fiesta st170 turbo
Re: fiesta st170 turbo
Postby crazycage on Wed May 04, 2011 8:13 pm
Excursion :Looking good mate. For more equal cylinder filling the entry into the main plenum from the feed plenum should be on a taper – starting out wide at the TB end and narrowing towards no 4
cheers. the plenum feeding the main plenum is a cone :D didnt you see you pic of the cvh one i made ? its a few posts up .
crazycage
Postby Excursion on Wed May 04, 2011 8:18 pm
crazycage :
Like this mate
The area over each inlet port should be a 1/4 less than the previous port :)
Maybe the picture doesn't show the angle too well.
Postby leighk2010 on Wed May 04, 2011 8:28 pm
epic stuff going on mate i'm glad to say i own one of your inlets. very good at what you do. like your new engine mount wish i had thought of that will be b it hardcore for me thought you still going be use this as ya daily once its fixed?
leighk2010
Postby crazycage on Wed May 04, 2011 8:32 pm
Excursion :
crazycage :
Like this mate
didnt know thats what you ment mate :lol:
the mountune wrc inlet that i have is a twin plenum like plenum i am building and the slot is the same size all the way along :D
the jenvey turbo inlet is very similar too.
crazycage
Postby crazycage on Wed May 04, 2011 8:35 pm
leighk2010 :epic stuff going on mate i'm glad to say i own one of your inlets. very good at what you do. like your new engine mount wish i had thought of that will be b it hardcore for me thought you still going be use this as ya daily once its fixed?
cheers :D
no i wont be using it every day but most days :)
i am hoping for it to be taxed 1st of june
crazycage
Postby luca on Thu May 05, 2011 9:32 am
SANTA POD BABY! :Q
luca
Postby heeman10 on Thu May 05, 2011 10:20 am
The need for tapering down will certainly be lessened in a double plenum setup, compared to single plenum, but it's probably still there to a degree. I could've run a flow simulation if I had Solidworks to hand...best get to grips with simulation on Inventor!
Postby crazycage on Thu May 05, 2011 6:29 pm
luca :SANTA POD BABY! :Q
i will be having a go mate. got my eye on a 130 terminal :o
when you running next?
crazycage
Postby crazycage on Thu May 05, 2011 6:30 pm
heeman10 :The need for tapering down will certainly be lessened in a double plenum setup, compared to single plenum, but it's probably still there to a degree. I could've run a flow simulation if I had Solidworks to hand...best get to grips with simulation on Inventor!
a friend of mine does all the cfd for me ,but i am thinking of having a go myself ,just need to get it onto my comp :x
crazycage
Postby crazycage on Thu May 05, 2011 9:02 pm
i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted :(
and put a KAAZ plated lsd in there just to see if i like it better than my atb diff.
crazycage
Postby Excursion on Thu May 05, 2011 9:07 pm
crazycage :i have also had a new box built with standard focus rs ratio's as i didnt really like the last one with the 3.41 fd fitted :(
Did you have the 2.0 ratios with 3.41 FD?
What didn't you like about it?
Postby crazycage on Thu May 05, 2011 9:25 pm
Excursion :
it is a focus rs box with the 3.41 fd fitted .
it geared the car for over 180mph , i only fitted it so i could hit 130+ in 4th gear . top speed is not my thing :lol:
its hard to explain but just sort of took a little edge of how torquey it was low down part throttle low boost round town if that makes sence.
it made more boost lower down but didnt pull harder for it ,made it feel a little laggy but the data logs show it wasnt
crazycage
Postby luca on Thu May 05, 2011 9:28 pm
crazycage :
Not sure actually mate, wont be at Classic Ford show in it though.
Im enjoying trackdays too much, but will try again at Pod sometime.
luca
Postby Excursion on Fri May 06, 2011 10:13 am
crazycage :
Excursion :
Ahh OK. FYI the FRS box is just a 2.0 box with the diff and shot peened gears.
I'm making up a 3.41 box also the other - is it 4.21 or something?
Postby crazycage on Fri May 06, 2011 9:38 pm
3.82 mate :)
crazycage
Postby heeman10 on Fri May 06, 2011 10:38 pm
crazycage :took a little edge of how torquey it was low down part throttle low boost round town
It's all about the 11 second car that feels good around town.
Postby crazycage on Sat May 07, 2011 4:43 pm
got more done on the inlet :D
just need to make and fit the cone and throttle body flange and sort the brackets for the billet fuel rail! but the blanks for them are not here yet :(
crazycage
Postby creator on Sat May 07, 2011 7:06 pm
Looks bloody sweet that mate :aviator: now get it finished and mapped :D
creator
Postby Excursion on Sat May 07, 2011 8:33 pm
Cracking stuff mate!
Postby SiST on Sun May 08, 2011 9:46 am
Absolute quality work there mate - some great unique mods going into the car!!
I will be interested to see what benefits the toy car gives to the inlet :D
Si
SiST
Postby crazycage on Tue May 10, 2011 8:25 pm
got a bit more done today :D
crazycage
Postby jonyb4 on Tue May 10, 2011 9:49 pm
looks great, ill admit my ignorance though, i done know what the twin plenum system does and what its advantages are :(
Postby crazycage on Wed May 11, 2011 7:42 pm
jonyb4 :looks great, ill admit my ignorance though, i done know what the twin plenum system does and what its advantages are :(
its all about equal air distribution :)
crazycage
Postby crazycage on Wed May 11, 2011 7:45 pm
inlet is almost done now, just need to drill and tap the plenum for the air temp sensor and vacuum take off's and sort out the fuel rail when the billet turns up :D .
crazycage
Postby FRSJON on Wed May 11, 2011 7:54 pm
all looking good and im sure will prove itself very soon.. :Q
FRSJON
Postby Excursion on Wed May 11, 2011 8:59 pm
Good job mate.
Postby leighk2010 on Thu May 12, 2011 3:19 pm
good job mate very jealous must say
leighk2010
Postby crazycage on Sat May 14, 2011 12:41 pm
made a new oil catch/separator tank with a return to the sump ect it's stainless steel :o but it cost me nothing and i got paid time and a half to make :lol: :lol: :lol:
just need a bracket to mount it and a coat of paint
still waiting on the billet fuel rail to turn up so i cant finish the inlet off :x off out to fit the wastegate :D
crazycage
Postby Excursion on Sat May 14, 2011 6:25 pm
Nice welding! Fancy doing another? I will pay you, obviously.
Postby crazycage on Sat May 14, 2011 7:16 pm
Excursion :Nice welding! Fancy doing another? I will pay you, obviously.
no problem, how manny inlet/outlets do you want ect ? and if you want i can build it how ever you want if you have a design in mind.
crazycage
Postby crazycage on Wed May 18, 2011 8:21 pm
made a bracket to hold the breather and made a new alloy boost pipe :D
crazycage
Postby SEG1 on Wed May 18, 2011 10:53 pm
:Q
i could do with one of them inlets :lol:
SEG1
Postby luca on Thu May 19, 2011 11:22 am
Nice pipework there Gary :)
When you hoping to have ready?
luca
Postby creator on Thu May 19, 2011 6:09 pm
Looks spot on dude new boost pipes sweet
creator
Postby crazycage on Thu May 19, 2011 6:18 pm
luca :Nice pipework there Gary :)
will be running next weekend :D
crazycage
