standard size as my mate has build a few turbo engines and its same as his. the ports also look totally standard and no sign of polishing.
jay the mahle pistons are identical to mine but mine AE.
what do you mean cam coil pack?
the engine is nto what its ment to me but they left the paddle clutch in so when i went to buy it and made sure it had eveything else and when i drove it, you could tell it was paddle and was quick so i thought the engine was as advertised. but sadly no....so now my plan is to get another engine and build it to the spec its ment to be.
- cowie20
he means check the cam at the coil pack side to see what kind it is, should be stamped on
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
- KINGHORN
yeah got you there. i thought it was something i aint heard of. ill check on monday. thinking on going for newman cam with solid lifters.
- cowie20
NEVER USED Newman but have head they are sposed to be good
- KINGHORN
well went down to mates garage today to fit new rings and some robbing cu*ts have broke into car and smashed up the dash, stole stereo, ripped apart steering coloum and bent drivers door from top which has kinked it around window and dented above green strip.
they tried to start it and have popped bonnet then realised there was no engine and left.
so basically they stole my £40 head unit but left a cylinder head and some hoses in boot and left the new turbo which was still on exhaust / downpipe in bay.
so now i got to get a new door and sort a dent in roof where they bent door from!
well pissed off to say least! police came and got finger prints so hopefully they come back with a name and i can find the robbing s**t!
- cowie20
Sorry to hear that, some right scum around
Hopefully the police will be able to get someone from the prints
- FiestaBen
- Your car: Vauxhall Astra Sport
Car: 1995 Vauxhall Astra
Re: My Fiesta Turbo - Got broken into!!!!!
Sorry to hear that mate! Nothing worse than your car being broken into!
At least they didn't steal the whole car!
- Dave G fsi
- Your car: Mk1 FRS and FRST
as i said in pm dude, persly is just up the road and i have the tools and know how to help get you most parts you need even a nice new black dash
- KINGHORN
i hope the police do get some prints then i ll hopefully get a name of the fuker!!!!!!!
ill get some pictures of the mess they left of the door.!
are the new water base paints albe to be matched to old paint??
- cowie20
scum bag c**ts need there hand cutting off.
tell me about it! they ended up with a £40 halfords cd player, they prob dont even sell them any more and i end up with needing a new door,spraying of door and dent in roof which isnt big but will no doubt be costly.
ill get pictures tomorrow of damage and engine all built back up and back in bay
anyone got ideas on best way to run in rings?
- cowie20
yeah, remove the lip from the top of the bore and drive it easy for a bit
there was no lip on bore, the rings didnt even look shagged, the the bord where really glazed from fuel running down them, and compression test was about 85 psi on 3 bores and 1 bore was about 70 psi. all the bearings didnt have a mark on them they looked brand new.
i fitted new rings and de glazed the bores.its all built up now but was reading a website that says to let the rings seat in its good to let car warm up then drive the car right up the revs and let the engine slow its self down to let the rings bed in, becuase if driving carefully the bores will glaze up before rings bed in and give good compression.
- cowie20
yeah mate a good bodyshop should be able to get a match on colour
- KINGHORN
c**ts mate
- andymcd
For fucks sack, what c**ts
Atleast you still have the car.
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
good stuff. wasnt sure if water bases paints matched up to old paints that well. the paint on car is only about 3 years old tho
- cowie20
Thugs!
- EUFez
thats s**t mate. set backs like that are things you dont need when your already wacking enough money into it!
i got my beemer keyed the other week, seems you cant have anything nice in this country
- Ram
you cant, too many w@nkers out there
anything that looks nice and shiny they want to destroy, i dont understand how they get a kick out of destroying peoples pride and joys that they spends thousands on!
didnt get pictures of damage today as spent all day putting engine in car and hooking everything up. once eveything was connected etc, bleed oil through oil feed pipe, then checked compression in bores, was getting 8 bar / 116 psi across cylinders. thats 30 psi more than i got when i did compression test before.
car fired up straight away, idled really nice,
away to find new doors tomorrow with handles and locks then get car over to bodyshop to get them painted and get dent in roof sorted.
then next when i get funds ill get wheels refurb with new tyres and a boot with lock and wiper
- cowie20
- FRSJON
Re: My Fiesta Turbo - engine built and back in!!!
thought id update this with latest thing ive done. thought id do this for a bit of fun and seen it done on a mk1 turbo and it made very good results on rollers
so i bought a wastegate off ebay, 1bar spring and a 1 meter lenght of 38mm mild steel pipe. all for sum off 97 quid posted for the lot.
took half a day to do, hardest part was getting turbo out of bay without taking bumber , cooler and rad off.
result - on idle sounds like a exhaust leak as there is exhaust as coming out screamer pipe, which i dont get as WG is shut and gases shouldnt be getting past.
when it comes on boost it feels alot stronger over a normal actuator, but on drive home it popped bottom boost hose off so not had a chance to proper open screamer pipe. will try get a video.
- cowie20
- Dave G fsi
Re: My Fiesta Turbo - Wastegate and screamer!
well after going on a drive, am not happy with it, i fitted a 1 bar spring in WG, but its opening at 8 psi and not boosting anymore. so need to sort it out.
also not to happy with screamer noise, not sure if its down to not getting full boost.
back to the drawing board
- cowie20
only just seen this update! external set up looks sweet
finally in the proccess of doing mine after having the wastegate sat in a box for ages lol..
regarding your boost issues, did u weld the internal wastegate shut? or even just keeping your actuator on but wound tight would do it. as otherwise this wont allow the turbo to spool up properly if its still open.
sorry if you have and my comment sounds stupid, just thought id try help as il be welding mine shut
edited to say: also there should be a ring that goes on the inlet part of w.g between the flange and the bit that closes/opens. looking at my one, if the ring is not there it would leave a small space around it that gases could get through the w.g and out the screamer when w.g is not open.
- Ram
Looks good..
Although can someone show me/explain how these external wastegates and screamer pipes fit/work
- happypaul
cheers for comments, yeah i have that ring fitted but screamer still lets gas escape on idle, i made a bracket and welded an ajustable rod from old actuator to hold gate shut tight.
to get my boost up i used a 1 bar spring with a 8 psi spring in the middle of it. which gave me a 22.4 psi. i then cut a coil off the 8psi spring which took boost down to 18psi. but i will be cutting another spring off to get it to about 16- 17 as with 18psi the turbo has to produce about 19-20 to over come spring.
waste gate works but getting pressure from turbo compressor same as it would to a actuator, as boost increases it will start to overcome the spring and once it reaches the size of spring or more it opens the gate inside wastegate and lets exhaust gas by pass turbo into air or back into exhaust system.
- cowie20
If Your want to know what these wastegate's sound like, watch this video i think they sound awsome better than a dump vavle by miles
http://www.youtube.com/watch?v=baUEBAKw5vQ
Love it
Love it
- stokieboy123
^ This car does not have or has never had an external wastegate, screamer pipe or DV fitted.
- ace1001ace
ace1001ace :^ This car does not have or has never had an external wastegate, screamer pipe or DV fitted.
It'll be even funnier when you tell him how you know
- Smo
See I was thinking that.. lol.
With regards to the answer to my question above.. yes I know how wastegates work.. but how have you fitted this external one etc?
- happypaul
drilled a hole in t3 manfold where the 4 peipes meet, welded a 38mm pipe onto it with some home made bends, welded wastegate flange onto pipe fittedd wastegate, made a screamer, then connected pipe from compressor side to top of wastegate,
took me a mornings work and cost me less than £100 notes
- cowie20
yeh i didnt weld w.g shut in the end just got a bracket welded to hold it shut instead. less permanent that way
well i just picked my car up from my mates now hes welded screamer on and mine is exactly like yours, you can hear it on idle and it makes the car bloody loud lol. abit too loud for my liking?? its only wound to 8psi but sounded great when on boost
so il be setting it to 14psi 2moro and see how it sounds
but were now in the same boat as to why it still has gases coming out when just on idle?
- Ram
